Question about Anderson Windows Andersen 24-15/16 in. x 43-17/32 in. Aluminum Casement Insect Screen CW4-1345056
Pulldown screen in outer door has snapped out
Screen has sprung from spring loaded assembly - can't get it back together,
  • Brad Brown May 30, 2014
    Hi cynthia bigley, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Is that the right make and model?
How to clean the streaks between the inner and outer glass on the oven door
Ugh its not fun and takes two people as you have to split the door with several screws and easy hands... take the door off... there's two tabs at the two hinges either slide them forward backwards or some are spring loaded. however get the door off and begin dis assembly preferably on soft surface. pay attention to how things go back together and begin cleaning have fun....
Sep 02, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
HOW TO OPEN HARRIS GARAGE DOOR WHEN SPRING SNAPS
In such a situation replace the spring assembly and shaft that it is attached to. Then determine how many winds you need to add to the windlass for spring tension to get the door to lift. Depending how the door track it is set up the outer wheels that take up the lift cable spool about 16 to 18 inches of cable per revolution. The spring gets tensioned by sticking a length of half inch/13 mm rod into 1 of the 4 tensioning holes of the windlass that are cast into the clamping end of the spring and turning tension onto the spring by way of that windlass to lift the door once the cables are attached to the door and then clamped into the wheels, once the approximately correct lift height has been cranked into the spring.One rod would need to be left in place to hold windlass firm until the set screw is tightened. Then you can put on a hard hat, unlock the door and lift slightly- the rod will fall out if you wound the spring the correct direction.and the door should rise again with ease.
Dec 31, 2011 | Home Security
My shaving head came apart and I can not re assemble it, kindly give me instructions
Wife cleaned bathroom shelf dropping the Arcitec. One of 3 heads was not aligned properly, when I tried to re-seat it, this head came apart. To put it back together takes some finesse and patience. Take a coil of stamps, or some other small opening to rest the outer plastic shell head, then insert the metal screen which has notches (2 small, 1 large) and fit it in the plastic shell head. Next put the metal blade assembly on the screen. Next align this on the metal (thin) pivot. When the outer plastic head, and the metal pivot are aligned (small peg holes), you can place the thin inner plastic piece on and gently press your sub assembly and the backing plastic together, It will snap together and hold. Don't FORCE it, the holes must be aligned on the outer plastic, the metal pivot frame, with blades resting on the screen. It does snap together. Work with fairly bright light to see what you are doing. If this fails, invest in a new head assembly for about 15% of the cost of the whole razor.
Jun 10, 2011 | Norelco Arcitec Electric Shaver -...
I was trying to fix the door lock problem myself on my Whirlpool Duet Washer GHW9150PWO and I pushed the door lock mechanism down with a screw driver and it locked into place. Of course the door won't...
Did the screw driver make it out? UNPLUG THE WASHER There are 2 screws at the top of the washer that hold the top cover on. remove the screws and SLIDE the top cover back off the washer. This should expose the door lock assembly, down the right side of the door. There is 1 or 2 screws that need removed and then there is enough wiring that you should be able to pulll the switch where you can work on it.
Now here's the hard part. What probably happened was that the actuator was popped out of its cradle, possibly losing its spring tension. There are clips on on half of the plastic covers(2 halves snapped together). VERY carefully separate the assembly watching for a loose or shooting spring popping out of the covers. If the spring is still on the acauator arm, and hooked in place, good. carefully put the arm back in its cradle. hopefully it snaps in so reassembly is MUCH easier. Simply snap th e assembly back to gether. test the arm with your screw driver to make sure it is springy. Re install the lock where you removed it from the door area. Good Luck.
Jan 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Removal and installation of 1988 harley sportster clutch
In order to remove the clutch from your bike, you must have a special tool. You'll need H-D #34761 in order to remove the snap ring holding the clutch together.
Disconnect the battery, drain the primary, and remove the primary cover. Once you have the primary cover off, you can remove the nut from the compensator sprocket at the engine end of the primary chain.
Install the H-D 34761 or equivalent tool and compress the clutch spring. Remove the snap ring and then back off on the tool to release the pressure on the clutch spring. Once the pressure has been removed, remove the adjusting screw assembly, the outer clutch spring seats, the clutch spring, the inner clutch spring seat, and the pressure plate.
Then you can disassemble the rest of the clutch. Remove the remove the four friction plates and three drive plates. Then you can remove the spring plate and the remaining plates after that. Remove the snap ring that holds the clutch assembly onto the transmission clutch gear and remove the inner and outer clutch shells, the primary chain, and the engine sprocket as a group.
For this job, I would recommend that you purchase a service manual. It's has pictures that show you what you're dealing with and in this case, a picture is truly worth a thousand words.
Good Luck
Steve
Nov 05, 2010 | Harley Davidson XL Sportster 883...
Kenmore 790.49073400 oven door won't close completely
Hello- You are on the right track. The hinge assemblies are 'sprung' or bent out of shape. Replacing them is pretty easy, so you can do it yourself. Four screws on each side. Be careful, these springs can snap closed and bite ya. Use the little pins that come with the new set to lock hinge so this doesn't happen. Let me know if this info helps- have more if needed- Thanks- Ed
Mar 19, 2010 | Kenmore Ovens
I took the filter assembly apart, now I can't get it back together. There's a silver medal ring, a big cotton back, an inner plastic seal and an outer plastic seal. Somehow, they all fit back together....
The cotton bag wraps around the hepa filter - the blue plastic part will not be visible once the bag is in place. The silver ring sits inside the cotton bag to hold the sides of the bag against the sides of the vacuum top-half. DON'T pull the plastic inner seal and outer seal apart. They snap together and snap onto the lip of the vacuum top-half. It's a bit of a struggle snapping the seal back onto the lip.
Jan 11, 2010 | Vacuums
Window regulator front driver door ,have apart , window motor out , spring unwound , can not figure out how to hold and get window motor back on
Sorry i've been doing this a lot of year's and never been able to rewind spring.You're supposed to lock assembly together before removing motor.I almost lost a finger when my first one sprung.never after that.Possible best thing get one from salvag yard or dealer if ya got the extra money.
Aug 04, 2009 | 1999 Ford Expedition
Help about assembling my trimmer
I had recently put together one that may or may not be the same - the head seperated from the body, and a small spring loaded detent inserts in the backside that "locks" the head at steadily increasing disances (lengths). The hardest part to assemble is the switch: which the outer slider is installed first, then the switch assembly (w/Small printed circuit board ) is slid very deeply into the plastic body of the shaver - you'll see where it locks into place. Then the lower circuit board and prongs attach at the bottom (also you can see where it locks in). Lastly, the battery is installed within its' holder and snaps into the plastic case. The two pars of the cases are then mated and click-lock into place (Think there's a single phillip's screw to keep it locked). Lastly, the blade cover snaps into place from the top, and you should be good to go - I never got to take it apart, but I had to put it back together...I believe that's how it goes, and mine works - there is no allowance for error, and it looks to me that if it's not 100% right it won't go together anyhow - good luck...
Jul 07, 2009 | Wahl 9916-800 Groomsman Beard Trimmer
Kenmore HE3 lock latch stuck with door open
ok nice details..all you can do is replace the lock latch,,its not to costly,,change the catch while your there,,,lock part number is,,8181700 and catch part number is 8181651..it will be better just to replace it in the long run ,,,onthejob..
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Anderson Windows Andersen 24-15/16 in. x 43-17/32 in. Aluminum Casement Insect Screen CW4-1345056 Logo
53 people viewed this question
Top Anderson Windows Home Experts
Donni Steen
Tom Chichester
Are you an Anderson Windows Home Expert? Answer questions, earn points and help others
