Question about Garden
I have a Bosch AHS 42-16 hedge trimmer, After dismantling, cleaning and re assembling the blades, they now wont work correctly. The blades open when turning the cog but catch. There is a U shaped bar
Where the blades are screwed together the fixing holes are elongated,but the U bar has only a hole, I have tried assembling in a few positions but sometimes the fixing screws catch at the holes or the bar catches the cog and will not allow the blades to rotate fully
2 Suggested Answers
  • 252 Answers
SOURCE: Bosch Hedge Trimmer AHS 4-16 Starts now and
sounds like you will need to replace starter pulley in the starter cover assy and check that the starter pawls are free to move and the pawl springs are no broken or the pawls are frozen
but your problem is most likley starter pulley
remove the starter cover and check the starter pulley
worn or damage teeth on pulley may be quite evident
cheers pauly46
Posted on Sep 12, 2010
What is the best way to sharpen bosch AHS 45 16 HEDGE TRIMMER
Please understand, if you do, you may well start a business!
You will have to take it all apart, and then take either a file or a grind stone and resurface the blades.
I know you can learn this skill, if you do not know how, but this time it will take you to do it right will be hours, and if you charge a reasonable rate to do this for others, you may find it cheaper to buy a new one!
You may be able to find a web-site by looking on-line that will tell you exactly you to do this.
God bless your efforts.
Jul 11, 2016 | Bosch AHS 45-16 Electric Hedge Trimmer
My Bosch AHS 48-16 Electric Hedge Cutter hit a bit of wire, now there's s clickingn noise when trying to start it. Any help appreciated
It could have possibly damaged the cutting edge of the blades and put a burr on them, meaning that as the blades reciprocate, the 'burr' is catching on the other blade.. Check the blades for damage and use a flat file to smooth off any burrs that could be catching. (Make sure it's unplugged before doing any work on the machine)
May 10, 2016 | Electric Garden
My hedge trimmer has a faulty switch
Hi Bob:
First, make sure the power supply cord is connected with power at the tool.
Since it's already broke, you really can't hurt it so you get to play if you're into it.
Disconnect from power supply!
Try to determine if something is stopping the switch from moving far enough to function.
Dismantle until you can get the switch out. Try to clean the switch terminals and check the function with a continuity meter.
If you can't get it to work, see your local dealer about getting a replacement part.
Sep 18, 2015 | Bosch AHS 45-16 Electric Hedge Trimmer
I have a Bosch hedge trimmer AHS 52 LI and yesterday when I tried to fit the battery to the trimmer it would not fit
Make sure that you are using the right battery, positioning it right to match how it goes the receptacle. Last thing is do not be afraid to give it a good push in there. New ones in particular have a firm seating which can take a little bit to get it in.
Feb 20, 2015 | Bosch AHS 52 Li Cordless Hedge Trimmer
How to open a Bosch AHS 4-16 Hedge Trimmer ?
Not sure how to open it - if engine runs but clutch doesn't engage on revving perhaps the clutch has seized... point to bear in mind though is if you can't open the gear box (don't know how to) you most certainly won't be able to change a part inside - you will just get fiddly bits everywhere and never get them back where they should be - best get a pro to give you their opinion on whether it is worth the cost of getting it fixed.
Sep 22, 2014 | Bosch Ahs4-16 42Cm 390W Electric...
My Bosch AHS 45 16 electric hedge trimmer start, is there anything you can suggest?
Hi Dan Walsh, When an electric motor won't start, it could be an open temperature device in the winding of the motor itself. If you have brushes and they are worn, then one or maybe two of the brushes can't stay inside the brush holder. They are spring loaded and if worn out can pop out. Also, if the winding are open, then there is not continuity. This will cause the condition you described. Not the best news, but it might answer your question.
Good Luck!
Jun 03, 2014 | Bosch AHS 45-16 Electric Hedge Trimmer
I have Bosch hedge trimmer AH15 63-16C which has stopped cutting. It still seems to be working as it should and the cutters moving as normal but suddenly stopped cutting? Just wondering if this is fixable...
This sounds similar to a problem I have with my Bosch AHS 60 24s. The blades are moving but not independantly and therefore not in a cutting action. I took it apart and the bottom blade has slipped off the drive wheel. I put it all back as it should be but as soon as I used it again, the same thing happened. I'm not sure why this is happening, it may be that the motor end of the bottom blade has become slightly bent, so I will be trying to straighten at the weekend. The cost of replacement blades is prohibitive and time for a new hedge trimmer. Has anyone else had this problem and a different solution.
Oct 07, 2013 | Bosch AHS 45-16 Electric Hedge Trimmer
cheers pauly46
Sep 19, 2009 | Garden
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
