Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTPS Normal button flashing
Normal light flashing will not start
3 Suggested Answers
  • 1314 Answers
SOURCE: Whirlpool GU2400XTPS rinse only light is blinking
mutiple keys stuck press keys one at a time then hit cancel
Posted on Dec 30, 2007
aborcass
  • 2651 Answers
SOURCE: whirlpool dishwasher
look behind the lower acess panel( toe kick) for the tech sheet, there is aspot cleary labeled "clean light ' blinking 7 times.
Posted on Nov 25, 2008
I have a whirlpool dishwsr. model GU2400XTPB7 that has been flashing the normal light and I cant use it for over a week. I turned off the breaker to the house for 30 min. & that did not work. I tried...
Hi Melinda,
Thanks in advance for using Fixya.com. Now then firstly by pushing the heated dry and normal buttons then repeating is the proper procedure to reset the control board,below is a the exact buttons to push to reset the control. Also please take a count of the number of times the light flashes befroe going off breifly then repeats the same number of flashes; the number of flashes indicates a error code...if if flashes 5 times that error code 5 and if it flashes 7 times its error code 7 etc,etc.. please get back to me with the number of times it flashes.
Here is what i copied and pasted from my online service manual for Whirlpool dishwashers that shows which buttons must be pushed to reset the board,after pushing the buttons shown push the cancel/off button and the board should be reset so the machine will start at least one time where ya can take note of the number of times the nirmal light flashes,
GENE
Mar 01, 2012 | Whirlpool Dishwashers
Whirpool Dishwasher ADP5966 Turned dishwasher on. Only light that comes on is normal wash light. Start button is flashing when normal wash light is on. On pressing start button dishwasher does not work
Most likely the door switch is not making proper contact when you shut the door or the Start button is faulty. Needs someone to look in the door panel to fix.
Feb 15, 2011 | Whirlpool Dishwashers
Clean light is blinking and cannot use dishwasher
Hi
Thanks for using FixYa. If the green/clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | Whirlpool GU2400XTPS Built-in Dishwasher
How can I reset my whirlpool dishwasher?
did the just fail or did it leak? if it just failed count the times the light flashes and your hand book may tell you what the problem is.
Mar 19, 2010 | Whirlpool GU2400XTPS Built-in Dishwasher
Whirlpool Gold dishwasher water overflowing and will not shut off
There should be a dome shaped float switch on the inside bottom of the washer. Make sure it is free to move up and down, or is able to float (possibly cracked or broken).
Jun 28, 2009 | Whirlpool GU2400XTPS Built-in Dishwasher
Wont run a cycle
Watervalve open?
If yes?
Has this unit an integrated waterstop with the hose interlocked with a flow detection device? Mine failed on that. Bought a new machine after 10 year of service the flow device was 300 dollars.
Apr 04, 2009 | Whirlpool GU2400XTPS Built-in Dishwasher
Normal wash cycle constantly blinking no other buttons responding dishwasher wont start
one of 3 things is happening, either your "start" button is not funtioning, the door latch is not operating, so the uint doesnt recognize the door closing there fore wont operate, or the "normal" button is "stuck"( electronic switch possible shorted)
the fact that you cant get any other function out of it leads me to believe that you have a stuck button/shorted keypad. this is not available as a seperate part and requires replacing the "console with active overlay"
Mar 03, 2009 | Whirlpool GU2400XTPS Built-in Dishwasher
Normal cycle light flashing
press and hold the start button until it resets about 5 sec then try again.
Mar 01, 2008 | Whirlpool 24 in. DU1055XTPS Stainless...
Dec 30, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. DU1055XTP Built-in Dishwasher
I don't know if your dishwasher is the same as mine, but this solution may be what you need. For electronic panel dishwashers made by whirlpool (mine is a whirlpool but with a kenmore name on it), some of them can be reset by pushing in sequence the Heated-Dry button followed by the Normal-Wash button, several times in a row. that is... Push Heated-Dry, then Normal-Wash, Then Heated-Dry, then Normal-Wash... Repeat until all lights light up. When all lights light up you can stop. The washer will then take 5-10 minutes to go through a diagnostics cycle, which is about 18-25 steps or so. You can bypass one step at a time by pushing the STart button. This may not apply to your washer, but is pure gold if it does. Good Luck!
May 26, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
Whirlpool GU2400XTP Built-in Dishwasher Logo
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
