Question about Panasonic Audio Players & Recorders
Zen m72 mic jamper
Zen m72 plus headphone solution
  • ankastrinity Apr 02, 2014
    Hi rahul kumar, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Sch-f219 mic problem
samsung scg f219 mic problem
Dec 05, 2012 | Cell Phones
Spice m-4580 mic jamper digram
spice m4580 mic ki positive supply short ho gayi hai so solution bataye thank u
Apr 13, 2012 | Cell Phones
Spice 940 mic jumpr
spice m940 gold mic jumper solution
Nov 21, 2011 | Cell Phones
Nokia 6120 classic mic got muted?
if remove mic point, then jumper from ic
Jun 19, 2010 | Nokia 6120 classic Cellular Phone
My front panel headphone& mic connecting pcb have only 7 slots and the cable is named as 1)LINE OUT FR,2)LINE OUT RR,3)LINE OUT FL,4)LINE OUT RL,5)MIC IN(R),6)GROUND,7)MIC POWER(L) how can it connect...
FR stands for Front Right, FL for Front Left, RR for Rear Right and RL for rear left. These are speakers connections. You need a convertr cable to connect your headphones with your PC. After getting cable, connect it with FR and FL or RR and RL pair. Your headphone will be working. Similarly get the cabl for Mono to Stereo Mic and you can connect your mic too. (ehteshamhusain@gmail.com)
Jul 14, 2009 | Computers & Internet
Creative zen plus player problem?
Bad quality headphones? or possibly the headphone jack port is damaged which can alter the way songs sound. 9 times out of 10 it can be solved by buying new headphones.
Feb 19, 2009 | Creative Labs Zen Stone Plus MP3 Player
Intructions for recording Mic or Line In and SAVING to PC
Hi
Recording is quite easy:
1. To record from the Mic, simply press the button on the side of the player with the red dot and speak into the mic - its the small hole at the top left of the player.
2. To record line-in: connect the small mini stereo jack to the player and the other end to the line or headphone output of a recording device. Use the menu to find 'line in recording' (its towards the bottom of the menu). Monitor the input signal and adjust its level using the VU meters on the V Plus. Using the volume control on your player device, ensure that the signal is not too loud so that it clips, nor too soft (it will be noisy). When ready, press the red dot button. Press it again to stop recording.
3. To find the recordings and transfer files to PC: using the Zen Explorer, find the folder 'Recordings' on the Zen. Your recordings will be stored there with file names such as "Line In {date, time}.wma". Simply copy and paste these files onto your PC and play them with Winamp or Windows Media Player. Note that they are in WMA format, not MP3 format, but that this is a better standard than MP3 and can be played on most MP3 players.
Hope this has helped, and now can someone help me - my Zen V Plus screen is dead, and I didnt' even drop it.
John
Jan 11, 2009 | Creative Labs ZEN V Plus MP3 Player
Mono Sound Playing through Headphones
Simplest solution, from experience: make sure your headphone jack is pushed all the way into Zen 3.5 output jack. Sometimes it will feel like it's clicked in but you need a little extra push to get it all the way in.
Another thing to look at: I pretty sure the is a preference setting that controls right/left balance (my son has my Zen right now). If you can find  this control, it could be set all the way to one or the other side.
Give it a try, or see if resetting zen helps.
Good Luck.
Jun 10, 2008 | Creative Labs ZEN V Plus MP3 Player
Zen V plus screen fail/constant charge glow
· http://www.zenrepair.com/Zen/index.jsp
Sep 15, 2007 | Creative Labs ZEN V Plus MP3 Player
27 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
