Hi my sound as stopped working on my 40 inch jmb tv the buttons working turning up an down no sound tho
Jmb 40 inch tv no sound not muted an on full
    Top Expert:
  • Televison & ... Master
  • 75,417 Answers
Check its speaker first. If found OK, check and replace damaged component/s at its audio output section circuit. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 28, 2014
SOURCE: There is NO SOUND from the LC3760N 37 inches TV.
The problem was caused by a loose conexion. One of the cables that goes from the DirecTV box to the TV was loose. The problem was FIXED by pushing the cables to make sure there was a good conexion.
Posted on Jun 18, 2009
  • 63 Answers
SOURCE: Mute is on when I turn my vizio on. How do I
The OSD consists of several menu options: Picture Adjust, Audio Adjust, TV Tuner Setup, Parental Controls,PIP Set Up, or Special Features. When in the TV menu, select the Audio Adjust and make sure the mute is off. It may be worth checking the manual which is avialble from: http://www.vizio.com/downloads.aspx
Posted on Aug 20, 2009
roety
  • 585 Answers
SOURCE: Ln40a5op3p Samsung LCD 40
Hi my name is Eric,
I hope I can help you with your issue ,
Do you have a cable box?
 First thing i think of is you need to reboot the cable box by unplugging it from AC power, then reconnect it. (then reboot the Tv same way if haven't done that yet either) then its time to try it with AV cables
to make sure the cable box is not bad. using the red/white and yellow cables
then testing with another source like a DVD player, common sense will tell you if its the cable box or the TV.
If you've already done this or don't have a cable box (sorry),
The only thing in the TV that can cause you to lose audio only on TV is the SAP mode.
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
Posted on Sep 09, 2009
Testimonial: "Great feedback with multiple options thanks"
SOURCE: The volume on the TV doesn't work. TV worked fine last night
You can always turn your TV off, unplug it from the electrical outlet, wait for 30 seconds or so, plug it back in, then turn it back on. If you have kids check the menu options to see if they may have tampered with it unintentionally. If all else fails, call Vizio and ask for their professional help. If you are not satisfied with their help and assistance, make a complaint by going to BBB.org (Better Business Bureau). Maybe if you tell Vizio that you're going to call the BBB then they might take you a little more seriously.
Posted on Dec 28, 2009
SOURCE: We have a Vizio 22 inch. The remote will turn on
I have the exact same problem. Let me know if you find a solution...ssteffek6@yahoo.com
Posted on Feb 01, 2010
40 inch element tv is muted but we never muted it
it is mute it will have the mute symbol on the screen
if you get the symbol by pressing the mute button on the remote then the sound card has failed so take it in for a proper diagnosis and quote
Aug 05, 2017 | Element Televison & Video
Why is there no sound?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Sep 05, 2015 | Televison & Video
Jmb tv troubleshootingMy jmb tv won't turn on. The stand by flashed a few times and the tv turned off and will not turn on. No response at all. I have changed the fuse but still nothing. Model no,...
Hi , silly question but I have a jmb tv 32 inch code Jt0132003B/01 but can't find the power button on the tv !?! I looked all over the tv but doesn't seem to have one ??? I don't want to leave it on stand by so my only option is to turn off at wall but that turns off My talk talk and DVD player too , any know where is it !?!
Apr 19, 2014 | Televison & Video
My 40 inch S400A Series Full HD BRAVIA LCD TV does not turn on. When i plug it in, the green light (next to the Red power light) blinks. If i try to power on via remote, the red power light turns on and...
this again sounds like the power supply,.if you hear a click when you push the power button, this means your main board is reading good so replace the power supply,.
Apr 06, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a olevia 37 inch tv that when i turn it on and try to change the channel it goes mute. i tried turning the channel on the tv and same issue, goes mute. sometimes when i turn the tv off and back on...
sounds like av main board in back of tv try factory reset or make sure tv is off 10 mins then open back up try giving it hoover sounds daft but a lot of problems happen dust nothink to lose hope it helps mark google how tofactory reset and then make model of you tv should find help try same youtube videos
Mar 04, 2018 | Televison & Video
My insignia 37 inch tv
Press menu and use the up or down arrows to find the audio section adjustments. Press the right arrow and again use the up and down arrows to find tv speakers, Press the right arrow to either turn on tv speaker or turn them off ( This is used only if you are using the output signal from you tv in to you stereo input to have surround sound.) Turn them on to listen to sound from the television speakers only. If this does not solve your problem, Press the mute button on you remote control to release the mute function. If all this does not work the telephone number for Insignia is 1-877-467-4289. Talk to them about you problem and see if your television needs some type of service to restore the sound. Hope This helps you with your problem.
Mar 19, 2009 | Insignia 37" LCD Flat-Panel HDTV
No sound
the DVDS151 has its own built in volume control that is easy to hit the buttons near the bottom of the remote and accidently turn the volume down.
even tho your tv volume is set high it won't pass the sound to the tv if it is on mute or turned down.
Mar 18, 2008 | Daewoo DVDS151 DVD Player
Televison & Video Logo
407 people viewed this question
Top Televison & Video Experts
