Question about Vehicle Parts & Accessories
Jurking 30 kmph speed vss sensor disconected vehicle running smoothly
Tata nano car
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 159 Answers
Check the sensor
Posted on May 11, 2014
04 f150 heritage speedo moves but not over 10 mph and trans won't shift gears. i changed all sensors,traced all wires.
taking your vehicle to a qualified reair shop to have it diagnosed would be a good thing to do . You could not have traced all wires ! Because i'm sure you haven't any idea how this works . An a factory scan tool is a must to diagnose this .Do you know what ford SCP data network is ?
Speedometer
The instrument cluster receives the vehicle speed signal from the powertrain control module (PCM) over the standard corporate protocol (SCP) network and displays it on the speedometer gauge. If the instrument cluster receives no vehicle speed signal after one second, the speedometer defaults to 0.0 km/h (0.0 mph).
Vehicle Speed Sensor
The vehicle speed sensor (VSS) (Figure 52) is a variable reluctance or Hall-effect sensor that generates a waveform with a frequency that is proportional to the speed of the vehicle. If the vehicle is moving at a relatively low velocity, the sensor produces a signal with a low frequency. As the vehicle velocity increases, the sensor generates a signal with a higher frequency. The PCM uses the frequency signal generated by the VSS (and other inputs) to control such parameters as fuel injection, ignition control, transmission/transaxle shift scheduling and torque converter clutch scheduling.
P0500 - Vehicle Speed Sensor (VSS) Malfunction Indicates the powertrain control module (PCM) detected an error in the vehicle speed information. Vehicle speed data is received from either the vehicle speed sensor (VSS), the transfer case speed sensor (TCSS) or the anti-lock brake system (ABS) control module. If the engine RPM is above the torque converter stall speed (automatic transmission) and the engine load is high, it can be inferred that the vehicle must be moving. If there is insufficient vehicle speed data input, a malfunction is indicated and a DTC is set. On most vehicle applications the malfunction indicator lamp (MIL) is triggered when this DTC is set.
  • Open in the VSS+/VSS- harness circuit.
  • Open in the TCSS signal or the TCSS signal return harness circuit.
  • Short to GND in the VSS harness circuit.
  • Short to GND in the TCSS harness circuit.
  • Short to PWR in the VSS harness circuit.
  • Short to PWR in the TCSS harness circuit.
  • Damaged drive mechanism for VSS or TCSS.
  • Damaged VSS or TCSS.
  • Damaged wheel speed sensors.
  • Damaged wheel speed sensor harness circuits.
  • Damage in the module(s) connected to the VSC/VSS circuit.
  • Open or short in the vehicle speed circuit VSS signal between the ABS VSS signal output and the VSS signal inputs to the PCM and other modules (Excursion and F-Super Duty).
Monitor the VSS PID while driving vehicle. This DTC is set when the PCM detects a sudden loss of vehicle speed signal over a period of time. If vehicle speed data is lost, check the source of where the vehicle speed input originates from: VSS, TCSS or ABS. Note: On some MSOF applications, VSS and TCSS PID can be monitor. However if no TCSS PID is available and VSS PID is zero, TCSS circuitry frequency must be checked for loss of sensor signal. If another vehicle electronic module has generated the P0500 and the vehicle does not receive its vehicle speed input from one of the above mention sources (VSS, TCSS or ABS). Check the PCM for Output Shaft Speed Sensor (OSS) DTCs. On OSS applications the PCM uses the OSS to calculated the vehicle speed. If no OSS DTCs are found check for correct PCM configuration. Check PCM configuration for correct tire size and axle ratio. P0501 - Vehicle Speed Sensor (VSS) Range/Performance Indicates the powertrain control module (PCM) detected an error in the vehicle speed information. This DTC is set the same way as P0500, however the malfunction indicator lamp (MIL) is not triggered.
  • Refer to possible causes for P0500.
Refer to Diagnostic Aids for P0500. P0503 - Vehicle Speed Sensor (VSS) Intermittent Indicates poor or noisy VSS performance. Vehicle speed data is received from either the vehicle speed sensor (VSS), the transfer case speed sensor (TCSS), or the anti-lock brake system (ABS) control module.
  • Noisy VSS/TCSS input signal from the radio frequency interference / electro-magnetic interference (RFI/EMI) external sources, such as ignition components or the charging circuit.
  • Damaged VSS or driven gears.
  • Damaged TCSS.
  • Damaged wiring harness or connectors.
  • Malfunction in the module(s) or circuit connected to the VSS/TCSS circuit.
  • After market add-on.
Monitor the VSS PID while driving the vehicle. Check for intermittent vehicle speed indication. Verify the ignition and charging system are functioning correctly.
Mar 25, 2017 | Cars & Trucks
99 Grand Am VSS location
At the rear of the engine/transaxle
Connector Part Information
12162195
2-Way F Metri-Pack 150.2 Series Pull to Seat Sealed (BLK)
Pin
Wire Color
Circuit No.
Function
A
PPL
401
Vehicle Speed Sensor (VSS) Return
B
YEL
400
Vehicle Speed Sensor (VSS) Signal
Two wire connector !
Aug 09, 2016 | Cars & Trucks
I have a1999 cougar the speed on stop working now the transmission will not shift in less you manual shift your self what could be the problem
The speedometer stopped working ? is this what you meant ? You probably have a bad VSS - vehicle speed sensor . The VSS is an input to the PCM - engine computer , besides being a signal for the speedometer it is used for shift control and other thing's .
Vehicle Speed Sensor The vehicle speed sensor (VSS) (Figure 43) is a variable reluctance or Hall-effect sensor that generates a waveform with a frequency that is proportional to the speed of the vehicle. If the vehicle is moving at a relatively low velocity, the sensor produces a signal with a low frequency. As the vehicle velocity increases, the sensor generates a signal with a higher frequency. The PCM uses the frequency signal generated by the VSS (and other inputs) to control such parameters as fuel injection, ignition control, transmission/transaxle shift scheduling and torque converter clutch scheduling. You could possibly have a DTC stored in the PCM.
P0500 - Vehicle Speed Sensor (VSS) Malfunction Indicates the powertrain control module (PCM) detected an error in the vehicle speed information. Vehicle speed data is received from either the vehicle speed sensor (VSS), transfer case speed sensor (TCSS), anti-lock brake system (ABS) control module, generic electronic module (GEM), or central timer module (CTM). If the engine rpm is above the torque converter stall speed (automatic transmission) and engine load is high, it can be inferred that the vehicle must be moving. If there is insufficient vehicle speed data input, a malfunction is indicated and a DTC is set. On most vehicle applications the malfunction indicator lamp (MIL) will be triggered when this DTC is set.
  • Open in VSS+/VSS- harness circuit.
  • Open in TCSS signal or TCSS signal return harness circuit.
  • Short to GND in VSS harness circuit.
  • Short to GND in TCSS harness circuit.
  • Short to PWR in VSS harness circuit.
  • Short to PWR in TCSS harness circuit.
  • Open or short in the vehicle speed circuit(s) (VSC) between the PCM and appropriate control module.
  • Damage in module(s) connected to VSC/VSS circuit.
  • Damage drive mechanism for VSS or TCSS.
Diagnostic Aids: - Monitor VSS PID while driving vehicle. This DTC is set when the PCM detects a sudden loss of VSS signal over a period of time. If vehicle speed data is lost, check source of where vehicle speed signal originates. Note TCSS does not have a PID, circuitry frequency must be checked for sudden loss of sensor signal. P0501 - Vehicle Speed Sensor (VSS) Range/ Performance Indicates the powertrain control module (PCM) detected an error in the vehicle speed information. This DTC is set the same way as P0500, however the malfunction indicator lamp (MIL) is not triggered.
Refer to diagnostic aids for P0500.
Oct 26, 2015 | Cars & Trucks
My check engie light came on then about a week or so later my speedometer stopped working on my 2000 ford ecsort
The Vehicle Speed Sensor is what tells the Speedometer how fast you are going. Have your check engine light scanned for the code that is set. Replace the Vehicle Speed Sensor if necessary.
Removal
  1. Raise and support the vehicle.
  2. Disconnect the vehicle speed sensor (VSS) electrical connector.
  3. Unclip the heated oxygen sensor (HO2S) wire clip from the VSS bracket.
  4. Remove the VSS retaining bolt.
  5. Remove the VSS.
Installation
  1. To install, reverse the removal procedure.
Mar 04, 2011 | 2000 Ford Escort
Can you tell me where vechile speed sencor 'A' is on my focus st the fault code is P0500
P0500 Vehicle Speed Sensor "A"
P0501 Vehicle Speed Sensor "A" Range/Performance
P0502 Vehicle Speed Sensor "A" Circuit Low Input
P0503 Vehicle Speed Sensor "A" Intermittent/Erratic/High
Vehicle Speed Sensor Removal & Installation Automatic Transmission To Remove:
  1. Remove or disconnect the following:
    • Output shaft speed (OSS) sensor electrical connector.
    • Bolt and OSS sensor
To Install:
  1. Apply a light coat of petroleum jelly to the O-ring before installation
  2. Install or connect the following:
    • OSS sensor torque bolt to 89 in-lbs (10 Nm)
    • OSS sensor electrical connector
Manual Transmission To Remove:
    • Vehicle Speed Sensor (VSS) electrical connector.
    • Retaining pin.
    • VSS.
To Install:
  1. Install or connect the following:
    • VSS.
    • Retaining pin.
    • VSS connector.
The VSS is on the transmission near the output shaft. It will not be a wheel speed sensor on the hub.
Good luck on this repair, tommy.
Nov 06, 2010 | 2006 Ford Focus
1994 GRAND MARQUIS Odometer stopped working, tridometer aswell
If the odometer and tripmeter stop incrementing their mile values, then the VSS or vehicle speed sensor is bad or has become disconnected.
Vehicle Speed Sensor OPERATION The Vehicle Speed Sensor (VSS) is a magnetic pick-up sensor that sends a signal to the Powertrain Control Module (PCM) and the speedometer. The sensor measures the rotation of the transmission output shaft or the ring gear on the differential and sends an AC voltage signal to the PCM which determines the corresponding vehicle speed.
TESTING
  1. Disconnect the negative battery cable.
  2. Disengage the wiring harness connector from the VSS.
  3. Using a Digital Volt-Ohmmeter (DVOM), measure the resistance (ohmmeter function) between the sensor terminals. If the resistance is 190-250 ohms, the sensor is okay.
REMOVAL & INSTALLATION Fig. 1: Detach the connector for the VSS sensor 91194p27.jpg
Fig. 2: Remove the retaining bolt for the VSS sensor and . . . 91194p28.jpg
Fig. 3: . . . remove the VSS sensor from the transmission 91194p29.jpg
Fig. 4: Pry the retainer for the VSS gear off and . . . 91194p30.jpg
Fig. 5: . . . remove the gear from the VSS 91194p31.jpg
  2. Raise and safely support the vehicle securely on jackstands.
  3. Detach the connector for the VSS.
  4. Remove the VSS retaining bolt and remove the VSS from the transmission.
  5. Remove the driven gear retainer and the drive gear. To install:
  6. Inspect the O-ring on the sensor and replace if necessary.
  7. Install the driven gear and the retainer.
  8. Place the VSS into the transmission.
  9. Tighten the retaining bolt to 98-115 inch lbs. (11-13 Nm).
  10. Attach the VSS electrical connector.
  11. Lower the vehicle.
  12. Connect the negative battery cable.
Oct 23, 2010 | 1994 Mercury Grand Marquis
Where is the location of the speed sensor on the 1999 v10 triton f250? Why does my speedo not work?
VSS Sensor The Vehicle Speed (VSS) Sensor input is used by the PCM to determine vehicle speed. The VSS generates a signal that increases in frequency proportionate to vehicle speed. The PCM has a base frequency stored in memory for a distance of one mile. By comparing the input and stored value, the PCM calculates vehicle speed.
VSS types include: photo-optic, permanent magnet generators or hall effect technology. The PCM may use other sensors on the vehicle (ABS Wheel Speed) to validate VSS operation.
VSS information is used to calculate vehicle loads including: torque converter application, cruise control, fuel cutoff/speed governance strategies, instrument panel speedometer and more.
Modified drivetrain components such as final gear sets and/or tires can alter VSS input values to the PCM. Improper signals can alter Torque Converter Clutch (TCC) application, shift points, cruise control operation as well as many other systems relying on vehicle speed input.
WARNING
To avoid personal injury and/or vehicle damage, refer to the service precautions at the beginning of this section.
The Speedometer may not work due to a break in the wire for the VSS, or a bad VSS or a bad instrument cluster.
Oct 08, 2010 | Ford F-250 Cars & Trucks
What cause the O/d light blink
it's usually because you have a bad VSS, Vehicle Speed Sesnor. It sends a signal from the trans to the speedo and engine computer. Usually speedo stops working too.
Vehicle Speed Sensor (VSS) The vehicle speed sensor (VSS) (9E731) is a magnetic pickup that sends a signal to the powertrain control module (PCM) (12A650) . This VSS signal transmits vehicle speed to the powertrain control module .
Nov 10, 2009 | 1998 Ford Windstar
Speed sensor on 2000 ford f150 4x4 triton 4.6
if this helps, please rate as fixya. thanks.
For the 4R70W trans vehicles
The vehicle speed sensor (VSS) is model dependent. Possible sources of vehicle speed input are, anti-lock brake sensor (ABS), a gear-driven vehicle speed sensor (VSS), or the transmission output shaft speed (OSS) sensor. On 4x4 applications with a manual shift transfer case, the transfer case speed sensor is the source of vehicle speed. The VSS signal is either an AC signal whose frequency changes with vehicle speed, or an SCP data message depending on the source. Some vehicles have both. The vehicle speed signal is an input to various vehicle sub-systems such as the powertrain control module (PCM), instrument cluster (speedometer and odometer), speed control systems, etc. The vehicle speed source must be operational to enter output state control mode for diagnostics.
If you have a 4R100 trans, it is different.
Mar 12, 2009 | 2000 Ford F150 Flareside SuperCab
Vehicle Parts & Accessories Logo
26 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
