Home teathre The remote control for philips blue ray HTS5560/98 currently not working as normal use, to any one please HELP me!!
5 Suggested Answers
SOURCE: Time Warner Remote Code to work volume for Philips Home Theater
after much trial and error i found a code that partially works.... 3025
it controls volume, power, mute and the c button on the remote controls the genre of music. AND THATS ALL. no analog of songs no fwd or rwd, its better than nothing though
Posted on Feb 02, 2009
dunnbiker
  • 8546 Answers
SOURCE: my Samsung Remote doesn't work with my Blue Ray
Try this advice:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641
"Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the unit.
If it works, Great!
If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Posted on Jan 19, 2011
PhilwithDISH
  • 123 Answers
SOURCE: I moved into a new
We would be happy to help with that. Please keep in mindthat the code provided will only be compatible with either the 20.0 or 21.0model remotes. The model number of a remote can be found on the back of theremote, close to the top. The first thing we want to do is hold the AUX buttondown until all the mode buttons on the top of the remote light up, thenrelease. Once the AUX button is blinking, press 2 then * then enter 836followed by the pound (#) button. The AUX button should blink 3 times and youshould be able to operate your LG LHB953. Remember to put the remote back in SAT mode after you'redone. Althoughwe try and facilitate using your DISH remote to control other devices, thiscode may not be compatible with your equipment. Thank you for being a valuedDISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Posted on Feb 22, 2011
SOURCE: cannot get surround sound to work with Philips hts3106/f7 andonic tcp50g25. It works fine for Blue ray via the hdmi out of philips dvd/receiver, but not for xbox or cable etc (only works in stereo).
i have the same system. all you have to do is when you connect your xbox 360, press the surround button on the remote and then use the arrow buttons to change it to dolby music pro2 or multi channel audio. same goes with any device you connect. hope it helps. In my case the xbox is connected to the Tv via HDMI and bluray player is connected to xbox via compoent cable
Posted on Dec 06, 2011
How to hard reset my philips blue ray
BDP5506, HTS5506, BDP3306, HTS3306, BDP3506, HTS3506, BDP3106, HTS3106
Press the [Home] button on the remote. Then select [Setup]>[Advanced Setup]>[Restore defaults settings]>[Reset Network Setting]>[Yes]
BDP3406
Press the [Home] button on the remote. Then select [Setup]>[Advanced]>[Restore default settings]>[OK]
BDP7320, BDP7520, BDP5320
Press the [Home] button on the remote. The select [Settings]>[Factory Default]>[Network Settings]>[Yes]
http://www.p4c.philips.com/cgi-bin/cpindex.pl?ctn=BDP5506/F7&hlt=Link_UserManuals&mid=Link_UserManuals&scy=US&slg=AEN
Feb 09, 2016 | Philips Televison & Video
How can I get the Sony DVD home theater TO WORK ON MY UNIVERSAL REMOTE?
Universal remote codes Home theatre
Aiwa = 0641, 1912
Anam = 1913
Apex Digital = 1915, 1937
Audiovox = 0790
Cambridge Soundworks = 1916
Classic = 1917
Daewoo = 1918
Fisher = 1919
Gradiente = 0651
Initial = 1931
Integra = 1924
JBL = 1926
JVC = 1901
KLH = 0790
Koss = 0651
Magnavox = 1914
Norcent = 1923
Onkyo = 1924
Oritron = 0651
Panasonic = 1907, 1908, 1909, 1910
Philips = 1914
Qwestar = 0651
RCA = 0790, 1913
Samsung = 1932
Shinsonic = 1931
Sony = 1903, 1904
Venturer = 0790
Sep 29, 2015 | Philips Phillips SRP1103/27 3-Device...
Rca blu ray home theater rtb10220 why did my remote quit working?
Probly moisture damage. Take it apart and check board for damage. U can also smell the board for a burnt smell.
Jul 24, 2014 | RCA Televison & Video
Remote code codes
This may help if you have a remote control from a pay-tv company.
Here's what Philips says (web link below):
Where can I find the remote codes for my Philips device?
Remote control manufactures all use different codes. We do not have list of the codes that are used for the Philips devices. The remote control manufacture will have the codes for your device. If you do not have a remote from a cable/satellite provider please contact the manufacturer of the remote you are using. If you are using the remote provided by a cable/satellite company please reference the list below.
Links to the major cable/satellite provider's remote control support pages including Comcast, Charter , Cox, Time Warner, DirectTV and so on.
Philips Blu ray Disc DVD player BDP2900 DivX Plus HD USB2 0 Media Link
Jan 24, 2014 | Philips BDP2900 Blu-ray Disc Player -...
Would like unlock code for Philips HTS5593 Blu ray
To make your Philips BDP3100 region free (this works on a BDP3100/05 purchesed in the UK in June2010)
1. Make sure there is no disc in the tray when you switch on.
2. Press "home" key on remote control.
3. Enter number "1389310".
4. Switch off. Wait a few seconds and then switch on...now region free.
Please note, the above hack has only been confirmed as providing region-free DVD, not Blu-Ray.
Mar 14, 2013 | Philips HTS5593/12 3D Home cinema system...
Need codes for rca remote for digital converter box so i can program it to my philips magnavox t.v
There's a universal remote in Home Depot n is only four bucks and even has a code for blue ray maybe that will work
Jan 07, 2013 | RCA Universal Tv Digital Converter Box...
Can I change my Philips DVP3950 to region-free?
Before you begin please ensure you have connected your DVD player to your TV and both have the power turned on. Once you have connected your TV please follow the instructions below using the remote control.
Select SETUP then press OK (via the DVD remote control)
Using the arrow down button highlight PREFERENCE
Press NEXT, PREVIOUS, NEXT, PREVIOUS (the >l, l<, >l, l< buttons in the bottom of the remote control ).
Your current region should show on the TV screen
Using the arrow down button select region code 0
Press OK
Press the 'HOME' button
You have now completed this process. Enjoy! (from multi-region.net) Also works for DVP3800. The remote control has no numbers on model DVP3950
Dec 23, 2012 | Philips dvp-3960 region code free dvd...
Cannot get surround sound to work with Philips hts3106/f7 andonic tcp50g25. It works fine for Blue ray via the hdmi out of philips dvd/receiver, but not for xbox or cable etc (only works in stereo).
Nov 26, 2011 | Philips Audio Players & Recorders
Unlock code region hts5560
Open the Philips HOME SCreen,...
Type on your remote: 13893108520
This will display all of the current settings for your player.
Region_Code: DVD(2) BD(B)
This will not change any settings, but will report your current settings. So it's a reporting function only.
To change your DVD region settings try the following:
Turn on player with no disk inserted
Press "Open/Close" on the remote control
Press 259 on the remote control
After enter the code 13893108520 again on the HOME Screen and the player will show region "0"
Now the buttons on the front of the player do not work anymore.... You will need to go to SETUP and click on RESET FACTORY SETTINGS....
Wait until the player restarts and now you can play all DVD regions..... ;-)
Oct 16, 2010 | Philips Televison & Video
Unlock HTS 3555
Press "Door Open"
- after the door opens perform the following sequence with the remote control:
Press STOP-7-3-4-4-6-6
a Region settings page will be displayed showing the current region on the TV (usually the default is region 1), using the remote control select the region number by pressing the number on the remote (select region 0 for region free) and press OK.
May 05, 2008 | Philips HTS-3555 System
19 people viewed this question
 Grubhead
Grubhead
