Error code t98-540
Error on reading/writing data
4 Suggested Answers
  • 105 Answers
SOURCE: Nero 7 write error
i think you have tried to write a cpoyrighted disc .
Posted on Jun 18, 2008
  • 10 Answers
SOURCE: Seagate 300GB USB 2.0, read write error
Hook it to another computer do see if the drive is the issue.
Posted on Oct 04, 2008
sweetyanne
  • 68 Answers
SOURCE: DELL XP
Turn on your system when you see the dell logo, tap on f12, there is an option there to click on IDE DIAGNOSTICS, or utility partition, using your arrow keys choose any of these and run the test, it will tell you if your hd is bad, if not you might be able to do checkdisk by using the xp disk and go to the recovery console.
Posted on Oct 31, 2008
1999. What are the probable causes of DTC P1624?
Definition of Diagnostic Trouble Code P1623 Audi: Data Bus Powertrain No Communication BMW: Pedal Position Sensor Potentiometer Supply Buick: Transmission Temp Pull-Up Resistor Cadillac: Transmission Temp Pull-Up Resistor Chevrolet: Transmission Temp Pull-Up Resistor Chrysler: ASD Relay/Control De-Energize Too Soon Dodge: ASD Relay/Control De-Energize Too Soon Ford: Code word/id number-write/read error GMC: Transmission Temp Pull-Up Resistor Hyundai: Diagnostic Lamp Powerstage Malfunction Jeep: ASD Relay/Control De-Energize Too Soon Land Rover: Immobilisation ECU code storage fault.Last occurrence - signal fault Lincoln: Code word/id number-write/read error Mazda: Immobilizer Code Word/ID Number Write Failure Mercury: Code word/id number-write/read error Oldsmobile: Transmission Temp Pull-Up Resistor Pontiac: Transmission Temp Pull-Up Resistor Saturn: Transmission Temp Pull-Up Resistor Volkswagen: Data Bus Powertrain No Communication Volvo: ETS .amp / MIL on
Jun 27, 2015 | Hyundai Elantra Cars & Trucks
How do i reset error c7911 on kyocera printer ?
C7911 Developing unit K EEPROM error
No response is issued from the device in reading/writing for 5 ms or more and this problem is repeated five times successively.
Mismatch of reading data from two locations occurs eight times successively.
Mismatch between writing data and reading data occurs eight times successively.
Possible Causes;
  1. Poor contact in the connector terminals.
  2. Defective developing PWB K.
Jan 12, 2015 | Kyocera Office Equipment & Supplies
Error Writing Data (551-00000310 41329c5c)
Read only Means it may not burn a DVD but only CD-RW
Maybe the problem is the dvd is only rom not RW(read write)
Oct 24, 2013 | Computers & Internet
SC922 Error
922 B IMB DRAM error
The machine detects a discrepancy in
the IMB DRAM write/read data during
its write/read test (done at power off/on
and at recovery from low power or
night/off mode).
• IMB defective
• BiCU defective
• Poor connection between BiCU an IMB
might be time to replace copier for what it cost to fix it.
Feb 20, 2012 | Ricoh Aficio 1018D Copier
What does the error-code E50 means in a crayola Kiddycam 25070?
hi,
The "E50" error code indicates formatting a storage card has failed.I think the e50 error code happens when the camera is reading and/or writing to the CF card when the battery are dead or real low. The camera does not get to finish writing data and leaves an error on the CF card. Use new battery or fully charged battery. I hope this may help you,
regards,
kaybicks
Feb 27, 2010 | Cameras
E000315-000d Imagerunner 3320i error code at start up
E315
A fault is detected when encoding the image data.
1. A chip failure is found when writing/reading/verifying the
image data by using the register of the encoding chip.
FAX failure
2. An error occurs when encoding the image data
Aug 10, 2009 | Canon Image Runner 3320I Copier
Error - 8403 on cdj 200 not reed the cd
Can't find Error 8403 in the service manual. Please advise the correct error code and I'll see what I can find out for you.
E-7201 TOC READ ERROR 26: TOC data could not be read.
E-6002 DSP PROGRAM
DOWNLOAD ERROR
62: The program cannot be written in the DSP.
E-8301
PLAYER ERROR
(Startup error)
12: The desired address could not be searched.
15: Address data could not be read.
22: The Focus Servo could not be closed.
91: The pickup could not be returned to the inner track.
E-8302 PLAYER ERROR
(Abnormality in playback)
E-8303
PLAYER ERROR
(Abnormality in writing to the buffer)
99: Abnormality in writing in the buffer
E-8304
MP3 DECODE ERROR
(Abnormality in decoding)
Abnormality in decoding ∗∗
E-8305
DATA FORMAT ERROR
(Inappropriate data format)
A data format other than MP3 was used. ∗∗
E-9101 MECHANICAL TIME OUT 90: Abnormality in the disc-loading mechanism (TIMEOUT)
Feb 24, 2009 | Pioneer CDJ-1000 CD Player
Oct 04, 2008 | Seagate 300GB USB 2.0/FireWire Hard Drive...
Use vb.net and access
Imports System
Imports System.IO
Imports System.Data
Public Class SaveImage
Shared Sub main()
Dim o As System.IO.FileStream
Dim r As StreamReader
Dim gifFile As String
Console.Write("Enter a Valid .Gif file path")
gifFile = Console.ReadLine
If Dir(gifFile) = "" Then
Console.Write("Invalid File Path")
Exit Sub
End If
o = New FileStream(gifFile, FileMode.Open, FileAccess.Read, FileShare.Read)
r = New StreamReader(o)
Try
Dim FileByteArray(o.Length - 1) As Byte
o.Read(FileByteArray, 0, o.Length)
Dim Con As New _ System.Data.OleDb.OleDbConnection("Provider=Microsoft.Jet.OLEDB.3.51;Persist Security Info=False;Data
Source=Test.mdb")
Dim Sql As String = "INSERT INTO images (Pic,FileSize) VALUES (?,?)"
Dim Cmd As New System.Data.OleDb.OleDbCommand(Sql, Con)
Cmd.Parameters.Add("@Pic", System.Data.OleDb.OleDbType.Binary, o.Length).Value = FileByteArray
Cmd.Parameters.Add("@FileSize", System.Data.OleDb.OleDbType.VarChar, 100).Value = o.Length
Con.Open()
Cmd.ExecuteNonQuery()
Con.Close()
Catch ex As Exception
Console.Write(ex.ToString)
End Try
End Sub
End Class
Jul 08, 2008 | Microsoft Computers & Internet
Nero 7 write error
Jun 05, 2008 | Computers & Internet
18 people viewed this question
k24674
jasbo
jasbo
