Question about HP LaserJet M1005 Printer
M1005mfp scanner error 12
Xerox & scanning was not working
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • HP Expert
  • 146 Answers
manojro
  • 495 Answers
SOURCE: Scanner Error 12
SCAN ERROR 12, IT'S A MECHANIC PROBLEM. YOU MUST CONTACT A TECNICIAN.
Posted on Apr 17, 2009
md_ehsan_1
  • 255 Answers
SOURCE: scanner error 12
uninstall the software of scanner and reinstall it
check your cables for loose contacts
Posted on Jul 04, 2009
SOURCE: SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
Posted on Apr 19, 2010
puertobori
  • 7733 Answers
SOURCE: my printer m1005mfp display scanner
Try HP Support & Drivers.
Posted on Oct 15, 2010
  • 30 Answers
SOURCE: hp laserjet m1005mfp scanner error
Hi there and welcome to Fixya!
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize. If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn the device on.
This error message is usually fatal so if the problem persists after trying the steps above, you will need to contact the manufacturer for further assistance. Please refer to the manual that came with the printer for contact information.
Thanks!
Posted on Jul 02, 2011
Xerox 510 wide format printer error code LL-12
PLEASE INFORM ME
MY XEROX 510 IS DESPLAY ERRORE CODE LL-12
Jul 18, 2014 | Xerox documate 510 - 600 X 1200 Workgroup...
LSU error displayed on Xerox M20i
LSU stands for Laser Scanner Unit. It comes up only if you are trying to access scanner services like scanning a document, using fax or simple scanning.
If it's coming continuously you might need to check connectors within the scanner. Best way is to call a technician from Xerox or take it to their store.
Jun 21, 2011 | Xerox WorkCentre M20i All-In-One Laser...
I have find the error in printer canon lbp 2900 scanner error
First of all you are not sure about your product and problem
When LBP-2900 is only a printer.
No any other combination is present
No scanner OR Copier
May 12, 2011 | Canon LASER SHOT LBP-2900 Printer
I could not find the icon for the One Touch Visioneer scanning software for my Xerox Documate 510 so I uninstalled the software and re-installed and now I can't find anything. I am completely unable to...
  • Welcome [ What's in the Box ~ The Xerox DocuMate 510 Scanner ~ What You Need ~ Documentation ]
  • Installation [ Before You Begin ~ Step 1: Assemble the Scanner ~ Step 2: Install the Software ~ Step 3: Connect the Power Supply ~ Step 4: Connect the USB Cable and Turn on the Power ~ Additional Applications Available with Your Scanner ~ View the User Guides ~ Register Your Scanner and Check for Updates ]
  • Scanning [ Loading Documents to Scan ~ Load a Stack of Documents ~ Load a Single Page ~ Scan from the One Touch Button Panel ~ Check the Scan Settings Before Scanning ~ Using the One Touch Panel ~ About the One Touch Button Panel's Names and Icons ~ The Default One Touch Settings for Your Scanner ~ Configuring the One Touch Buttons ~ About the One Touch Properties Window ~ Selecting New Settings for a Button ~ Setting Destination Application Properties ~ Selecting Document and Page Format Options ~ Scanning with Optical Character Recognition (OCR) ~ Renaming a One Touch Button ~ Selecting Options for a Button ~ Creating a New Scan Configuration ~ Editing or Deleting Scan Configurations ~ Configure Before Scan ~ Scan and Burn to a CD ~ Scanning with Event Forwarding ~ Creating an HTML Web Page from Your Scanned Documents ~ Transferring Scanned Documents to Storage ~ Checking the Hardware and Setting the Lamp Power Saving ]
  • Scanning with the TWAIN Interface from PaperPort [ Accessing the TWAIN Interface from PaperPort ~ The Two TWAIN Interface Options ~ Scanning from the TWAIN Basic Interface ~ Scanning from the TWAIN Advanced Interface ~ Adjusting the Image with the Advanced Interface ~ Adjusting the Resolution ~ Adjusting the Brightness and Contrast ~ Adjusting Gamma, Saturation, and Color Hue ~ Adjusting Input Size ~ Creating a New Advanced Interface Profile ~ Display the Device Configuration ~ Setting Up PaperPort to Work with Your Scanner ]
  • Scanning with the WIA Interface [ Fine Tuning Your Scans ]
  • Maintenance [ Clearing Paper Jams ~ Care and Maintenance ~ Cleaning the Scanner Glass ~ Cleaning the Automatic Document Feeder ~ Replacing the ADF Pad Assembly ~ Replacing the Roller Assembly ~ Troubleshooting ~ Error Light Troubleshooting Codes ~ Uninstalling Your Scanner ~ Uninstalling the Scanner and One Touch Software ~ Uninstalling the PaperPort Software ~ To Install Another Driver ~ Xerox DocuMate 510 Scanner Specifications ~ Xerox DocuMate 510 Parts List ]
PLEASE SEE THE COMMENTS ON INSTRUCTIONS TO REINSTALL
Jan 25, 2011 | Xerox DocuMate 510 Document Scanner
I have the message "Unlock scan head" when I turn the screw to the left to unlock it, I get the same message. Is there anything else I should be doing?
If you receive this error even after unlocking the scanhead xerox suggests replacing the scanner assembly. Item Inc offers this part on exchange for much cheaper then xerox. Here's a video to show you how to fix this error/replace the scanner.">
Aug 05, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Can you scan to file on the xerox docucolor 12 with the fiery x12 color server
yes it needs one printer cable and one scanner cable connected between fiery and machine
and scangear software install and remote compputer
Apr 23, 2010 | Xerox DocuColor 12 Color Copier
My scanner error message
Whatever the error message you get, write it down and Google it, you will always find the solution. It has never failed for me. But be carefull some solutions could end up costing you.
Oct 22, 2009 | Office Equipment & Supplies
We have a Xerox M20 Copier/Scanner/Fax/Email which we have always used strictly as a copier. We need to use it as a scanner, to reduce paper in the office and access/share documents electronically. I...
To scan a document to file (Scan to File), the WorkCentre must be directly connected to the workstation using a USB or parallel connection. Scan to File is not supported over an Ethernet connection.
Sep 22, 2008 | Xerox Office Equipment & Supplies
Error code 14-372 after power on
Chain 14 has to do with the scanner not passing self test, not comming to ready.
CCD Module, exposure lamp or one of the scanner baords.
Jan 03, 2008 | Xerox DocuColor 12 Printer
HP LaserJet M1005 Printer Logo
Seeker5211
Seeker5211
