Question about Samsung Clothes Washer Drain Pump Assembly - DC96-01414A
Samsung DC96-01414A Drain Pump impeller
Took pump off and found that the impeller was off the shaft. pushed impeller back on shaft and reassembled and ran it through spin cycle with no clothes and it worked. put a load of clothes in and stopped working again, so i have to assume that impeller came loose again. is there a clip or something that holds impeller in place that may have been washed away or do i have to replace pump?
5 Suggested Answers
SOURCE: samsung silvercare washer stopped working, won't unlock
here is the most common cause for this problem, according to the Samsung repair guy that was here to fix mine today.
On these washing machines it is possible for some debris (in my case it was a small screw from my packet) to make its way passed the drum and into the pump. Once this happens then the impeller of the pump becomes restricted or completely blocked which will result in the above mentione symptoms.
On some machines the pump is on the front, on others at the rear of the machine. In my case it was at the rear, removing the rear panel will allow easy access to it. Have a bucket ready, when the hose is removed from the pump the water will be draining from the machine. 3 bolts and a hose clamp on the inlet and another on the outlet hose. Disconnect the electrical plug from the pump and you can remove it from the machine for cleaning. A very easy job, requiring little skills and not much in terms of tools. (make sure machine is UNPLUGGED from AC outlet)
Remove obstruction(s) from pump and reinstall in reverse order of disassembly. The guy says these pumps are really tough so if you hear it buzzing, trying to go while it's jammed it's a good sign it will work. If not, replacement will be necessary.
Cost me $140. Could have been worse I suppose. Advise: Empty pockets BEFORE washing clothes...
Posted on May 26, 2009
  • 6277 Answers
SOURCE: samsung wf218 washer will not
Try all of this first!
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 01, 2011
kevin_getz
  • 1031 Answers
SOURCE: Washer won't drain
ND means No Drain(ing). First check that the drain hose isn't kinked. Then, check to make sure the drain hose isn't pushed so far down into the standpipe that it is sealed closed. If it is too tight in the standpipe, it will create a siphoning effect. It has to sit freely but securely in the pipe.
Posted on May 31, 2012
david_hanna
  • 58 Answers
SOURCE: Coins end up in the drain pump and take out the
try and check your clothes before putting them into the machine. and ensure all pockets are clear of debri before starting the wash, i dont think there is a screen device or filter hose that you could get to help so my first suggestion is the best one i have, best regards
Posted on Oct 30, 2013
Hurlicon pump is throwing out sand from the water jets back into my pool as I am cleaning. Have tried to clean filter and back washed so many times but its not working.
make this steps and fix it. God bless you
Replace a pump seal:
  1. Turn off the pump motor and close the input and output valves.
  2. Loosen the fasteners that secure the tube connecting the pump and motor.
  3. Move the motor away from the pump housing.
  4. Remove fasteners holding the diffuser to the backplate.
  5. Inspect the diffuser and O-ring for wear, replacing as needed.
  6. As needed, remove fasteners attaching the impeller to the shaft. Alternately, the impeller may be screwed on to the end of the shaft.
  7. Remove the impeller and seal from the shaft.
  8. Inspect and replace the impeller and seal.
  9. Reassemble the pump.
Nov 13, 2013 | Pool & Spa
CLOTHES ARE STILL WET AFTER SPIN CYLCE
It possible something is jamming pump impellor, like a coin or hair pin, or pump itself is seized, or impeller is broken or loose.
Remove front panel, there are two clips in between front panel and top that you have to push in with metal putty blade or thin slot screw driver while pulling front panel away on either then pull up from bottom clips. Shop vac water from machine clamp off hose going from tub to pump.
Lean machine back if poosible so remaining water goes to back of tub, remove hoses, remove wiring to pump.
Unscrew pump from base observe inside ports for objects or broken or seized impeller on shaft if there things in pump remove them reatach wires put machine to drain or cancel and see if pump impellor turns freely, if so reassemble and try, otherwise buy new pump. Not very expensive.
Hope helped.
Jun 24, 2011 | Washing Machines
Bad pump??? Bought used and did a few loads OK but lots of sand/small gravel came out discharge. Fifth load would not drain basket. Error code said drain failure. Went to troubleshoot/diagnose mode and...
Is this a FAV6800A or FAV9800A machine? I would normally ask for clarification but I can’t post a pic with a clarification question. I’m an owner of a FAV6800A.
I assume the error code was “ND”.
Did you open up the pump housing to expose the impeller? Make sure it hasn’t broken loose from the motor shaft and is freewheeling.
Sounds like you have checked the Sump Cap for any clogs and drain hose to drain pump for a clog.
If your machine is not a FAV6800A or FAV9800A then please disregard my solution please don't vote on the solution.
This forum doesn’t require Machine Model Number or Serial Number which is a big mistake.....Rich
Jan 30, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I love my Sharp CV-10MH Portable Air Conditioner but I'm afraid to use it. After a while it starts to make a noise I'd describe as a CLATTER or a RATTLE. Before I use it again I must know that this is not...
I had the same issue of filling up after a couple hours but mine started making some pretty loud noises as well just before shutting itself down and lighting all three lights. The top drain valve would no longer work and the only way I could drain it was through the bottom (gravity) drain valve. I took the unit apart and found that the simple water pump that is used for draining and the evaporating process had lost the thin filter screen on the bottom and the screen became lodged in the impeller of the pump preventing it from spinning. I removed the worn and broken plastic screen, carefully pushed the impeller back up on the shaft until it bottomed out, and cleaned all the built up sediment off the entire pump. After reassembling everything, the ac unit runs like new again and the noise is completely gone. Cost? $0
I imagine you can just order a new pump from sharp and save the time and effort of cleaning the pump.
Hope this helps!
Aug 03, 2009 | Sharp Heating & Cooling
This is a stand alone portable 10,000 sharp portable AC
Hope this helps!
Jul 27, 2009 | Sharp Heating & Cooling
Water pump is leaking on my 2001 Yamaha YZF 426 motorcycle.
First you remove the four 8mm bolt that attach the water pump cover to the side cover, the lowest bolt will drain the coolant. next you remove the coolant pipe with one 8mm bolt. The water pump cover like any part that has been in place for years may need some force to remove and that is why you will find two tabs around the outside of the pump cover for prying it off.
Once you have the cover off the impeller unscrews by way of a built in 10mm nut. This nut is right hand threaded and is removable by rotating it counter clockwise with preferably a 6 point socket as a 12 point socket may round the nut sides since the impeller and built in nut are made of aluminum.
To replace the twin seals (one for water/coolant and one for oil) you must remove the engine side cover from the motor and pull the impeller shaft out from the engine side of the cover. After the shaft has been removed the bearing is pulled out with a bearing puller or sometimes it can be removed by pushing it out from the outside in with a makeshift driver but the bearing can be damaged by this method and it is not recommended. The old seals can now be pulled out or pushed out from the opposite side.
To replace the new seals you must drive them in perpendicular to the impeller shaft with the manufacture markings to the inside. The water seal is installed from the outside and the oils seal from the inside.
There is a tool used for installing the seals called a seal driver but you could make one in a pinch. The seal driver makes contact with the outside diameter of the seal where it is solid and has a metal core. The inside diameter is soft and flexible and should not be used to push the seal in place however it can be used to keep the seal driver centered over the outer diameter and to keep the seal moving in a strait line perpendicular to the impeller shaft.
Once the new seals are in place they should be greased with some lithium soap based grease.
Install the bearing and reassemble the impeller shaft then you are ready to reassemble the engine side cover and water pump housing but make sure you spin the water pump impeller slowly as you install the engine side cover as the impeller shaft is driven off the engine shaft behind it and the shaft needs to be aligned in order for it to fall in place (do not try to force the cover on).
Apr 06, 2009 | 2002 Yamaha YZ 426 F
F2 code
go back to drain pump.. pull pump out ckd the impeller on motor pump shaft there should be a slight resistance when the impeller is turned by hand ..have seen impeller come loose of motor shaft and free wheel
Aug 27, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite
First if you have a wet vac pull the drain hose out of the drain spout and use the vac to pull the water out of the washer through the drain hose.If not you will need a pair of radiator hose clamps from the auto parts store. Pull the screws from the lower panel at the front of the washer and remove it.in side you will see a rubber hose coming down from the tub to the drain pump. Put the radiator hose clamp there if you didn't have a shop vac.On the front of the pump is a round part with a handle turn that and remove the pump filter .Clean any foreign objects out of the pump and look inside the pump to make sure no impeller blades are broken if any are you will have to replace the pump. put the filter back in and tighten it. If you had to use the hose clamp remove it now.reassemble and don't forget to give the tech his four boxes if this fixes it
May 24, 2008 | Kenmore Elite 45986 Front Load Washer
LG WM2032HW spin cycle
I had the same problem. You most likely have a drain pump issue. For me, after getting to the drain pump, I found that the hoses leading into it were clogged with dirt. I cleaned all the hoses, and took off the drain pump itself. The impeller (the little plastic blades inside) had come off the pump shaft. I was able to clean out the impeller and pump housing and it went back on. You'll know it's all the way on because it will click into place and then it won't easilty (if at all) pull back off. After this cleaning, mine worked fine. Hope this helps.
Apr 02, 2008 | Washing Machines
DDW399D Dishwasher
Check and make sure that there is nothing blocking the pump inlet underneath the mesh removable filter. It should be making a whirring sound like it's trying to pull water in in a cycle. If it's not making that noise your pump is shot.
Oct 14, 2007 | Danby 22 in. DDW399 Free-standing...
Samsung Clothes Washer Drain Pump Assembly - DC96-01414A Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
