CV-21-AFC circuit diagram
Service mode
2 Suggested Answers
SOURCE: onida igo 21 1x3 service repair and circuit
power supply is daed
Posted on Feb 14, 2013
Are cv boots replaceable
CV boots are replaceable,but most times it's just as cheap to replace the complete axle.
Jul 10, 2017 | Cars & Trucks
The value of zd442 zener diode which r used in afc circuits of LG flatron crt tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 16, 2015 | LG Televison & Video
Blinking AC button of Honda Civic 2003
HEATING AND AIR CONDITIONING
HONDA CIVIC 2001 - 2005
How to retrieve DTC:
The heater control panel has self-diagnosis function. To run the self-diagnosis function, do the following:
1.Turn the blower fan OFF.
2.Press and hold the recirculation control switch and the rear window defogger switch down.
3.Turn the ignition switch ON (ll).
4.Release both switches. The recirculation indicator and the rear window defogger indicators come on. The recirculation indicator goes off 3 seconds later and the A/C indicator comes on, then the self-diagnosis will begin. About 10 seconds later, the self-diagnosis will finish and the A/C indicator goes off.
- If any trouble is found, the recirculation indicator blinks the diagnostic trouble code (DTC) to indicate a faulty circuit or component.
- If the system is ok, the recirculation indicator stays off.
DTC TROUBLESHOOTING INDEX
DTC (Recirculation indication blinks) Detection Item Page
7An open in the air mix control motor circuit.21 - 16
8A short in the air mix control motor circuit.21 - 16
9A problem in the air mix control linkage, door, or motor.21 - 17
10An open or short in the mode control motor circuit.21 - 18
11A problem in the mode control linkage, doors, or motor.21 -19
12A problem in the blower motor circuit.21 - 20
13A problem in the EEPROM in the heater control panel;
(THE CONTROL PANEL MUST BE REPLACED).21 - 38
14An open in the evaporator temperature sensor circuit.21 - 23
15A short in the evaporator temperature sensor circuit.21 - 24
- In case of multiple problems, the recirculation indicator will indicate only the DTC with the least number of blinks.
- In case of an intermittent failure, the heater control panel will store the DTC until the ignition is turned off.
Mar 17, 2013 | 2003 Honda Civic
I have 2002 Ford Expedition and it is running rough. had diagnostic test done and was given several codes. don't have manual to see what these codes mean. I was given 9 different codes. P0755, 1747,...
For each code there is a diagnostic testing procedure . Without doing the testing we would only be guessing as to the problem . Sounds like you know next to nothing about automobile engine management systems . Your best bet ,take it to a qualified repair shop .
P0443 - EVAP Control System Canister Purge Valve Circuit Malfunction The PCM monitors the state of the EVAP canister purge valve circuit output driver. The test fails when the signal moves outside the minimum or maximum limit for the commanded state.
  • VPWR circuit open
  • EVAP canister purge valve circuit shorted to GND
  • Damaged EVAP canister purge valve
  • EVAP canister purge valve circuit open
  • EVAP canister purge valve circuit shorted to VPWR
  • Damaged PCM
To verify normal function, monitor the EVAP canister purge valve signal PID EVAPPDC (or EVMV for electronic valve) and the signal voltage (PCM control side). With the valve closed, EVAPPDC will indicate 0 percent duty cycle (0 mA for EVMV) and the voltage approximately equal to battery voltage. When the valve is commanded fully open, EVAPPDC will indicate 100 percent duty cycle (1000mA for EVMV) and a voltage drop of 3 volts minimum is normal. Output test mode may be used to switch output ON/OFF to verify function.
P0135 - HO2S Sensor Circuit Malfunction (HO2S-11) During testing the HO2S Heaters are checked for opens/shorts and excessive current draw. The test fails when current draw exceeds a calibrated limit and/or an open or short is detected.
  • Short to VPWR in harness or HO2S.
  • Water in harness connector.
  • Open VPWR circuit.
  • Open GND circuit.
  • Low battery voltage.
  • Corrosion or poor mating terminals and wiring
  • Damaged HO2S heater.
  • Damaged PCM.
  • Wiring.
  • Damaged PCM.
P0155 - HO2S Sensor Circuit Malfunction (HO2S-21) See DTC P0135
P0755 * SSB, wiring, PCM SSB solenoid circuit failure SSB circuit fails to provide voltage drop across solenoid. Circuit open or shorted or PCM driver failure during on-board diagnostic. Incorrect gear selection depending on condition mode and manual lever position. See Solenoid On/Off Chart. Go To Pinpoint Test A .
P1747 * EPC, wiring, PCM EPC solenoid circuit failure, shorted circuit or output driver Voltage through EPC solenoid is checked. An error will be noted if tolerance is exceeded. Short circuit causes minimum EPC pressure (minimum capacity) and limits engine torque (alternate firm). Go To Pinpoint Test D .
P1401 - DPF EGR Sensor Circuit High Voltage Detected The EGR monitor checks the DPF EGR sensor signal to the PCM for high voltage. The test fails when the average voltage to the PCM goes to a voltage greater than the maximum calibrated value.
  • DPF EGR circuit open
  • VREF short to PWR
  • Damaged DPF EGR sensor
  • DPFEGR circuit short to PWR
  • SIG RTN circuit open
  • Damaged PCM
A DPF EGR PID reading greater than 4.5 volts with the key ON and engine OFF or running, indicates a hard fault.
P1451 - EVAP Control System Canister Vent Solenoid Circuit Malfunction Monitors the canister vent (CV) solenoid circuit for an electrical failure. The test fails when the signal moves outside the minimum or maximum allowable calibrated parameters for a specified canister vent duty cycle by PCM command.
  • VPWR circuit open
  • CV solenoid circuit shorted to PWR GND or CHASSIS GND
  • Damaged CV solenoid
  • CV solenoid circuit open
  • CV solenoid circuit shorted to VPWR
  • Damaged PCM
To verify normal function, monitor the EVAP canister vent solenoid signal PID EVAPCV and the signal voltage (PCM control side). With the valve open, EVAPCV will indicate 0 percent duty cycle and the voltage approximately equal to battery voltage. When the valve is commanded fully closed, EVAPCV will indicate 100% duty cycle and a voltage drop of 4 volts minimum is normal. Output test mode may be used to switch output ON/OFF to verify function.
Look's like you have multiple problems an to say what the problem could be would be guessing . Your best bet ,take it to a qualified repair shop .
Oct 17, 2017 | 2001 Ford Expedition
Explorer, 2000; 4.0 EFI: Engine runs fine in neutral & responds well when accelerator is depressed; shift to reverse or drive & engine runs very rough....with no power whatsoever. Scanned...
The EPC solenoid is shorted or the electrical circuit (wiring) or the transistor (driver) inside the computer is fried. do you know how to test a computer controlled circuit ?
How to test computer transistor driver without scan tool
Do you know how to find the circuit in question ?
And you are correct about these two codes as being not related . Do you know what evaporative emission system is ?
Wells EVAP Training with Sgt Tech P0440 P0441 P0442 etc
The Evaporative Emission Control System (EVAP) is used to prevent gasoline vapors from escaping into the atmosphere from the fuel tank and fuel system. The EVAP system usually requires no maintenance, but faults can turn on the Check Engine light and prevent a vehicle from passing an OBD II plug-in emissions test.
EVAP Evaporative Emission Control System - AA1Car.com
http://www.bbbind.com/free_tsb.html you can find free wiring diagrams here . Do you know how to use a wiring diagram ?
  • VPWR circuit open
  • Damaged PCM
To verify normal function, monitor the EVAP canister vent solenoid signal PID EVAPCV and the signal voltage (PCM control side). With the valve open, EVAPCV will indicate 0% duty cycle and the voltage approximately equal to battery voltage. When the valve is commanded fully closed, EVAPCV will indicate 100% duty cycle and a voltage drop of 4 volts minimum is normal. Output test mode may be used to switch output ON/OFF to verify function. This is another electrical circuit problem .
Do you know how to use a DVOM - digital volt ohm meter ?
Do you know that P1747 (electronic press control solenoid short circuit) Is a transmission problem . This solenoid controls the fluid pressure .
May 10, 2017 | Ford Explorer Cars & Trucks
Sharp AR-M237 Error Code H4-21
-H4-21 means:Sub heater lamp abnormally low temperature detection. The setup temperature (about –25°C: Sim 43-1-1) is not reached within the specified time (about 32sec) from turning on the power ON SW. (When the temperature falls below 140°C in the standby mode.)
-Causes:
Sub heater thermistor defect
Sub heater lamp failure
Sub thermostat failure
Control PWB failure
-Check the sub heater lamp blinking with SIM 5-2-2.
When the lamp blinks normally: Check the thermistor and the harness. Check the MCU PWB thermistor input circuit.
When the lamp does not light: Check for disconnection of the heater lamp and thermostat. Check the interlock switch. Check the power PWB and the MCU PWB lamp control circuit.
Clear the display of self-diagnostics with SIM 14.
The H4 errors will not reset by themselves. You must enter service mode to reset this error even if the problem has been repaired. The reset process is outlined below (DO NOT USE ANY OTHER FUNCTIONS IN SERVICE MODE):
Press the following sequence: "#/P" "*" "C" "*"
Type in 1 4
Press start
hit 1 for yes
hit start
Unit should power off and the restart.
If the error code recurrs ther are other problems.
Jun 05, 2008 | Sharp AR-M237 Digital Copier
AKAI MODEL NO - CT2002
press (DISPLY) key on remote handset & S009 button on tv set,simultaneously SERV will be displayed on screen to indicate that tv is now in service mode now you can do what ever you want to do. good luck
Sep 28, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
