Question about Sewing Machines
Error 314 for model TMEF-H915
Problem
Some times we received error-5 in sv500 model please advise a solution
Consult the owner's manual troubleshooting section. Usually there is a list of error codes and possible resolutions.
Otherwise, Search the internet:
Make + Model + the particular error code
Mar 08, 2016 | Sewing Machines
Error message E2 when trying to wind the bobbin
Difficult to assist without the make & model. Usually the troubleshooting section of the owner's manual has a list of error codes and how to resolve them. You can also search the internet listing: Make + Model + Error Code E2
Feb 10, 2016 | Sewing Machines
What is the Singer sewing machine error code E7?
Hello, you didn't say what the model was? But here is a website to see what e7 means and download manual. Error Code E7 Singer 7258 Stylist Support
May 28, 2014 | Singer Sewing Co Machine Model 6199...
My machine give error E-6
hi there
error E-6 means your control box is older than machine model DDL-8700/7. please tell me your control box model and i can help.
best regards
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Jan 08, 2014 | Juki DDL-8700
Error code & solution
HI there
can you please inform us what's model of control box? there is no error named E815 !!!! please we need more explain to help you.
thanks and best regards
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Jan 02, 2014 | Juki DDL-8700
Won't sew! Loads of top thread bundles up around bobbin casing.
First... make sure you are threading it correctly. It MUST be threaded with the foot up.
Do a test seam. Make sure you put the presser foot DOWN when you sew.
Make sure you grasp and hold the bobbin and top threads as you begin the seam. (this is good practice for any seamstress on any machine.
If you still get loops, tighten top tension.
Also check the bobbin case for burrs. drag a finger nail along edges to feel for it catching. If you find one take a small bit of extra fine sand paper and file it off.
Good luck
Nov 12, 2012 | Sewing Machines
Some times Error-2 & some times error-4.Our model is JUKI8500-7.Control box model is SV500 series. Pls advice the soluations. Regards, Kailash kailash.mehala@yahoo.com
hi there
1- your control box model is SC-500 not SV500, juki didn't made sv never ever
2- there is no error 2 just error 3 and error 4 both means there's problem with synchronizer which installed behaind handwheel first try to clean it by dray spray maby there's some oil or dust arround it. if error still coming change the senchronyzer with new one
best regards
ashraf abozid
aabozid@hotmail.com
Sep 03, 2010 | Juki DDL-8700
Janome 314. Multiple loops on underside of material. Why?? How to correct??
not enough tension on your needle thread is the most common cause of this problem. rethread and make sure there is sufficient tension on the needle thread.
Aug 30, 2009 | Janome Sewing Machines
Sewing Machines Logo
62 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
