Question about Hayward H Series Induced Draft Abg 100,000 Heater
Hayward heater not working
I have a Hayward H100ID Spa Heater. The blower motor turns on when thermostst is on and I hear igniter sparking. I also hear the solinoid on the gas valve click but there are 2 of them so I don't know if the valve is opening to let the gas thru. I have this temporarily hooked up to a 20 lb propane tank until I can get it connected to a larger tank. I don't know if this would stop it from liting the burner.
    President:
  • Hayward Master
  • 1,378 Answers
You'll never get enough gas from a 20 pound tank. Even 100# tanks struggle to evaporate enough gas to keep up with that heater.
In the mean time, what is the output pressure on your regulator?
Posted on Jun 15, 2009
Pool Heater. Hayward H100ID Starts fine and heats for about 5 minutes. Then heat stops. You can feel the blower its just cold air.
It sounds like your pool heater is not firing. I would check several things: the burner might be blocked and clogged, the gas valve might need to be replaced, the direct spark module might be malfunctioning, or the combustion blower might be cleaned. One of these is probably the issue. A service man can repair all of these problems.
Aug 08, 2010 | Hayward 100kbtu Pool Or Spa Propane Gas...
Hayward Heater Problem ''AO'' error. H400IDH
Thank you for posting your question here on Fixya.com.
It sounds as if the air activated switch the tube you mention attaches to is not working. Pull the two wires from it and connect them to simulate the switch closing. Start up the heater to see if you get ignition. If so, replace the switch.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Feb 14, 2010 | Hayward H Series Pool & Spa Heater 400k...
Hayward h100ID ignitor not starting - I turn on the heater after the winter and hear the fan but no ignition
There are many different things it could be with the fan comming on that means the heater is trying to fire. Make sure gas supply is on first of all. Depending on the gas line run you may have to try several times of turning on and off the heater to reprome the line. If no luck with that the next step is the igniter follow the small tube comming off the gas valve and folliw it to the burner tray try poking a small peice of wire through it from a wire brush it probally is plugged. Heater should fire after that.
Jun 25, 2009 | Hayward H Series Induced Draft Abg 100,000...
Igniter not working when heater is turned on
Air pressure sensor on the blower blocked or damaged and not reading the fan is on. Control board not sending spark down to the ignitor. Check the short grey tube off the blower first. If clearing it works, great. If not, you'll likely need a warranty service call. http://www.haywardnet.com/locator/
Jun 05, 2009 | Hayward H Series Induced Draft Abg 100,000...
Hayward Spa Heater H100ID blower will not stay on.
I had a similar problem and it turned out to be the solder connections on the control module. The connector that is soldered to this board (comes from the gas valve) needed to be re-soldered.
May 30, 2009 | Hayward H Series Induced Draft Abg 100,000...
Hayward H Series Induced Draft Abg 100,000 Heater Logo
573 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
