Question about Proscan 26LB30QD 26 in. LCD HDTV
How to turn off CC. Button says no info
How to turn off CC. Button says no info available.
  • nocm Jun 15, 2009
    Crikett,
    Tried it. Doesn't work!
    President:
  • Proscan Master
  • 1,779 Answers
Go into your menu under Audio, it should be there, navigate to turn it off.
Posted on Jun 15, 2009
  • Jim Krause Jun 15, 2009
    What type of signal are you using for reception. The display of No Info doesn't make sense.
How to turn close caption off
Try this.....when you press the CC button once, it shows you the current CC mode and status. If you press it again while the box is still showing, it will step to the next available CC display mode. Just press it again until the mode shown is "Off".
Aug 05, 2015 | Sharp Televison & Video
Can I turn the caption mode off with the remote?
CC (Closed Caption)
To select the options in the CC sub-menu, press the MENU button or the #
button. A new menu will be displayed showing the following CC settings:
CC
The CC feature is available when watching regular analog (NTSC) TV.
Select from CC1, CC2, CC3 or CC4. Closed Caption for regular TV is
usually CC1 or CC2.
Digital CC Style
The Digital CC Style feature is available when watching digital TV.
Select either As Broadcaster or Custom. If Custom is selected then
you can customize the way Closed Caption is displayed.
Feb 14, 2015 | Vizio VF550M 55 in. LCD HDTV
I keep gettting 'no CC info available' when I I hit the CC button on Proscan(26LB30QD) remote while watching cable. Cable box (DVR) is a Motorola DCX3400 and is provided by Comcast. I can do it from the...
You will not be able to get closed captioning by pressing the cc button on your television remote control. You must turn off the motorola cable box. Yes I did say turn off the motorola cable box. You should be standing in front of the cable box when you turn it off because as soon as it is turned off you must press the menu button on the cable box (not on the remote but on the cable box) right away. If you press menu soon enough after turning it off you will get a hidden menu. You will be able to scroll down to Closed Captioning and choose enable with the left or right arrow. Then just turn the cable box back on and you should have captions.
Dec 30, 2010 | Proscan 26LB30QD 26 in. LCD HDTV
2008 Samsung 32" Flatscreen 720p Channels are
The cc has been enabled on your cable box. Usually there is a hidden menu accessed by turning off the cable box. Yes I did say turning off the cable box first. Then immediately pressing the menu button on the front of the cable box. The hidden menu should pop up and one of the menu options will be closed captioning,. Disable it.
Nov 09, 2010 | Samsung LN32A540 32 in. LCD HDTV
Closed caption
CC (Closed Caption)
Press the down button to highlight the CC (Closed Caption) selection.
Press the > button. A separate menu will appear with the following CC
settings
CC
When watching regular analog (NTSC) TV, the CC feature is available in the
Setup menu.
Press the down button to highlight the CC selection.
Press the > button to select CC1, CC2, CC3 or CC4.
Once the adjustments are completed press the LAST button repeatedly to exit
the OSD completely.
Closed Caption for regular TV is usually CC1 or CC2.
Mar 02, 2010 | Vizio VO42L 42 in. LCD TV
Turning off Closed Caption
Are you using a cable/satellite box or just basic cable service?
When you go to the menu what options become available to you?
If the following options are present-
smartlock
setup
cc
If not try to press both the volume buttons on the front of the TV at the same time and see if the above options become available.
If so use the channel down button on the front of the tv to scroll to "cc"
Once CC is highlighted use the volume + button until it says CC off.
If these menu options don't become available please reply what options are shown.
Good Luck.
Jan 05, 2010 | Philips Magnavox 20MS233S 20" TV
Cannot turn off Closed Caption
Here's the copy on CC from my manual LC-32SB23U.
1. Press CC.
This will present the Closed Caption information display.
2. Press CC while the Closed Caption information is
still on the screen.
Press repeatedly until you select the desired closed
caption service.
INFO BOX ON THE SCREEN,
Air ANALOG
Audio : MONO
CC : 1/2 CC1 ------ Closed Caption information
Ratings : NONE
Example:
If a program has three services (Digital CC(ENG), CC1
and Text1), the closed caption display will toggle in this
sequence:
1/3 ENG -- 2/3 CC1 --- 3/3 Text1 -- Off
The CC button keeps a record of the last service
selected in its memory.
If the last closed caption mode (e.g. 1/3ENG) you
selected is not available for the next program, or on
another channel, the closed caption service that is
available is automatically selected, and this service
appears in parentheses, e.g. “1/3(CC1)”.
Closed Caption services that appear in parentheses will
not be stored in the CC button's memory as your last
selected service. Only services that you have selected
with the CC button are stored.
If this doesn't work, the TV may need a software upgrade.
I can get you a copy of my manual LC-32SB23U for you. But, are you sure there is and "A" in the middle of your model number?
Jun 02, 2009 | Sharp LC-32SB23U 32 in. LCD TV
Proscan 26LB30QD 26 in. LCD HDTV Logo
52 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
