Question about Toshiba E-Studio 232 Copier, 232 Digital Copier
How to reboot toshiba e-studio 232
Error code c 430
  • 653 Answers
SOURCE: Toshiba e-Studio 232 is showing error message CF60
CF60 indicates Recycle Toner Transport area lock. U need to take out the process unit, remove developer unit, remove drum, drum blade & recovery blade, disposed all waste toner, make sure the gear can turn properly. Then reassembly back everything.
Posted on Jun 10, 2009
  • 653 Answers
SOURCE: studio 232 has c430 code. what does tha code mean,
The C410/440/450 are all related to fuser unit. Normally is caused by thermistor. The fastest way is to enter 08 mode, key in "400", set the value to "0". Then restart MFP, this can reset the code. But if occur again, it is recommend to check the thermistor, which can be dirty or failure.
Posted on Jan 12, 2010
  • 3 Answers
SOURCE: toshiba e-studio 232 says c440 code
This problem is caused by the thermister in the fuser section. To reset shut macine off, then turn it on while holding down the 0 and the 8 key down for more than ten seconds then release. This is service program mode, now press 4 then 0 then 0 and then the start key, you will see a nuber in the screen, press 0 then start key this should reset that code if not the thermisters need to be replaced
Posted on Apr 11, 2010
SOURCE: unable to access scan folder
Connect to copier/scanner using web browser. Click Administration tab, and logon use the copier's username/password. Click Network Click SMB Session Click SMB Session box In section called "SMB Signing of SMB Server", the default of "If client agrees, digital signature is done for communication" needs to be changed to "Digital signature isn't done for communication for the server" Click Set button at top, then Save button, and the copier will reset.
Posted on Dec 09, 2010
  • 132 Answers
SOURCE: Toshiba e studio 232 is showing misfeed and
check the registration sensor for broken or dirty the registration sensor is on the transfer and seperation cover
Posted on Mar 15, 2011
How to solve error code e010 on toshiba 232
Paper not reaching/pass exit sensor, check the exit sensor and actuator (easily break)
Jan 03, 2014 | Toshiba e-Studio 232 Black and White...
Error code ca20
toshiba estudio 232 errr ca20 wt problems?
May 25, 2013 | Toshiba e-Studio 232 Black and White...
Resetting error code c970 on toshiba e-studio
Karuna wire break
OR
its side charger problem clean it
OR
replace it
Mar 19, 2013 | Toshiba e-Studio 232 Black and White...
Error codes and their meaning for Toshiba e-studio 181 copier
toshiba e-studio 181 is not working. It shows that cover is open symbol and tells the same and the printer is woken up. what to do to rectify it.pls
Apr 27, 2012 | Toshiba e-Studio 232 Black and White...
The toshiba e 232 has a code c430 that is not on the books. what is the problem. how to resolve it
This is a fuser thermistor abnormality. You can try going into (08) mode by holding 0 and 8 while turning on the copier. Once the copier starts up key in 400 and press start, input "0" and press interrupt. Try rebooting the copier, if this doesn't clear that call for service then you are going to need to get work done on your fuser.
Feb 08, 2010 | Toshiba e-Studio 232 Black and White...
Error F120
Hello sir; The error code you display F-120 it means "data base" problem it can not be reset you have to replace either memory chip or hard drive.
Jun 02, 2009 | Toshiba e-Studio 232 Black and White...
How to reboot my toshiba E-Studio 232 black and white copier? Where do I get its bootable CD in India ?
if u want to reboot hard **** just go to 08 mode .then press 690 press start .2 is normall format .shut power off when reboot machine appears .
Dec 12, 2008 | Toshiba e-Studio 232 Black and White...
F120 fault on Toshiba estudio 232
HOW TO RESET ERROR CODE F-120 IN TOSHIBA STUDIO 232
Jul 09, 2008 | Toshiba e-Studio 232 Black and White...
Toshiba E-Studio 232 Copier, 232 Digital Copier Logo
20 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
