Question about Seagate Computers & Internet
Need to change ST3160215AS pcb
Need to change hdd pcb
    Top Expert:
  • Seagate Master
  • 75,424 Answers
It will be best to buy an other HDD, rather than trying to replace the PCB. Gopakumar Gopalan Google
Posted on Mar 28, 2014
E602-0001 Canon ir 3300 reply me sir
A mounting fault of the HDD is detected when the HDD is started up from the BOOT ROM
HDD, Main controller PCB Try replacing the HDD, and download the system software. Is the problem corrected? YES: End. NO: Replace the main controller PCB.
Jan 16, 2018 | Canon Office Equipment & Supplies
How to Change the HDD for konica Minolta c352
Go here to download the service manual
Service Manual free download schematics datasheets eeprom bins pcb repair...
Please note you need to have a backup for the HDD prior to replacement.
Aug 13, 2016 | Konica Minolta Bizhub C352 Color...
Error 602.00003
A data read fault of the HDD is detected when the HDD is started up from the BOOT ROM Causes The wiring is faulty (short circuit, open circuit). The HDD is faulty. The main controller PCB is faulty. Remedy 1. Wiring Are the connection and the cable between connector J1025 of the main controller PCB and the connector J2005 of the HDD normal? NO: Correct the connector/cable. 2. System software Try re-installing the system software. Is the problem corrected? YES: End. 3. HDD, Main controller PCB Try replacing the HDD, and download the system software. Is the problem corrected? YES: End. NO: Replace the main controller PCB.
Dec 03, 2014 | Canon Office Equipment & Supplies
Faulty circuit board of clickfree hard drive hd325. Where to find the board. Pls! Help!
This is en external HDD. This means, there's a HDD inside the package, and a small PCB (print with tiny ICs on it). If you're lucky, the PCB is defective, while the HDD is OK. In that case, you only need to look for another USB Harddisk enclosure for a 2.5 inch SATA harddisk. Maybe your local computer-store sell these casings, otherwise check internet (eBay for example)
To be sure it's either the HDD or the PCB, just open up the casing and remove the HDD. Insert this HDD into a PC, connecting it to the motherbord over a SATA-cable (and don't forget to use a powercable too).
If the HDD becomes visible under Windows or whateven operating System you use, than it's indeed the PCB, which is defective. If the HDD is not visible, maybe the HDD is defective. In such case, you can find at internet a new(er) HDD of identical make (brand / type HDD)
Oct 18, 2013 | ClickFree HD325 320 GB USB Hard Drive
Recover data from seagate barracuda 7200.10
External hard drive case, which comes with its own PSU AC/DC power pack.
They come in IDE and SATA flavours, some with extra cables to convert IDE<>SATA.
Take HDD with to computer retailer so physical dimension can be matched.
Sep 07, 2012 | Seagate Barracuda 7200.10 ST3160215AS -...
Hi,last week my HDD does not detect in BIOS and I open HDD cover and look insite the inner parts.then I close the cover and setup in my motherboard. But my HDD can't run normally.I heard such a sound...
As friendly advise...your HDD is on its way out. What you will need to do at this moment is try to recover and transfer your data to a new HDD if possible. PM me if you want my service (I can recover and transfer your data). It will not cost you much. I got an affordable service. My PM is dicxs_lpt2 at yahoo.com I will be happy to help you.
Mar 24, 2011 | Seagate 25PK 160GB ST3160215AS SATA 7200...
ERROR CODE E602-0003 What is this?
E602
1) Are the connection and the cable of the connector (J1017) on the main controller PCB and the connector (J1551) on the hard disk drive normal? NO: Correct the cable connection.Hard disk drive (HDD), Main controller PCB
2) Try replacing the hard disk drive and downloading the system software.Is the problem corrected?
3) HDD unit.
Remove the rear upper cover and the reader rear cover. Remove the three screws, and detach the cover, Remove the two screws and disconnect the two connectors then, remove the HDD unit. Remove the six screws and detach the HDD When mounting the HDD unit,be sure that the flat cable is under the plastic sheet of the HDD upper case.
Solution 1# :
It can be a Sector Problem ,to resolve it just press 1&9 keys at the same time the machine started the HD Diagonose and it repared the sector error without replacing the HDD .
Solution 2# :
try to go in to disc check service mode to clear the sectors ,this should work if it doesnt you will need to replace the hard drive .
Solution 3# :
Try HD clear & then HD check for every sector in service mode. Then try to upgrade system software;If nothing works change hard disk ,format & install system software. Posted by Kuyung at 5:50 AM icon18_edit_allbkg.gif Labels: error code 602-0003 IR5000, error code 602-0003 IR6000
May 07, 2010 | Canon imageRUNNER 5000 Copier
Computers & Internet Logo
26 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
