Question about Seagate Computers & Internet
Pcb change of ST3160215Aa
Need to change pcb of hdd
  • Seagate Master
  • 3,320 Answers
Go to ebay and find a drive
Posted on Mar 28, 2014
How to Change the HDD for konica Minolta c352
Go here to download the service manual
Service Manual free download schematics datasheets eeprom bins pcb repair...
Please note you need to have a backup for the HDD prior to replacement.
Aug 13, 2016 | Konica Minolta Bizhub C352 Color...
Error 602.00003
A data read fault of the HDD is detected when the HDD is started up from the BOOT ROM Causes The wiring is faulty (short circuit, open circuit). The HDD is faulty. The main controller PCB is faulty. Remedy 1. Wiring Are the connection and the cable between connector J1025 of the main controller PCB and the connector J2005 of the HDD normal? NO: Correct the connector/cable. 2. System software Try re-installing the system software. Is the problem corrected? YES: End. 3. HDD, Main controller PCB Try replacing the HDD, and download the system software. Is the problem corrected? YES: End. NO: Replace the main controller PCB.
Dec 03, 2014 | Canon Office Equipment & Supplies
Error code e000602
Mounting fault of the HDD.Viring faulty.The main controller PCB faulty.Wiring between connector J1025 of the main controller PCB and the connectorJ 2005 of HDD,or try reinstall the system software,or try to replace HDD and download the system software,or replace the main controller PCB...
Sep 25, 2014 | Canon gpr-6 ir 2200/2800 drum...
Need to change ST3160215AS pcb
It will be best to buy an other HDD, rather than trying to replace the PCB. Gopakumar Gopalan Google
Mar 28, 2014 | Seagate Computers & Internet
Faulty circuit board of clickfree hard drive hd325. Where to find the board. Pls! Help!
This is en external HDD. This means, there's a HDD inside the package, and a small PCB (print with tiny ICs on it). If you're lucky, the PCB is defective, while the HDD is OK. In that case, you only need to look for another USB Harddisk enclosure for a 2.5 inch SATA harddisk. Maybe your local computer-store sell these casings, otherwise check internet (eBay for example)
To be sure it's either the HDD or the PCB, just open up the casing and remove the HDD. Insert this HDD into a PC, connecting it to the motherbord over a SATA-cable (and don't forget to use a powercable too).
If the HDD becomes visible under Windows or whateven operating System you use, than it's indeed the PCB, which is defective. If the HDD is not visible, maybe the HDD is defective. In such case, you can find at internet a new(er) HDD of identical make (brand / type HDD)
Oct 18, 2013 | ClickFree HD325 320 GB USB Hard Drive
I have this canon copier but having a problem. it only bootup 1/4 and it hang with a waiting sign. i know it the monetery pcb . is there a solution to repair this pcb .
There is no monetery pcb in a canon copier. If the model is a larger one the boot comes from the HDD. It could be a bad HDD or bad sist
um software
Dec 27, 2010 | Canon Office Equipment & Supplies
ERROR CODE E602-0003 What is this?
E602
1) Are the connection and the cable of the connector (J1017) on the main controller PCB and the connector (J1551) on the hard disk drive normal? NO: Correct the cable connection.Hard disk drive (HDD), Main controller PCB
2) Try replacing the hard disk drive and downloading the system software.Is the problem corrected?
3) HDD unit.
Remove the rear upper cover and the reader rear cover. Remove the three screws, and detach the cover, Remove the two screws and disconnect the two connectors then, remove the HDD unit. Remove the six screws and detach the HDD When mounting the HDD unit,be sure that the flat cable is under the plastic sheet of the HDD upper case.
Solution 1# :
It can be a Sector Problem ,to resolve it just press 1&9 keys at the same time the machine started the HD Diagonose and it repared the sector error without replacing the HDD .
Solution 2# :
try to go in to disc check service mode to clear the sectors ,this should work if it doesnt you will need to replace the hard drive .
Solution 3# :
Try HD clear & then HD check for every sector in service mode. Then try to upgrade system software;If nothing works change hard disk ,format & install system software. Posted by Kuyung at 5:50 AM icon18_edit_allbkg.gif Labels: error code 602-0003 IR5000, error code 602-0003 IR6000
May 07, 2010 | Canon imageRUNNER 5000 Copier
Western Digital Hard Drive AAK5000
Your HDD motor or PCB (on the HDD) blew
IF it is the PCB, you can jot down the numbers on the connector (look for this pattern: xxxx-xxxxxx-xxx-xx) and googlee for it. If you are lucky, someone selling a WD Caviar Blue WD5000AAKB - hard drive - 500 GB - ATA-100 will look at their PCB and see if the revisions match. BUY the HDD!!
You now have a 50/50 chance to get the HDD working again.....
IF the motor blew, you WILL hose the new board, and end up with 2 bad drives
IF the PCB blew, it might just surprise you and work. I have used this trick to recover data for $$$ on 8,20,60,80,160,200,and 250 WD drives that were out of warranty. Good Luck
The other option is IF the motor went bad, and you will certainly know if you see burned chips on the back of the PCB or hear a loud POP when you try the new one... You only have 3 choices.
1. Send the HDD off to a Data Recovery $ervice (No guarantee here)
2. Send it to WD for a warantee replacement (and forever lose your data)
3. Take off the HDD cover, bridge the Positioner, DO NOT TOUCH anything in there and Manually spin the HDD Platter spindle to EXACTLY 3500 or 7200rpm (depending on drive) with a tiny speed-controlled motor and a tachometer, then plug it into ext USB bridge and your PC and if the motor drive is the ONLY thing bad, the speed sense will engage, and the heads will load and you will have ~20min-2hr before the HDD dies due to contamination of the heads and platters(dust, smoke, pet hair,, human skin flakes, moisture and oxygen) so grab the essential files quick! I recommend Total Commander (Hilight all you NEED (not want - there isnt time) and drag to copy. PRACTICE TC on a good HDD. If you miss a file or folder, you will have to cancel and redo, or wait until all others highlighted are done first. Make a list - stick to it.
I have done this 5-6x so far. Several old Seagate and Maxtor 80Gb and for the larger, I Built a mini clean room, complete with forced filtered heat (hairdryer pulling its air thru a HEPA filter. for motor, I Used an expensive German variable speed dremel-like tool and cheap tach from Harbor Freight.
Good Luck!
Jan 15, 2009 | Western Digital Computers & Internet
Iomega hard drive 500gb not working
Ext USB?, Internal HDD?
Is it making any noise at all? Clicking, Whirring, etc?
If it is USB, then it is most likely hosed (or the USB enclosure is) and what I would do is go out, spend $20 at Microcenter and buy a new one - that can handle 500Gb HDD ;-)
If internal... well that is a whole nother mess.
IF it is the PCB, you can jot down the numbers on the connector and googlee for it.
If you are lucky, someone selling an identical model will look at their PCB and see if the revisions match. BUY the HDD!!
IF the PCB blew, it might just surprise you and work. I have used this trick to recover data for $$$ on all types and sizes of drives that were out of warranty. Good Luck
2. Send it to MFG for a warantee replacement (and forever lose your data)
3. Take off the HDD cover, bridge the Positioner, DO NOT TOUCH anything in there and Manually spin the HDD Platter spindle to EXACTLY 3500 or 7200rpm (depending on drive) with a tiny speed-controlled motor and a tachometer, then plug it into ext USB bridge and your PC.
IF the motor drive is the ONLY thing bad, the speed sense will engage, and the heads will load and you will have ~20min-2hr before the HDD dies due to contamination of the heads and platters(dust, smoke, pet hair,, human skin flakes, moisture and oxygen) so grab the essential files quick!
I have done this 5-6x so far. Several old Seagate and Maxtor 80Gb and for the larger ones, I Built a mini clean room, complete with forced filtered heat (hairdryer pulling its air thru a HEPA filter. For motor, I Used an expensive German variable speed dremel-like tool and cheap tach from Harbor Freight.
Good Luck!
Nov 28, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Computers & Internet Logo
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
