Question about Pride Go-Go Ultra X 3-Wheel Travel Scooter
Scooter beeps and won't go. Gear doesn't click into "engaged" mode sometimes. It seems to slip between "engaged" and "freewheel".
Sometimes it works, sometimes it just beeps.
  • Debbie Sommers
    Debbie Sommers Mar 28, 2014
    Sometimes it works - sometimes it just beeps and won't go.
  • Mark Brown
    Mark Brown Mar 28, 2014
    it sounds like you have a faulty break lever (the lever starts or stops the current from getting to the breaks) or more lightly a loose connection, check all the connectors are firm, hold them in place and turn on for each one, with luck you will find a loose connector and some insulating tape will sort it out, or maybe a new connector fitted. Hope that helps. Mark.
    Scholar:
  • 128 Answers
Sounds to me like the starter solenoid that's what I would replce first , then look towards new battery's if that fails .
Posted on Mar 28, 2014
Wont move 5 beeps and freewheel lever is properly engaged
hi Cornelius,
Check the micro switch located on the brake, if that working okay as sometimes they stick... if the controller can't see the brake resistance it will bleep five times...
then check the connections from the axle to the frame , four connectors , tow for the motor and two for the brake.
Feel free to call me if you're located in the UK
Regards
Rob..
Dec 03, 2015 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Go Go scooter wont engage gears
Try first without power to switch from freewheel to engaged. Its usually a small lever on the back by the wheels. If the scooter can be moved by hand its in freewheel. Switch the lever then move the scooter slightly til you hear it click in. They don't have brakes, They are supposed to live in gear and then are either moving or not. :) Hope this helps.
Oct 16, 2013 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
I have a go go elite traveller plus , the battery pack will not lift off my scooter it seems to be stuck , i need to replace the batteries
The manual for this scooter is at http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdf
The closest info I can find is page 14. MOVING AND TRANSPORTING YOUR Easy Travel Elite
6.1. Moving Your Easy Travel Elite in Freewheel Mode when unfolded:
The Freewheel switch (Fig. 1/17) is used for releasing the brake and moving the Easy Travel Elite without operating the motor. Before activating, make sure your Easy Travel Elite is switched on. Turn Freewheel switch to the "freewheel" position and push or pull the Easy Travel Elite manually.
NOTE: The Freewheel mode can only be activated after the battery is in place and the power switch (Fig.9/1) is turned on. Doing otherwise will cause a fault situation indicated by rapid flashing of the Indicator light (Fig. 9/4). See section 4.2.
WARNING: The Freewheel switch should never be engaged on a slope.
CAUTION: The seat back must remain in the upright position.
They seem to assume removal is obvious, I would check any connections from battery to scooter are pulled out and that freewheel mode is not engaged.
Oct 07, 2013 | Pride Mobility Products Go-Go Elite...
Mobility scooter
Check the freewheel lever is not engaged.
Jun 03, 2017 | Health & Beauty
My scooter battery won't stop beeping
hi, that's sounds like the freewheel lever is engaged, please make sure it out of freewheel mode, now remove the rear axle then refit, does it still make that noise ?
Yes, okay now check the connection from the rear axle to the frame, make sure they are clean and a good connection,
Regards
www.gewizrepairs.co.uk
Dec 27, 2012 | Sunrise Medical Guardian Trek 4
My scooter won't move! i turn the key, plenty of battery power, all lights, horn etc working but will not move forwards or backwards, when i pull the controls all i get is a beep. any thoughts?
Either your parking brake is engaged or if your scooter is more like mine i have a Rascal 600t it gives a code 5 service code when it thinks its in free wheel. Your scooter is dropping into a fail safe mode and is telling you this by beeping. Most scooters have a service light on the tiller head that will flash out the failure code of the failure detected. Does your beep a number of times pause then beep this same pattern. The freewheel mechanism is located on the trans-axle which if you go outside across grass it gets wet. This device doesn't like moister and will get stiff will partially engage or disengage. In that mechanism there is a micro-switch which if the lever when slipped into the engaged position doesn't go all the way to the seated position the switch will see the mechanism as being disengaged [in free wheel] and will inhibit the motor from running. I lubricate the entire assembly with pure silicon spray oil,WARNING, do not use WD-40, It will eat some plastics.After lubricating the lever should move smoothly. I have to lub my scooter about once a month in the winter.
Now if this doesn't work check the connector that are all the wires are connected. Disconnect the connector check the pins are ok reconnect check to see if your still getting the failure. If you are still getting this problem do continuity checks on the wiring. You will need a multimeter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8 Check the switch in the freewheel assembly. Select ohms the highest scale, short the leads together, zero the meter by turning the zero adjust knob. There is only one wire we are interested in. On some scooters you can visually see the switch and the wire running from it. The wire usually foes to a spade connector. Disconnect the spade connector put a probe on that connector leading to the switch. Disconnect the battery put other probe on the positive side of the terminals that were connected to the battery not to the battery it side.Work the switch does the meter needle deflect to zero, no, try the negative side. Does the meter deflect, no, put the probes directly on the switch terminals, does the switch.when worked now cause the meter to deflect, no, replace switch, yes, the problem is in the harness, don't panic, use can use that meter to trace the wire through the harness. Wiggling wires and flexing connectors usually makes the meter flick at some point. Thats how i do it i'm never without my trusty meter. Rascal are notorious for having problems of this type my mid-frame harness fell apart in the middle of a six lane intersection, the scooter simply locks up tight .I can do nothing but sit in the middle of this huge intersection. People try to move me but the scooters wheels are locked, my illness makes it so i can't communicate with people do it was a mess. So i modified the connector so its no longer a latch type connector. I drilled it for a quick pin which is much stronger than what its using now. Hope this helps
Jul 28, 2012 | Shoprider Sprinter Xl3 Deluxe 778XLSBN
95 eagle vision esi slips out of gear at stops
there is a limp mode but I doubt if that is the problem
It indicates that the torque converter clutch servo/solenoid is faulty
run the fault codes to confirm if that is it or a faulty TCM
check wiring around the transmission
Apr 19, 2017 | 1995 Eagle Vision
I have just purchased a new Little Gem2 mobility scooter which appears to work fine until I sit on the seat ,then there is a series of beeps followed by 5 single beeps.Can you please help
Make sure that the scooter is not in freewheel (the freewheel lever at the rear of the chair needs to be in drive position) If you can push the scooter easily then its in freewheel mode If you have the owners manual check to see if they have the beeps codes listed and look for the code you aare getting if you don't have the manual try the manufacturers website to download one Hope this helps
Apr 09, 2011 | Health & Beauty
We have a Fortress Scientific 2000 electric scooter that hasn't been used for several years. We put in new batteries, it shows fully charged, comes on and has a steady beep, but won't go forward or...
Your break release shifter is in the push the scooter mode. Put it back in gear and the horn doesn' beep and it should run..
The horn beeping is the alarm to tell you the break release is on.
It is usually located under the seat on the body of the top of the battery housing. Looks like a stick with a ball on it.
Oct 03, 2010 | Electric Mobility Mobility Electric Power...
Pride Go-Go Ultra X 3-Wheel Travel Scooter Logo
125 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
