Open toshiba satellite a110195
How to open the keyboard
3 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: Replace keyboard on Toshiba Satellite 1410-s173
First remove the AC adapter (Charger) if plugged in. Then remove the battery.
Next step is removing the Keypad Securing Strip. This is a plastic cover right Above the keypad, and below the LCD screen. Looking at it, you'll notice on the Left and Right sides of it, that it has a U-shape.
This U-shape covers the LCD screen hinges.
Take a small flat tip jewelers screwdriver, and come from the right side of this plastic strip. You will see a thin parting line, where this plastic strip meets the laptop body. Your flat tip goes in this parting line. You have to use finesse. It's doubtful you'll break the plastic strip, as it's REAL tough! But if you slip, you could scratch the plastic. (Actually, it's pretty hard to scratch that plastic! Just thought I would caution you. The plastic strip is made of a spaceage plastic. Pretty tough stuff!)
The plastic strip has tabs around the edges, every so often. These
plastic tabs snap into place, and hold the Keypad Securing Strip on. When you begin, it's a little tough to get that flat tip down in there. (Remember ->Jewelers screwdriver!)
Plus, you may be at one of the points that there is a tab. Usually there is a 'dimpled' flat place, that looks like a flat tip should go there.
With the flat tip jewelers screwdriver inserted a little, ease back on the screwdriver, and lift the plastic strip up.
It will look like it's bending. If you have another flat tip Jewelers screwdriver, or a small butterknife, you can insert it, and hold this part up. Then take the other flat tip, move over a little, and start lifting up.
Once this Keypad Securing Strip starts coming up, it will come to one of those tabs, and the tab will come up and out. You'll hear a POP, and think you broke it! You didn't.
Go along the edge, and keep popping this strip up. Use caution, as to how far you insert that flat tip screwdriver!
There are tiny little wires under there, and you don't want to pinch one, or tear it loose. Keep the flat tip, about a half a fingernail length in, and you won't.
Once you get towards the other side enough, the strip will let loose, and come up.
Without disconnecting the wires, see if you can lay the strip towards the back, and lay it out of the way. Towards the LCD screen. You are trying to get to the screws, that secure the keypad. They will be in a metal strip for the keypad, and towards the LCD screen.
I can't remember at this point if there are two, three, or four screws. You'll be able to see, and you'll know.
(Use Caution! You can easily drop these screws! They might go right into the body of the laptop. You MAY be lucky enough, to pick the laptop up, turn it over, and gently shake the laptop, to have them fall on the table. You MAY not be so lucky, and have to disassemble the entire laptop, to get to them!)
IF, the Keypad Securing Strip will not lay out of the way, so that you can get to the keypad screws, you'll have to remove it.
It isn't tough, but it looks daunting the first time.
You will see small White connectors in the middle of the cables.
Two wire cables, if memory serves. These connectors are small White rectangular blocks. There is a Female and a Male. You just take your fingernails, and ease the connectors apart.
Don't worry about how they go back together. They are different sizes. You just match up the size.
Now with the keypad securing screws removed, ease the keypad forward a little, and bring the front of it up to a tilted position. (Towards the LCD screen is the front of the keypad) You don't want to bring it straight up, as there is a flat ribbon cable you need to disconnect. The flat ribbon cable attaches at the back of the keypad. (Towards you) It has a White connector.
This connector is different, from the ones you have disconnected already. The connector itself has a locking 'bar'.
This thin rectangular piece of plastic, goes across the length of the connector.
It is positioned at the front of the connector. It comes forward, towards the flat ribbon cable end, that is connected to the keypad.
It slides. It only slides so far, then stops. It is at this point, that you remove the flat ribbon cable itself. The one towards the keypad. There will be No connector on that flat ribbon cable. It will be just the ribbon cable itself.
When you reattach it, you just slide the flat ribbon cable back into the White connector. Then you ease that locking bar back into position. The position that it started from.
Now reverse your steps.
Posted on Apr 18, 2009
  • 174 Answers
SOURCE: Toshiba Satellite som of the keyboard is not
Either the ribbon wire from the keyboard to the mainboard has come loose, or the keyboard is going bad. Or if you mean special media buttons that are not standard, Toshiba may provide a utility on their support website that you can download to make those buttons work.
Posted on Mar 19, 2010
How to replace keyboard on Toshiba satellite c55t-b5230 laptop
Toshiba Keyboard Replacement - Satellite Laptop - YouTube
? 5:19
www.youtube.com/watch?v=F62RbnA06Fo
Mar 6, 2012 - Uploaded by Jennies Garage How to remove and install a keyboard on a Toshiba Satellitelaptop computer. ... This video should help If I ever think ofreplacing the keyboard.
Sep 17, 2015 | Computers & Internet
How can i remove a toshiba satellite A500-01w keyboard?
try this first
a. turn over computer overnight and let it 'drip dry'
b. take a hair dryer on low heat and fan and GENTLY run it over the keyboard about 1 inch back and at angle
try that first and report back
you might get lucky
Jun 14, 2012 | Toshiba Computers & Internet
My toshiba satellite m55 s135 ctrl key did not work
open your laptop keyboard then try to clean it first, then try your keyboard
if did not fix your problem it mean you need to change keyboard with new one
Mar 14, 2011 | Toshiba Satellite M55-S135 Notebook
How to replace keyboard on a toshiba sattelite A-215 laptop
Hi click on the link http://www.irisvista.com/tech/laptops/toshiba-satellite-a215/disassemble-display-panel-1.htm , in your case i think you should just start at step:5 ,once you take out the screws be careful removing the plastic connecter they usually open "up"
Aug 28, 2010 | Toshiba Keyboard for Satellite A200 A215...
I have got Toshiba satellite - A135. Accidently coffee spilt on my laptop keyboard, and it is not starting. will you please give advice regarding this. Is there any protect cover for keyboard? Please...
All you need to do is prop open your keyboard and wash it. Go to this website and it will show you how to open your laptop up. http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/remove-mainboard-1.htm
you can start at STEP 7. The plate WILL prop open, Just be patient. And also watch for the tap connector.
Also, your keys will prop open easily also. Pull with your hands. Just put them together when you are done.
Use a universal cleaner and wait for it to dry before putting the keyboard back together
Aug 20, 2010 | Toshiba Satellite A135-S4666 Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
How to open a Toshiba Satellite M-100 ?
The key move for that buddy is the cover above the keyboard, usually snap-in type, after that the screws for the keyboard and every thing follows,need to remove some bottom screws for further exploration.Need your vote
Aug 29, 2009 | Toshiba Satellite M100-ST5211 Notebook
Toshiba satellite laptop keyboard driver
i dont have satellite L40 drivers plz provide a link for them
Sep 05, 2008 | Toshiba Satellite A135-S4527 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
