Question about Sirius Audio Players & Recorders
I have a sv3r stratis what t fm transmiter sould i use
I didnt have a transmiter when i bought it
Squealing sound
are you listening via FM transmitter function?
if so, make sure that you do either.
1) when watching the same DVD on both screens, disable the FM transmit on one DVD.
2) when watching separate DVDs on each screen, make sure that the frequencies are separate by as big a gap as you can make.
I had this problem and it was due to both screens transmitting on the same FM frequency and interfering with each other.
I also found that the lower FM frequencies stopped my GPS from working!
After altering the FM transmit settings (FM-TX) button on remote, it was all good.
Mar 12, 2014 | Eonon C1037 2x9" HD LCD In Car Black...
Recently lost drive and second still had first and reverse changed fluid and filter now i have drive sometimes but it slips i didnt change fluid in torque converter
u need a new transmition. first and reverse are on the same band. u have enough new fluid that u sould not have to worry about what was in the converter. rebuild or replace is my sugestion
Nov 10, 2009 | 1999 Ford F250 Regular Cab
How do i get expanded freqs on my ft1802 yaesu tranceiver
The FT-1802 is a 50 watt 2 meter FM transceiver. It can transmit anywhere between 144 - 148 Mhz (the FM portion) of the 2 meter ham band. It can receive anywhere between 136 - 174 Mhz without any modifications. There is a modification to enable transmit "out of band" below:
http://www.ham.dmz.ro/yaesu/ft-1802-extended-transmit-modification.php
There are few details about the results of this mod - typically these provide for transmitting on frequencies outside (above, below or both) of the 2 meter ham band. Transmitting outside of the ham band without a proper license for the frequencies in the U.S. is a violation of FCC rules.
Sep 08, 2009 | Yaesu Radio Communications
Transmition problem
No forward or reverse? After you installed it how much fluid were you able to get in it before it read full?
May 27, 2009 | 1997 Dodge Dakota
Flip down monitor
Well, It all kinda depends on how ur trying to hear it. Depening on the age and the model of the dvd player some models have a built in FM Modulator. This transmits the audio signal via your FM radio. Most Fm Modulators are preset out of the box with lower frequencies. Simply pop a disc in ur dvd player, Make sure the volume is  up on the dvd system and tune ur radio to the matched setting of the Fm Modulator.
Nov 15, 2008 | Car Audio & Video
FM transmission on a zipy kanguro
I solved the problem...just plug the earphones...
Aug 29, 2008 | Audio Players & Recorders
Hands free calling and FM transmitter
Old post, but here we go.
1: Update to latest firmware from tomtom, for Gox20/x30 that is 8.351
2: Make an silent mp3 file and put that onto device
3: Play silent mp3 in loop
4: Send nav instructions over fm to radio... et voila!
Jul 20, 2008 | Tomtom GO 720 GPS Receiver
Can i change my cb to fm
It would be fairly expensive & therefore impractical to do.
Jul 18, 2008 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Garmin 760 phone feature
Did you check the settings for the sound output? If it is set to FM-receiver, you have to tune your radio to the same frequency as the 760 transmitting frequency. To get sound from 760-device, you must deselect the FM-transmitting feature.
(I don´t think this solves your problem. Too obvious.)
Jun 26, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
