Question about Olympus SP-550 UZ Digital Camera
Image sensor problem in image sensor Olympus SP-550UZ
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 96 Answers
If the problem is dust, you can try to blow it away. Else, take the camera to a repair shop, the sensor is very sensitive and can easily be destroyed...
Good luck! :)
Posted on Apr 17, 2014
kakee
  • 1268 Answers
SOURCE: How to remove lens from
This cleaning process is very delicate and sensitive. Cleaning lens should be done by authorized or pro camera technician. I suggests you to bring it to the nearest cam service center because they have appropriate tools to open the camera and properly clean it. A single failure or error on cleaning it by yourself might give fatal result to your camera.
Posted on Oct 04, 2008
  • 3422 Answers
SOURCE: I would like to find an instruction manual for my camera.
HI,
Please click on the below link to view the manual for your model:
http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/zoom/man_sp550_e.pdf
Posted on May 15, 2009
SOURCE: how can you take off the lens on an olympus
my camera wont take pictures clearly and on the screen the flash signal is blinking and next to it theres something that says E:91:01 how can i fix it
Posted on Oct 30, 2009
  • 11967 Answers
SOURCE: Zoom Error with my Olympus SP-550uz
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 04, 2010
richard191
  • 691 Answers
SOURCE: Hi Ive got an Olympus SP-550UZ digital Camera
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty. "Zoom error" is repairable
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Feb 21, 2010
Olympus SP-550UZ camera will not upload recording to computer
Long videos should be transferred to a folder you create on your desktop using a separate card reader. eaa3d1b.jpg
Jun 15, 2010 | Cameras
I have a problem with power on Olympus SP-550UZ
Try using regular batteries. I did with my camera and seems I can go a lot longer on the regular batteries verses the re-chargable ones
May 16, 2010 | Olympus SP-550 UZ Digital Camera
Need to turn the sound on the camera to record
have you tried going into menu and resetting default settings,this should bring everything back to origional settings
Mar 18, 2010 | Cameras
Hello
Thanks
Richard Scott
Technical Support
New Zealand
Feb 21, 2010 | Olympus SP-550 UZ Digital Camera
My olympus sp-550uz will not take a picture on Auto, but does take video and will take pics on the "My" setting. Also some pics have green tint to them now. This happened after changing batteries
I don't think the battery caused this problem.
Try a known fresh set of batteries, then go into the camera settings and do a "restore to factory default"
option. And, re-format the memory. If you are using a memory card take it out. Take out or put in AFTER camera has been turned off by the way. Hope that helps.
Nov 28, 2009 | Olympus SP-550 UZ Digital Camera
How can you take off the lens on an olympus sp-550uz camera? the lens is stuck is not coming out
Oct 30, 2009 | Olympus SP-550 UZ Digital Camera
Olympus s P-550UZ,
Turn the camera dial to the letter P on the mode dial. Then go to the Menu and left arrow over to Reset and press Ok. You will see Reset Yes or No. Highlight Yes and press Ok. This will reset the camera to all of its factory default settings. The zoom feature should be working again.
Nov 17, 2008 | Olympus SP-550 UZ Digital Camera
OLYMPUS SP-550UZ
When I try to zoom on my SP 550 UZ it says battery empty, yet operates normally otherwise.
Oct 11, 2007 | Cameras
Olympus SP-550 UZ Digital Camera Logo
59 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
