Question about DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker
Esam 5500 t water spout doesn't register and cappuccino doesn't work
Water spout doesn't register
2 Suggested Answers
  • 48434 Answers
SOURCE: Delonghi ESAM 5500 no hot water/milk just says "Heating Up, Please Wait"
Apparently the heating element has gone to that place where they can not be fixed .
Posted on Nov 25, 2015
DELONGHI ESAM 5500 WON'T MAKE CAPPUCCINO SAYS GRINDS TOO FINE, BUT WILL GRIND AND MAKE REGULAR COFFEE
have you tried cleaning it as described in your user manual,, can you hit the button for regular grind? there are alternatives, a coffee grinder if failry cheap at 10 dollars US,,
Jun 07, 2016 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Nov 25, 2015 | DeLonghi Coffee Makers & Espresso Machines
Cannot get steam to come out of my delonghi prima donna XS coffee machine
Could not find why but maybe if you go back over the scaling procedure and steam procedure there might be something you missed.
Please note! If "Energy saving" is active, you may have to wait a few seconds before hot water and steam are delivered.
Steam delivery 1. Make sure the hot water spout is attached correctly (fig. 7). 2. Fill a container with the liquid to be heated/frothed and immerse the spout/cappuccino maker (D5) in the liquid. 3. Press the steam ( ) button. After a few seconds, the steam to heat the liquid comes out of the cappuccino maker and "STEAM" is displayed. 4. When the required temperature is obtained, interrupt steam delivery by pressing the steam ( ) button again. (You should not discharge steam for more than 3 minutes at a time).
http://www.delonghi.com/Global/InstructionManuals/EN/EN-PrimaDonna-ETAM36365M-im.pdf
customer support
Customer Support
Delonghi 3500s coffee machine not producing hot water or steam from water outlet/milk frother
Hey Everyone,
I had this exact same problem.
Check out my video of how to fix it.
Video: https://youtu.be/_SbGiD4LeCc
Hope it helps!
Jun 25, 2014 | Coffee Makers & Espresso Machines
Water leaks between the pull down spout and the bathroom tile
It sounds like your spout supply nipple has sprung a leak. There isn't much of any other way water can flow between your spout and tile wall. It's pretty important that you don't use the fixture until the problem is fixed. Because the water coming out that you see is also probably flowing into the wall and causing water damage and MOLD. You need to remove the spout and replace the nipple that is supplying the water to the spout. There could be a defect in your spout too, but likelihood of that is less than your nipple threads giving in to some electrolysis from the bronze/copper in the spout or somewhere in your water system. To prevent it from occurring again, use a brass nipple to replace the galvanized nipple in it now. Red brass, no yellow brass. Good luck with your problem and always know where and how to turn your water off to your house before attempting a plumbing repair.. Most spouts screw off. Counter clockwise, use a pair of channel locks by inserting the rubber coated handle into the opening on the spout then using the leverage of the channel locks to unscrew the spout off of the wall. It is not a repair that requires to have the water off to your home before attempting to repair. It only emits water when the tub valve is turned on. If it doesn't unscrew, twist it until the under side is up and you will see a slot where you can insert an allen wrench to loosen it and then slide off. Inspect the spout while it is in your hands to see if it is damaged of if the nipple sticking out is damaged. one of the two must be, because water flowing from behind the spout is definitely not normal and definitely something you need to fix right away, before your wall and floor behind your tub are damaged or start to grow mold.
May 04, 2014 | Delta Faucet Delta RP17453 Pull-Down...
Moen 7700 - No water through spout
Because you bought it for life. For service and support call 1-800-BUY-MOEN
Customer Support Moen
Give them a call, they stand behind what they sell. There is a possib ility that it has lifetime warranty.
Nov 21, 2017 | Plumbing
Service manual for "Insert water spout" problem
Check the heating coils for proper resistance or no resistance. If the machine is sending a signal to check the coils before turning them on AND it is not getting any resistance then it cannot continue. However if you have the machine plugged in near the microwave oven, then a power surge may have blown the control board or caused it to lose its progamming. The control board is expensive!
http://www.appliancefactoryparts.com/smallappliances/delonghi/esam5500-b-perfecta.html
Nov 24, 2013 | DeLonghi ESAM5500
"GROUND TOO FINE ADJUST MILL! Insert water spout
  1. Insert steam spout and push OK.
  2. Fill your tank and add descale solution.
  3. Go to program settings - Descale.
  4. Follow the prompts on the readout.
  5. After descale and rise are complete refill your water tank.
  6. Your system should now work as normal.
Note: If you do not have a descale solution, run the above with just water. Remember to descale when you obtain a descale solution.
Sep 27, 2013 | DeLonghi Perfecta ESAM 5600 Espresso...
DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker Logo
37 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
