I HAVE AN ELCECTROLUX SPLIT AC.. VOICE COMES FROM IT IN LOW FAN MODE AND IT STOPS AT HIGH FAN (TURBO) WHAT COULD BE THE PROBLEM .HOW TO RESOLVE IT..?
  • 960 Answers
Check and make sure the filters are clean. Strange noises can occur if they are dirty. It may also be a "dry" fan bushing. At the end of the fan barrel, (Usually the left side) there is a brass bush which can dry out and cause a squeaking noise. Carefully insert the long tube of a WD40 (or similar) oil spray can, into the outside of the fan barrel on the left hand side. NOT when the machine is running.. and give it a light spray, the oil should seep into the bush and quieten it down if that's the problem. To do the job properly however, the indoor unit would need to have the cover taken off and the bushing removed and oiled....
Posted on Mar 29, 2014
  • 124 Answers
SOURCE: High Pressure cutoff
YOUR OUTDOOR FAN MOTOR SHOULD NEVER SHUT OFF IN THE AC MODE. IT IS SUPPOSED TO SHUT OFF IN THE HEAT MODE WHEN ITS IN DEFROST. IF THE UNIT IS RUNNING IN COOL AND THE OUTSIDE MOTOR QUITS ,THE COMPRESSOR WILL QUIT SOON AFTER. EITHER THE RUN CAPACITOR FOR THE FAN IS BAD OR THE FAN MOTOR ITSELF IS BAD, IF CAP IS GOOD THEN THE MOTOR IS At FAULT. THE OUTDOOR PRESSURE SWITCH CAN ALSO OPEN IF THE INDOOR FAN MOTOR FAILS IN HEAT OR THE FILTER IS PLUM NASTY in heat OR THE INDOOR COIL IS PLUGGED UP in heat.. THE PRESSURE SWITCH USUALLY TRIPS AT 400 TO 425 SO ITS WORKING CORRECTLY. YOU MAY BE CONFUSING THE ISSUE SAYING THAT THE AIR IS HOT AND COLD INSIDE. IT IS COLD WHEN AC IS RUNNING HOT WHEN HEAT PUMP IS RUNNING IN HEAT BUT ESSENTIALLY not cold or hot if compressor isn't running, but a lot of folks describe the lack of cold air as hot when the compressor isnt running. but it basically is warm or house air temp.you test the capacitor with a capacitor tester or take it to motor shop and let them test it. odds are its a 5 , 7.5 or a 10. it should test within 10 % of rated value . ask for a RESCUE brand replacement motor. they are great ,reversable etc.carefully oil and sand the motor shaft and note exactly where the blade was located in relation to the grill so you get it back just the same. usually they wire up black to a leg of 220 power. white to the other leg of 220 power. brown and brown with white stripe to the capacitor.you can also pull whole fan shroud assembly on some units and take whole thing to motor shop and let them test motor cap, replace and all you do is return to unit and connect two power leads,
Posted on Oct 26, 2008
SOURCE: My split type AC won't blow on high fan. Goodman
Goodman Air Conditioner WMC24-1A access cover
Posted on Jul 27, 2009
relaga58
  • 158 Answers
SOURCE: Goodman wmc24-1a split system - fan stops on dry mode
that's normal
Posted on Aug 11, 2009
motor1258
  • 6674 Answers
SOURCE: have a duo therm ac and the low ac and low fan not work -
Thermostat on wall, or manual controls at AC? Did it work for you on low before now? Reason I ask, is that normally they are only a 2 speed fan ( low and high) so if it's a wall thermostat and has been changed from original, perhaps it the way the thermostat is wired.
Posted on Jul 10, 2010
  • 10 Answers
SOURCE: Electrolux split AC 1.5 ton inside fan working.But
The 2 most common issues are a freon leak or the outside unit fan start capacitor goes out. It's more likely a capacitor issue. They fail regularly, especially when it's hot out. I had a fan capacitor go out on one of my 3 units last year and it cost close to $300 for an AC company to come out and fix it. I watched them fix it and it's something that you can do yourself if you know what you're doing and are careful to hook it up right. I have three AC units and another capacitor went out this year and I found a kit with detailed instructions with pictures and phone support at hvacrepairkits.com. It saved me over $200 on the capacitor replacement.
Posted on Aug 14, 2011
Split type aircon
It sounds to me that the air con is on auto fan, as the room gets hotter or colder the fan will slow down and stop. keep the fan on low,med or high fan speed
Apr 02, 2014 | Carrier Heating & Cooling
When I turn the furnace on the ac comes on also.
If you have both heat and ac running that means that the Yellow , AC and the White heat circuits are both being energized with the Red 24 volt hot leg that enters the tstat on the R terminal, note the Auto fan switch between Yellow and Green if Normally closed that is the Auto setting and high speed fan comes on for the Cool mode via the fan relay,
while the Heat speed is low speed and controlled not by the fan relay but the temperature or time delay, you need to determine what speed you have running now, low or high? if you flip the fan switch to ON and it speeds up then it was on low, if it makes no difference you have high sped running already.
Oct 06, 2013 | Dometic Rooftop RV Air Conditioner
How to on a blower in an split AC
Press on/offf in your remote. You keep any mode -blower will start first. But only dry and auto mode the fan speed will be low only. You can't change speeds
Jan 11, 2011 | LG LA185HV Split System Air Conditioner
I have an Electrolux split air-con, have no manual, want to just have fan on without the air on ,do I fix it no DRY Mode regards
Fan mode only, you can control low/med/high speed. In dry mode with low fan, it cut in and off air-con for five minutes frequently.
Jan 04, 2011 | Heating & Cooling
Case 580 m ac will come on blow cold then the light comes on and it stops blowing cold you can turn ac off for bout 1 min and turn it on it blow cold and kick off light on manual say light eather high...
take a garden hose or somthing with high water pressure and spray out all of radiators in the front of machine. This will clean out all the dust build up between all the rads and will cause your fan to cool the ac fluid as well as the others
Aug 05, 2010 | Ertl 580 Super M Series II Tractor
AC won't run on low speed
It may not be wired for low & high fan mode. If it always did before, then yes there's a problem.
Jul 18, 2009 | Dometic Rooftop RV Air Conditioner
Ac runs for a while then stops and operation light flashes
Hello, It depends what refrigerant the system is on but if it tripping out on HP it could be overcharged with gas or a problem with the outside condesor fan.
Feb 02, 2007 | Mitsubishi MS12TN Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
