Question about Husqvarna 224L
What brand oil [other than factory]can i use for oil change for Husqvarna 224L weedeater
Oil change recomnened hours
3 Suggested Answers
  • 277 Answers
SOURCE: What oil am I to mix with gas for my Husqvarna
any 2 cycle oil is good.
mix 40 to 1 for most 2 cycle motors
Posted on Jul 07, 2011
hunter19_46m
  • 7482 Answers
SOURCE: why does my husqvarna 224L weed eater cut off everytime i push throttle?
Hi casey guffey
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Oct 11, 2012
When to change oil for the first time
Hi David:
There may be a recommendation in the owners manual.
Depending on how many hours you are running it, I would recommend:
- 1st change including filter after 25 hours (just because there may be some "run in" residue.
- Every 100 hours and at the end of each cutting season. (best not to leave used oil in an engine for long times.
Cheers
May 16, 2016 | Husqvarna Garden
How much oil and what type of oil should I use in the trimmer?
You use no oil,use regular unleaded gas only,on 4-Cycle engine use gas,2-Cycle engines use the oil- gas mixture,your's is better cause you just need gas.I use Husq's too.
Apr 13, 2016 | Husqvarna 224L 25cc 4-Cycle Straight Shaft...
Drive head rotates counter-clockwise. Can't get it back into position. Use to be able to simply turn it back around. Can't now.
Husqvarna 128 LD Weedeater Repair Questions,... - Fixya
www.fixya.com > Forum > Lawn Trimmers & Edgers > Husqvarna
Recent Husqvarna 128 LD Weedeater questions, problems & answers. Free expert DIY tips, ... Drive head rotates counter-clockwise. Can't get it back into ...
HOW TO CHANGE HEADS ON HUSQVARNA 128LD - Fixya
www.fixya.com/support/t20975899-change_heads_husqvarna_128ld
Oct 25, 2013 - Question about Husqvarna 128 LD Weedeater ... SOURCE: MyHusqvarna 128LD primer bulb .... Drive head rotates counter-clockwise.
Weed eater bogs out at full throttle - Fixya
Oct 07, 2015 | Husqvarna 128 LD Weedeater
How much oil does a husqvarna 224l use
The manual does not call for a specific volume of oil. Make sure to check the level using the dip stick and make sure the oil level is approximately half way up the dip stick. If oil is needed, SAE10W40 is recommended.
Sep 01, 2014 | Husqvarna 224l Gas Powered Line Trimmer, 4...
How to change cutting head on 224l trimmer
www.husqvarna.com/asia/support/contact-husqvarna
1 (800) 487-5951
Jun 17, 2014 | husqvarna"" ls 2 cycle oil"
Set idle 224L
page 19 of the manual found here : http://www.husqvarna.com/ddoc/HUSO/HUSO2009_USen/HUSO2009_USen__115138729.pdf
Jul 08, 2012 | Husqvarna 224L
Owners manual husqvarna 224l how to read oil level on 4 cycle
oil level.? Although its a 4 cycle it uses standard 1:50 2 stroke mix. No engine oil.!
Jun 11, 2011 | Husqvarna Garden
Husqvarna 224L Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
