Question about Pantech Tablet Element 16GB, LTE Gsm Unlocked, 8in - Black
Unlocked at&t pantech element tablet 4.0.4 apn settings for red pocket 4G plan
Have a unlocked at&t pantech element tablet running on 4.0.4 and have a red pocket sim its sowing I have internet but apn settigs must be wrong. any clue what the full APN settings would be? Thanks in advance
3g dongle support
Hi
Seems like it needs to be configured, though not all tablets support dongles i.e Karbonn-Samsung Galaxy and lenovoA1000 & A30
First, (1) put 3G sim into dongle and connect dongle to tablet. You may have to wait several minuets for tablet to find internet, if it does not, continue as below.
2. Now go to 'settings' and select the 'More' option .
3. Select 'Mobile Networks' > 'Access Point' Name (APN) 4. Then select New APN option.
5. All you have to do now is make the following changes in the bracketed entities [ Name, APN and Dial Number]:-
-> Set the network name. Eg:- For Tata photon just write Tata or TP or anything, as you like it.
-> Set the APN,> search the net for your service provider's APN. Then write it precisely.
-> All the dongles come with dial number. Check your dongle purchase paper or the manual or just search it Google. And then fill the same here as the Dial Number, save and you are done. eg. For Tata Docomo it is #999 and Reliance it is #777.
NOTE:
After plugging the dongle, a default APN gets created in the APN setting's page.Try to feed the settings by creating a new APN.
Karbonn, Samsung Galaxy and Lenovo A1000 & A3000 tablet does not support dongle.
By far and large the above steps will work with all the dongles and Tablets. You could also go to 'You Tube' and seach for Video info which may be quite helpful. Regards Silverfox160
Ssssss
Aa
You can aaa
aa
a
Aug 27, 2014 | Irulu 7 Inch Android 4.1 Jelly Bean...
How do I edit and save apn settings?
Android 4.0 manked up the apn controls, unfortunately there isnt a simple 'covers everything' solution. Search the market for 'APN settings' and hope fr the best. Each carrier and phone has a totally different compatibilty list.
Aug 08, 2014 | inDigi 7-inch Phablet Smart Phone Tablet...
What is the apn settings straight talk
It is best if you contact Straight Talk for APN settings.
Mark
Mo
Aug 01, 2014 | Motorola Mobility Atrix 4g Mb860 Quad-band...
Straight talk apn
I would suggest you call your carrier. It is possible to disable picture messaging from their side. If that is fine then they can walk you through your settings.
Jun 17, 2014 | Motorola Mobility Atrix 4g Mb860 Quad-band...
My tablet sceen is white how do i fix it
possibly water damage. call and see if youre under warranty
Mar 02, 2014 | Pantech Element 4G LTE Android Tablet
Gave my Pantech Element away how to change owner name
You will need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
Nov 02, 2013 | Pantech Element 4G LTE Android Tablet
Juice spilled on it and now after reboot it has a white screen. I thought the pantech element android tablet was waterproof...is it damaged?
it's only water proof when all the ports - usb - earphone are closed
"The Pantech Element is waterproof against incidental exposure to water when all ports (incl. USB and earphone ports) are tightly closed, but is NOT designed or intended for in water use. Waterproof based on IP57 rating. "
see if it's under warranty to return defective
Oct 30, 2013 | Pantech Element 4G LTE Android Tablet
Fix a pantech element tablet with frozen touch screen
my tablet needs to be caliabrated I try to touch a letter and it wont work
Apr 16, 2013 | Pantech Element 4G LTE Android Tablet
Pantech Tablet Element 16GB, LTE Gsm Unlocked, 8in - Black Logo
Top Pantech Tablets & eReaders Experts
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Pantech Tablet and eReader Expert? Answer questions, earn points and help others
