Question about Brunton Echo 440 Rangefinder
New battery unit won't turn on
Put a new battery in, but the rangefinder won't turn on
Bushnell hybrid won't charge
Most likely a dead battery. Easily replaceable at home. The factory won't tell you that.
Dec 01, 2012 | Bushnell Hybrid Pinseeker Laser...
Won't turn on
I found that mine works great if I do not over tighten the cap on the battery. back it off little by little until it does work.
Nov 24, 2011 | Leupold RX-III Rangefinder
Rangefinder is 4+ seasons old - will not lock-in
for this you will need to send the unit into their repair at 8500 marshall drive lenexa ks 66214 4-6 week turnaround and put your name address and telephone number inside the package. if there is a cost they will send an estimate.
Mar 11, 2010 | Bushnell Pinseeker 1500 Rangefinder
My bushnell rangefinder had abrand new battery put in.when ilook through everything all the legends are completlyfroze up.nothing moves or works. thank you for your time.mark
Dec 04, 2009 | Bushnell SCOUT 1000 Rangefinder
The prosport is showing low battery even after putting new battery in it. It is acquiring the target but not showing the yardage
Nov 21, 2009 | Bushnell Yardage Pro Sport 450 Rangefinder
Very wet rangefinder
Sep 30, 2009 | Bushnell Yardage Pro Trophy 20-2020 Laser...
The LCD screen will not come on when I depress the power button. The unit worked fine when I used it several days ago. It has not been dropped or jarred.
I would take the rangefinder battery and have the voltage checked. If you don't have a meter....radioshack will test it. It should be 3 volts a little more or less(2.9 to 3.2) if its good. Also make sure its in correctly. Positive end goes in the unit first. (flat side of the battery up towards you when you put the battery cap on) Make sure that little spring on the battery cap is there. Sometimes I pull that spring out....just a little to make sure its putting enough pressure to make a good contact. If you purchase a new battery and the rangefinder eats it up in a few days...You have a battery drain problem...This should be covered under warranty.
good luck to you!!
mtg
Jul 18, 2009 | Bushnell Tour V2 Pinseeker Laser...
Nikon ProStaff Laser 440 not working
Here is the address to send your rangefinder for repairs.
  • Nikon INC.
  • 841 Apollo St. Suite 100.
  • Elsegundo, CA 90245-4721
  • Attention: Repair Department
  • Phone (800) 645-6678.
I had the same issue with my Nikon Laser 800 rangefinder. I sent it in and they wanted $311.00 to fix it so I bought a new one for $300.00 off EBAY. Today I was missing around with my old rangefinder and noticed after I put the battery in I could hear something loose in the rangefinder. There is a little metal tang in the bottom where the battery goes that holds tension on the battery that was bent down. I bent it back up about 3/16" and put the battery back in, now it works fine.
Dec 01, 2007 | Nikon ProStaff Laser 440 Rangefinder
Unit "cannot measure" at any distance
Had the same problem... Pushed the mode button and the power button simultaneously for 30 seconds, then it worked again...
Oct 18, 2006 | Nikon ProStaff Laser 440 Rangefinder
Brunton Echo 440 Rangefinder Logo
59 people viewed this question
Top Brunton Optics Experts
Piyal Perera
Piyal Perera
john h
Ann Zambetti
Ann Zambetti
Are you a Brunton Optic Expert? Answer questions, earn points and help others
