Hll 2600wa THIS UNITIS DEAD IC LOCATION NO N802 IS FIRE SO I WANTED TO KNOW THAT IC NO
Serial # HLL 12,only numbers on gun, how old and base price
Hi Larry.
I found a listing in a State of Michigan gun data code manual
https://www.michigan.gov/documents/msp/NCIC_Gun_codes_as_of_8-5-2012_407670_7.pdf that links the HLL, in several places, to 'J. H. Hall/Hall-North' as Civil War Rifles. There are some listings here
https://books.google.com/books?id=WiK6kmJ6XukC&pg=PA151&lpg=PA151&dq=J.+H.+Hall/Hall-North+Model+12&source=bl&ots=61JUjZkJO0&sig=g1e_F-jZZlWHnLYkrnVb6cvdsAM&hl=en&sa=X&ved=0ahUKEwia6tD20s_JAhXLE5QKHfWEAX8Q6AEIOTAE#v=onepage&q=J.%20H.%20Hall%2FHall-North%20Model%2012&f=false of some Hall / Hall-North pieces listing at thousands or even tens of thousands of dollars, though I didn't find a HLL 12 mark specifically. The only mention of 12 there is as part of weights.
This
http://www.cornellpubs.com/free-files/United%20States%20Cartridge%20Revolver%20Names%201865-1930%20BW%20Portrait.pdf
mentions other brands (Tiger and Enterprise), made by Ely & Ray, and Enterprise Gun Works, respectively).
This mentions a B12 breechloading flintlock made by Hall in 1834
B12 Rifles 2 flintlock breech loading Hall Harpers Ferry Arsenal Virginia...
Sans description of form factor, firing mechanism, and the like, that's about as far as I can get at present. I hope this gives you some leads to identify and price the piece.
Happy Holidays
D
Dec 09, 2015 | Optics
I NEED E59670 POWER SUPPLY IC 802 PART NO WANTED
Your best bet is a universal power supply. Cheap and readily available.
Feb 18, 2015 | Acer Computers & Internet
K770i sim ic location in board
i want to know sonyericson sim ic location in board.pls show me now
Apr 05, 2012 | Sony Ericsson Cell Phones
There is a sound but no picture in to the screen and there is horizontal line
Tv have a Horizontal IC out is dead or cold soldering.Make a fist with ur hand,bang on the tv frame bazel a couples of times.If the hoizontal line flashes back to normal screen?Tv have cold soldering around horizotal IC area.U have a soldering iron tool and a roll of solders,know how to do basic soldering?Take the back of the plastic screw driver tap around for cold soldering area.Resoldering those area.No horizontal tv screen flashes back the IC out is dead,require replacing another horizontal IC output.
Mar 21, 2011 | Televison & Video
HI ! My name Igor from Saint -Petersburg -Russia ! I have problem with my lcd monitor ACER AL1716F model ! AC 220V voltage is up over normal and my monitor is dead ! I am open ...
You will need service manuals at this point, so please try downloading them from here:
http://elektrotanya.com/?q=showresult&megnev=ACER&megnev2=AL1716&kategoria=monitor&kat2=all
I hope they are close enough for the PCB you have.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series
Dec 19, 2010 | Acer AL1716 F Monitor
My Magnavox tv is about 5 years old. When we turn it on the screen is blank. A soft high pitched sound comes out of it. The green "on" light blinks on and off. Any ideas on what is happening and why it...
You have a bad eeprom. Very common problem for this TV. The replacement eeprom [location, IC002, on the Tv board] is dependent on which microprocessor [location, IC001, on the TV board] and which stereo decoder [IC 1001] are present on the board. See if IC002 has a color mark on it. red, yellow, green..etc. Or give me the numbers on the actual IC 001 and Ic1001. For example IC 001[ microprocessor] might beMCU A22V01-TO and IC 1001 [stereo decoder] MSP3440. Take this info to a TV tech if you cannot repair this TV yourself. Thanks for asking and give me a High Five of hands!
Sep 14, 2010 | Philips Magnavox 27MS343S 27" TV
My system just stop working and its only blinking ocer
OCER indicates that the unitis in protect mode. First press the reset button (tiny pinhole button). If the unit comes back on saying OCER then most likely there is a short or a grounding problem with the speakers or speaker wiring. Disconnect all speakers and press reset again. If OCER still shows up the unit needs service. If not, connect each speaker once at a time until the unit comes back in OCER to narrow down the location of the unwanted DC signal.
Apr 02, 2010 | Kenwood KDC-MP235 CD Player
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
