Question about HP Pavilion dv9000z Notebook
Screen doesn't light up, hard drive doesn't spin, dvd drive spins
Was working, won't boot up, hard drive doesn't spin
  • csuaso Mar 28, 2014
    After many hours trying to repair this problem, I was able to turn it in on my Directv service plan. For $50 I sent it to their service center which couldn't fix it either so they sent me a brand new present year laptop of the same value as I paid for my laptop. Problem solve.
    Guru:
  • HP Master
  • 468 Answers
Please let me know more information about the issue.
Do you see Power light on the Laptop?
Do you receive any error message?, if so, please let me know
Are you able to go to BIOS setup?
Thanks!
Posted on Mar 30, 2014
    Top Expert:
  • HP Master
  • 22,688 Answers
Can you get to the bios? If you can, ensure the boot sequence starts with the hdd.
Posted on Mar 28, 2014
The display of my laptop is not working when i switch it on the backlight glows but nothing appears on the screen it doesn't even boot.
It would be helpful if we knew the Make, Model of Laptop and the OS you are using? Try a hard restart , remove ALL media, DVD, CD, USB, etc., unplug , remove battery, leave battery out, plug in , reboot. Describe what happens, Fan spins? LED's blink? HDD spins up? Sound? Anything on screen? Have you tried a System Restore/Recovery? You can start by removing the HDD and testing it, if you done have a USB to sata/ide adapter take it to a Qualified Computer Tech.
May 04, 2013 | Computers & Internet
Acer am1100 won't start up
Discribe what happens when push the on/off button and you try to boot, fan spin? LED's blink? HDD/DVD light blink? Sound? Any thing on screen at boot? What blue light?
Feb 26, 2013 | Acer Aspire AM1100-B1410A Refurbished AMD...
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
Fan just work for seconds
Replace the fan or your computer will run hot and keep turning off.
Or are you saying this is what happens when you power on the computer? if so: When you press the power button do you hear fansrunning, hard drive spinning, lights on the computer, hear any beeps or lightsconstantly blinking, hear the DvD/CD drive click and the light on the drawer ofthe DvD/CD turn on for a second or two? If so the laptop is trying toboot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Mar 28, 2012 | Computers & Internet
Toshiba l355d - s7815 won't boot and screen doesn't light up
From your description you have a motherboard issue, the only way to rectify this, it must be replaced.
Mar 26, 2012 | Computers & Internet
After setting for a while can't get machine to boot up. Put in new battery, still no difference, everything lights up but just won't boot. what can I do?
If there are no beeps, nothing on screen, all fans spinning, and hard drive spins up, chances are your motherboard is bad.
May 31, 2011 | Computers & Internet
My brother wiped the hard drive on his Sony Vaio PCG-4F1L notebook and gave to to me, because he was upgrading. The power button lights and I hear the dvd drive spinning if I put a disc in, but the screen...
he has formatted the hard drive
press the start button and hold down the delete until the bios screen comes up
select the boot tab and select cd as first boot preference
save yes and press esc
install the operating system disc and the hard drive will load the os
you will still have to load drivers from microsoft driver downloads as well
Sep 19, 2017 | Computers & Internet
System not booting, k8n
Have you tried resetting the bios? turn off the computer and remove the power cable connected to the power ATX power supply, look for the "clr_cmos" jumper and change the settings from 1-2 to 2-3 for approx. 10 secs, then return the jumpers to original settings and reconnnect the power cable and turn on the computer. This was the solution when i had the same problem before. Hope this helps you too.
Oct 01, 2009 | ASUS K8N-E Motherboard
HP Pavilion dv9000z Notebook Logo
50 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
