Question about Maytag Atlantis MAV6000 Top Load Washer
Leaking and saying overflow
My washer is leaking from the bottem and when wash has finished it says overflow
  • 1 more comment
  • Brenda Mullins
    Brenda Mullins Mar 31, 2014
    Sorry. It not finishing a wash it starts the cycle within a couple of min it stops washing and leaks everywhere and says overflow
  • David Otter Apr 05, 2014
    ok is sounds like either the valve is not shutting of or the level sensor is not picking up water level.
    if you can have the top open where the wires plug into the valves you could try pulling off one of the wires for the valve (most are only 12/24 volts dc) any one of the valve wires will do. if water stops the valve is ok so could be sensor or control board.
    New Friend:
  • 62 Answers
It could be the air sensor for water level but more detailed info would help. is it still going through all cycles even when it leaks out and is water still being put in? or is it empty going through the cycles?
Posted on Mar 29, 2014
Why is my samsung vrt steam washer leaking from the bottem right model #WF331ANW/XAA
Locating And Repairing A Mystery Leak In A Front-Loading ...
? 3:55
www.youtube.com/watch?v=3D5q1ynWb-U
Jul 28, 2012 - Uploaded by SamuraiRepairman ... source of a leak in a front-loading washing machine and then mercilessly repairs it. ... LG Washer Repair & Diagnostic -Leaking Water from front & bottom ... Samsung Front-LoadWasher Disassembly - Washing Machine ...
Samsung vrt steam washer leaking - Fixya
www.fixya.com/support/t13638559-samsung_vrt_steam_washer_leaking
Jul 15, 2012 - Samsung vrt steam washer leaking - Samsung WF338AAB 4.0 cu. ft. ... I have a vrt ... I hope this helps.... Take of that little door on the front. Have a ...
Oct 29, 2015 | Samsung Washing Machines
Fit bottem entry inlet valve
WATER PRESSURE SWITCH MAY BE FAULTY
Dec 03, 2014 | Washing Machines
Kenmore Washer only leaking from one area
Ive never worked on a Kenmore but it may just be the overflow outlet. All washing machines have an overflow which will dump water out from the top of the tub if it overfills but sometimes on high fill water level, clothes can splash around and cause a "wave" of water to splash out over the overflow outlet. Check to see if the leak only occurs when you have selected high level fill.
Nov 23, 2017 | Kenmore Energy Star 44092 Front Load...
Hooverlightflashing
A tumble drier should only be used to dry clothes that have been through a hydro extractor (spin drier) first. They are not designed to put wet washing in. Dripping wet washing must first be wrung out or else the excess water will run out the bottom. If it is a washer/extractor, look for leaking pipes or door gasket.
Nov 25, 2013 | Dryers
Bosch washer leak
Check the 'outlet plumbing pipe' is not blocked, allowing water to overflow
Jun 28, 2013 | Washing Machines
Water leaks from the bottem of Maytag Neptune front loader
Your sewer drain may be backing up.
Check the drain during a final spin.
Feb 26, 2009 | Maytag MAH8700AWM Neptune Front Load...
Washer overlfow
How bad is the water overflow. A little puddle on the floor, or it will fill up to the top and be a waterfall until you shut it off?
Mar 11, 2008 | Kenmore 24032\24036 Top Load Washer
Cold water continues to run during entire wash cycle
Adrea, sounds like you need a new valve. When it's doing this leaking, unplug the washer. If it's still leaking you know for sure it's the valve. Part number for the model posted is 22002360. Catriver..post back.
Sep 30, 2006 | Maytag LAT3600A Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
32 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
