Question about Hitachi Saws
Armature interchange ? - Hitachi Saws
Need diagram for kango 900 concrete hammer drill
Hi Vicki
Is it the old all silver one or the new one with the red motor housing?
May 19, 2012 | Milwaukee Tool Hammering
Remove armature from grinder housing
If you have a shot armature then it will spark a lot where the brushes are touching the armature comulator. To remove the armature:1 Remove brushes. 2 Remove 4 screws holding the gear box. 3 Pull away gear box from the body. The armature may come with the gear box or not, it's only pushed in, so you should have no problem to disassemble it. If the armature stay in the grinder, use two skrew drivers to pray it out. You may not see anythink wrong with it, but it may be no good .
If my information helped you plz give me markings. Thanks
May 15, 2012 | Metabo Saws
Armature removal
Armature should just pull out. Try holding the armature and tapping the main housing with a soft mallet.
Drawing http://www.milwaukeetool.com/PartsAndService/DownloadManuals/PartsWiring.aspx?ProductId=6180
May 06, 2012 | Saws
Burntout motor on ksm150
Reg,
Good question. The KSM90 motor is not interchangeable as the KSM90 units were solid state units and the KSM150 units are not. However, I am very surprised that the motor on your unit died. They usually last a very long time, the most common issues we see are stripped gears inside the unit and stripped planetary gears.
Apr 10, 2012 | KitchenAid Food Mixers
Do parts for a model 3305 skil tablesaw interchange with a model 3400
numerous parts should. When you get to the armature and spur gear, then it gets a bit iffy.
Feb 13, 2012 | Skil 10" Table Saw
Replace armature, I have it all apart except I can't see how to release armature from base.
The armature bearings fit very snugly in their holders. If you have the case split and the belt drive pully off, you just have to pry the armature out of the other bearing holder. If you are replacing the entire armature and the new one has a fan on it just pry it out. If the new armature doesn't have a fan on it be careful not to break the fan or any of the fins. It should pull out smoothly, if it doesn't come out with even pressure you still have something on the armature holding it in.
Mar 04, 2011 | Porter Cable Cable 363 4" x 24" 1500 SPFM...
Replace coil
If, by coil, you are referring to the ignition armature and since you didn't specify what brand of engine you have I will give you instructions for Briggs: ((The instructions are similar with MOST engines with a few variances.))
Disconnect the spark plug2.gif wire from the spark plug, remove the blower housing from the top of the engine (That is the half round/half square metal cover on top of your engine, this will give you access to the ignition armature:
Installing And Adjusting A New Ignition Armature
An ignition armature must be set at a precise distance from the flywheel. Ask your Briggs & Stratton Authorized Dealer or consult our Engine Check Chart for the proper gap for your engine. Common armature gap ranges are .006- .010" and .010 - .014". Armatures are often packaged with a shim to assist in setting the gap. Microfiche or index cards of the proper thickness also work well.
  1. Remove the old ignition armature mounting screws (image A). Then, disconnect the stop switch wire from the flywheel brake and remove the armature.
  2. Attach a replacement armature from the original engine manufacturer, using mounting screws (image A). Then, push the armature away from the flywheel and tighten one screw (image B).
  3. Turn the flywheel so the magnets are on the opposite side from the ignition armature (image C).
  4. Place the appropriate shim between the rim of the flywheel and the ignition armature. While holding the shim, turn the flywheel until the magnets are directly adjacent to the armature (image D).
  5. Loosen the tight screw so the magnets pull the ignition armature against the flywheel and shim. Then, tighten both mounting screws and rotate the flywheel until the shim slips free.
Oct 15, 2009 | Garden
How do I replace the coil on a mtd yardman 15 HP
Disconnect the spark plug wire from the spark plug, remove the blower housing from the top of the engine (That is the half round/half square metal cover on top of your engine, this will give you access to the ignition armature:
Installing And Adjusting A New Ignition ArmatureAn ignition armature must be set at a precise distance from the flywheel. Ask your Briggs & Stratton Authorized Dealer or consult our Engine Check Chartfor the proper gap for your engine. Common armature gap ranges are .006- .010" and .010 - .014". Armatures are often packaged with a shim toassist in setting the gap. Microfiche or index cards of the properthickness also work well.
  4. Place the appropriate shim between the rim of the flywheel and theignition armature. While holding the shim, turn the flywheel until themagnets are directly adjacent to the armature (image D).
  5. Loosen the tight screw so the magnets pull the ignition armatureagainst the flywheel and shim. Then, tighten both mounting screws androtate the flywheel until the shim slips free.
Oct 08, 2009 | Mtd Garden
Installing Amature-Magneto
The air gap for the magneto is .010 - ,014. A microfiche card, an index card, a common business card or anything NON-magnetic of the above thickness makes a good shim to achieve this gap.
  1. Remove the old ignition armature mounting screws. Then, disconnect the stop switch wire from the flywheel brake and remove the armature.
  2. Attach a replacement armature from the original engine manufacturer, using mounting screws. Then, push the armature away from the flywheel and tighten one screw.
  3. Turn the flywheel so the magnets are on the opposite side from the ignition armature.
  4. Place the appropriate shim between the rim of the flywheel and the ignition armature. While holding the shim, turn the flywheel until the magnets are directly adjacent to the armature.
Sep 21, 2009 | Craftsman Garden
Something wrong with the armature
If the armature is shot, it will spark a lot where the brushes are touching the armature comutator. To remove the armature:1 Remove brushes. 2 Remove 4 screws holding the gear box. 3 Pull away gear box from the body. The armature may come with the gear box or not, it's only pushed in, so you should have no problem to disassemble it. If the armature stay in the grinder, use two skrew drivers to pray it out. You may not see anythink wrong with it, but it may be no good . That's Makita special, they don't make it good as they used to. The price for new grinder is about $130, for armature $65. field $40
Mar 06, 2009 | Makita 9005B 5" Electric Angle Grinder
Saws Logo
44 people viewed this question
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
