Question about HEWLETT-PACKARD HP EliteBook 8540p WH253UA Notebook
Sticky left mouse key Elitebook 8540W
The left mouse key is not fully returning to its natural position. Jiggling it around a little can get it to return fully but it is getting worse slowly. The functions are basically ok but the action of the key makes it difficult. It seems like a mechanical problem as opposed to a software type problem?? Any ideas?? Thanks
    Master:
  • 435 Answers
If it was me, I'd get a can of compressed air and try to blow it out underneath the key first. A soft bristled brush, pushed gently under the key might dislodge something. It sounds like you may have something spilled on your keyboard, so, while you computer is off, unplugged and the battery removed, I'd dip a soft bristled brush in some isopropyl alcohol and run it under the key. I'd repeat this a few times, and leave the laptop off for a few minutes until the alcohol has dried completely to avoid the possibility of a short from being wet.
Posted on Mar 29, 2014
Testimonial: "Thank you very much for taking the time to advise what sounds like a very logical approach. In looking to gain access under the edge of the key I found that the actual hard key has a rubber top cover to it and it is pressed onto the actual key and retained via a ridge around the lower perimeter of this rubber pad when it is pressed down onto the key. Well I have just solved the problem by removing the rubber pad completely and the key is performing normally as it should. Obviously what was happening was that the rubber edges of the pad were slightly impinging on the normal operation of the key. I have not put the pad back on as the key is perfect now but at sometime in the future I can reinstall it and see what happens.Hopefully this information may help someone else down the track. Regards Wayne"
  • sixpack6t9
    sixpack6t9 Mar 30, 2014
    I'm glad you fixed it. It was kind of you to present this problem here, there's no telling how many others might benefit from it. Have a jnice day.
How do I disable the mouse pad on elitebook 8470
Hi just double hit on the little hole on the upper left of the touch pad. This one will light orange when disabled. Regards.
May 27, 2014 | HP EliteBook 8470p Notebook
Hp unlock codes
I don't think there are any "Unlock Codes" but contact hp.com for an up date.
Nov 09, 2013 | HEWLETT-PACKARD Hewlett Packard HP...
General system board failure The LEDs near Caps
Your laptop has an external vga card
Thats usually the first suspect
Try reheating the one you have and if that works, even for a little while,look for a replacement
Sep 01, 2013 | HEWLETT-PACKARD EliteBook 8540w (FN095UT)...
Mouse buttons left right switching sticky keys
Remember you can always use the keypad in place of the mouse. Try replacing the mouse with another one. If that doesn't work, it is probably something in the software. Do a scan on the system next.
Jan 31, 2013 | Microsoft Computers & Internet
How to remove BIOS password on hp elitebook 2540p
You might try this, although it might not work on your specific model as some Elitebooks keep the password even if these steps are followed. Try this link
http://h30434.www3.hp.com/t5/Notebook-Display-and-Video/Reset-BIOS-Password-EliteBook-8540w/td-p/927153
Sep 11, 2012 | HEWLETT-PACKARD EliteBook 2540p XT931UT...
How can i reset Cmos password for Hp EliteBook 2540p
You might try this, although it might not work on your specific model as some Elitebooks keep the password even if these steps are followed. http://h30434.www3.hp.com/t5/Notebook-Display-and-Video/Reset-BIOS-Password-EliteBook-8540w/m-p/927235#M30136
Jun 06, 2012 | HEWLETT-PACKARD EliteBook 2540p XT931UT...
Spacebar on my Microsoft Natural Ergonomic Keyboard 4000 is sticking in the down position.
Take out the space bar button and change the position of the "sway bar" shown in http://www.paulstravelpictures.com/MS-Natural-Ergo-Keyboard-Sticky-Spacebar-Fix/index.html
There are 3 positions you can keep the sway bar - The middle positions worked for me and probably will work for you too.
Sumesh K
Jun 14, 2011 | Microsoft Natural Ergonomic Desktop 7000...
No sound from headphones plugged into jack Tried several sets of headphones.
To fix this problem please follow the links below
http://alturl.com/zvnbe
http://findtechhelp12.blogspot.com/
Thank you
Mar 26, 2011 | HEWLETT-PACKARD EliteBook 8540w (FN095UT)...
1989 ford f150 truck key will not turn in any position. tried jiggling steering wheel. any suggestions
This is a real shot in the dark but maybe it can get you out of a jam. Prehaps the steering wheel was turned very far to one side before the truck was turned off. The steering wheel would then be locked in this position. However, the steering wheel wants to return to the straight ahead position so it would putting pressure on the locking mechanism. This may prevent the key from turning. Try pulling on the steering wheel to the left or to the right while you try to turn the key. I hope this helps you out.
Jan 28, 2011 | 1989 Ford F 150
PRESARIO C700 LAPTOP CAPS LOCK KEY STUCK IN ...............CAPS RUNNING VISTA.
ok this a little trick but it can be done first under handy capped users there is a on screen keyboard get this up so you can used mouse to operate key board for a few miinutes. then there is also a setting for sticky keys get this turned on then mouse over to cap locke on screen and turn off the caps lock. I hope this hepled you i have been in that position my self.
Jun 10, 2009 | Compaq Presario C700T Notebook
HEWLETT-PACKARD HP EliteBook 8540p WH253UA Notebook Logo
49 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
