Question about Oregon Scientific Oregon 16-inch Pro-guard Chain Saw Chain Fits Cub Cadet, Echo, Homelite, Mcculloch, Makita, Partner, Poulan h66
CS9527 NEED TO KNOW HOW TO INSTALL NEW GAS LINE THE OLD ONE WAS GONE WHIN I GOT IT.
    New Friend:
  • 4 Answers
This is a tedious task but you can do it without taking anything apart the best think I've found is to go to small engine parts store and get the same size (fuel line) don't let them give you air line . Find a good long pair of tweezers and a bench vise you can bend them enough to be able to get into the fuel tank and connect the fuel line and away you go.
Posted on Apr 14, 2014
Has ran perfect for several years now it feels like it has a misfire .
it sounds like you have got water in your tank I would change the fuel filter and put 2 little bottles of gas line antfreaze in your tank
Jul 11, 2015 | 1996 Saturn SL
Gas leaks form gas line
It is an old car
You obviously need to remove any rusted out
steel fuel lines or leaking rubber hoses
How you will repair or replace that, will depend
on the parts avail at a dealer
I suspect the old stock is gone & you will need some
fabrication skills
Sep 14, 2012 | 1993 Dodge Spirit
How do I replace the water line going to the water valve assembly
That sounds favourite! Let me know how you get on. Is the tubing you have left long enough? And has it gone brittle? In which case it might be a good idea to replace it at the same time as the valve
May 20, 2012 | LG LFX25960 Bottom Freezer French Door...
It shuts off and the screen on the digital temperature controller flashes 11
Error code 11 is an Ignition failure.
New Install: Check your gas supply and that everything is grounded. Old Install: Check for internal water leaks or if your gas meter/regulator has gone bad (Or the amount of gas in your LP tank). Also check if your earthquake shut-off valve has switched on and shut off all the gas to the house.
Apr 22, 2011 | Rheem Water Heaters
How do i access the rear driverside brake line? there is fluid leaking all over the top of my gas tank.
If it is leaking on top of gas tank you need to drop fuel tank.Have some one install a new brake line ,bypassing the old one.,it is easyer than dropping tank Good luck
Dec 03, 2010 | 1995 Chevrolet Tahoe
Pilot light and heater will not stay lit
If the pilot light won't remain lit after you release pilot button you will need to replace the thermocouple. If you do not know how to do this it is generally a fairly easy job. First locate lines going from gas valve into burner compartment. There should be three, one to pilot light one to main burner and one to thermocouple. The thermocouple line is usually copper color and mounts directly in front of the pilot light. They usually slip into a friction fit holder so you disconnect line from gas valve and pull gently on line to remove. Measure length and get a new thermocouple at most hardware stores. If you can reuse the old holder then install thermocouple by inserting it into holder and seating it as far forwards as it will go. If you damage holder on removal there should be a new one with new thermocouple. Try to center thermocouple in pilot flame. Reconnect to gas valve and light according to instructions. I hope this helps you. Thanks
Nov 24, 2010 | Williams 2509612 Ceramic Mid-Size Heater
I have a 31-year old Caloric gas wall oven (Model RWD216) that finally died. I am ready to install a new unit, which means taking out the old Caloric. My question is, how do I unhook the gas line from...
first turn the gas off at the meter/ a oven this old may not have a shut off in the back. then you can remove the oven safely/ the line in back will hook to 1/2in or 3/4 pipe stub. . if you have a shut off in the back turn it off and reconnect new range to it . and if not make shure you put one in .. mm
Nov 22, 2009 | Ovens
Installing high altitude kit on Cozy NG furnace
the orifice that comes with the unit has a starter hole only needs to be drilled out, in the instructions is a chart for altitude de-rating.
Oct 04, 2009 | Cozy Enclosed Front Console Heater 20,000...
Need to replace gas line inside mcculloch chain
You need to disassemble the case to get to the fuel tank. Pull out the plug fitting and replace the internals with new factory grade parts.
Jun 30, 2009 | Garden
Gas line BSU"s
3/4 inch pipe is first choice but 1/2 inch pipe will work.
Aug 21, 2008 | Dynasty DGRSC 30 Gas Kitchen Range
Oregon Scientific Oregon 16-inch Pro-guard Chain Saw Chain Fits Cub Cadet, Echo, Homelite, Mcculloch, Makita, Partner, Poulan h66 Logo
55 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
