Question about Razor Dirt Quad Bike
I only get a click when I try to start the Razor quad bike
The lights show full power but the motor will not turn.I only get a click when I try to start the electric Razor quad bike.
I have charged it 5 hours.
Randall
07870 600776
    New Friend:
Also undi the connections and then reconnect them, I had the same problem. That did the trick, also google Razor recalls, if your model number is an 01 or 02 they ship you a free electronic controler. It was covered by the recall
Posted on Jul 18, 2015
MY RAZOR QUAD IS CHAREGED BUT WILL NOT RUN
I have exactly the same problem and it started right around the time the "gracious" 90-day warranty period expired.....
The battery lights had been on for days, indicating a full charge, but nothing happens when turning the throttle. Battery housing is very cumbersome to open, but I'll try to disconnect the battery next.
Jul 22, 2014 | Razor Dirt Quad Bike
How can i test electrical compontents on the mx500 dirt bike? i bought it used. it will not run the lights on the the throttle light up that the battery is full but when i twist the throttle nothing...
If the lights on a the throttle are showing a full battery then try disconnecting the brake switches at the controller one at a time. If the bike works after disconnecting a brake switch then that switch is faulty and should be replaced.
There is some excellent information on trouble shooting and testing components here http://www.razorama.com/razor-installation-guides.html
also wiring diagrams here http://manuals.monsterscooterparts.com/recreational/Razor/Wiring/
Oct 07, 2013 | Razor MX500 Dirt Rocket
Why is my Razor motorcycle MX350 battery showing green but not charging
yes!your battery needs replacement.....throttle clicking after a full charge is a sign,...but that's after 2years or more,depending on how it's being used..your motor can go bad before then if you been riding in the rain--wet connectors in or out the motor can not get wet for any reason..a full dirt motor bike can not get full dirty with mud..mud catains water/water and electricity don't mix/////.motor/thottle/moisture.
Dec 17, 2012 | Razor MX500 Dirt Rocket
Hi, my son has an electric razor quad bike with two 6 volt batteries. We have just replaced both batteries and the full charge light shows when you switch it on but it still wont start up. Can you...
The batteries should be 2 x 12v giving an output of 24v anything less than this the Razor Dirt Quad will not run. always make sure you buy genuine Razor replacement batteries.
Mar 29, 2011 | Razor Dirt Quad Bike
I have an 49cc ATV midi quad bike and it will not start at all. Have changed the flywheel and pull cord and carb, but still have no joy. Have used easy start too! please help, had it over a year never bin...
I had this same problem. I had a very hard time to start this quad untill i was told to make sure the fuel filter is half full with gas. Which it wasnt getting gas through the filter. So i went down to our local dealer and purchased another filter. The new filter was getting gas this time but the quad still did not start. So i was told to take the throttle cable off the engine and pur gas right in the hole, but the cable back on, Put the choke on full make sure the gas valve is turned on and fire it up. it started right away. But i had to repeat this a few times. But works now
Ed
Jan 09, 2011 | Razor Dirt Quad Bike
Not responing to the trottle.
The Main controllers always seem to be the problem on these quads. If you have a voltmeter you must check the batteries for a complete charge. You should read 24volt or around 24.60 vdc. If you have a full charge usaully 12-16 hrs by the charger supplied with the quad. Than check the output to the motor by disconnecting the motor wire and put your leads in the sockets and verify if you are getting voltage to the motor. Make sure you re-connected the battery before testing the controller output. You should see a varying voltage from 0-24 vdc when the throttle is turned. If you do not see anything at the motor lead and your batteries show charge. the controller is faulty or you have a bad connection. Un-plug and plug and connectors.
Dec 28, 2010 | Razor Dirt Quad Bike
Problem w/ razor dirt quad. I replaced the control module, it ran for a few days then died. Bought another control module and it doesn't go at all. I checked the batteries and they are putting out just...
Well this post was done a long time ago, seems like you have a bad battery. you should see 24vdc. The batteries are in parallel so it adds up to 24 volts.If one of them is dead it would only show 12vdc.
Sep 06, 2010 | Razor Dirt Quad Bike
I have similar problems with my razor mx350.
sounds like the CDI box is shot. This should be located either under the seat or the left rear side of the fuel tank if memory serve me correct.Fairly cheap part 20- 25 bucks.
Jul 24, 2009 | Razor Dirt Quad Bike
Razor Dirt Quad Bike Logo
3,520 people viewed this question
Top Razor Rock & Ice Climbing Experts
Betty L Kidd
Betty L Kidd
ray gallant
Makenzie Floyd
Level 1 Expert
Are you a Razor Rock and Ice Climbing Expert? Answer questions, earn points and help others
