Question about Ionic Pro TURBO Air Purifier
Take ionic pro apart to replace fuse
How to open ionic pro
No power is getting to model s1730 sharper image ionic breeze after taking it apart to replace light bulb. Is there a fuse in this model?
yes there is a fuse on the board located at the base of the unit...if that does not fix problem replace unit.. :)
Jun 21, 2014 | Sharper Image Ionic Breeze GP SI730 Air...
I can not open the door to clean the blades. When pushing the open button, the door does not open. Why?
Hi micheleyokum,
I work for the Ionic Pro company. Please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Feb 10, 2011 | Ionic Pro TURBO Air Purifier
How do you take the unit apart?
I work for the Ionic Pro Company. Please call customer service at 800-875-8577 and they will walk you through the steps. Thank you, Mary
Dec 19, 2010 | Ionic Pro 901P2RIP04 Air Purifier
Ionic pro turns off after one minute
Hi there. I work for the Ionic Pro company. Please call customer service at 800-875-8577 and they can do some troubleshooting with you. If they are unable to resolve it, they can give you the steps on how to get a replacement. Thank you.
Oct 19, 2010 | Ionic Pro TURBO Air Purifier
My wife wanted me to take it apart to clean it properly. we have the quadra which all of you know that it's impossible to clean. Well, after cleaning it, I noticed a fuse which is permanently in place...
You can replace the fuse by soldering a new one into place -- it's a standard fuse, just match the amp rating of old to new.
Chances are though, after you do this, it will blow again. So, there's a good chance the unit is kaput.
I have extensive experience with these units to the point of even replacing the high-voltage field wires (the two fine wires which run from top to bottom) with titanium wire. There is no real good way to keep these things running properly -- they're kinda like weed whackers -- inherently problematic.
Apr 20, 2009 | Sharper Image Professional Plus Ionic...
Ionice breeze quadra Model # S1637
had the same problem with ionic pro ca500. i took the unit apart and found a fuse that was blown and it works now. sorry but i don't know if there is any repair shops.
Aug 02, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Ionic pro compact and ionic pro turbo
The clean light stays on and purifier doesn't work but unit is clean.
Jun 09, 2008 | Ionic Pro Air Purifiers
My Ionic Pro doesn't turn on
i have taken the unit apart and found that if there is a broken wire you have to be a magician to fix it even if you had spare wires.
also found a small fuse in the bottom of the unit but it is soldered in. i am currently in the process of replacing and will post results asap.
Dec 12, 2007 | Ionic Pro 901P2RIP04 Air Purifier
Clean button
My ionic pro did the same, the red light just wouldnt go out, so I looked down the plate opening, (with unit unplugged), and could see one of the wires was broken. (these are the ones you clean by pulling up that plastic tab). I am currently looking for replacement wires, will post my progress. GregV
Oct 10, 2007 | Ionic Pro 901P2RIP04 Air Purifier
Ionic Pro TURBO Air Purifier Logo
91 people viewed this question
Top Ionic Pro Air Purifiers Experts
Paul Cox
Level 1 Expert
Shehu Pro
Shehu Pro
Thomas Perkins
Thomas Perkins
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
