Question about Brother International - MFC-9970CDW - MFC-9970CDW Wireless Laser
PRINT UNABLE EC
WHA T PCB IS BAD?
    Champion:
  • Brother Inte... Expert
  • 265 Answers
Your machine ventilation fan is not working, usually due to a foreign material being stuck at the fan or the fan is faulty or the PCB is faulty.
Posted on May 12, 2014
How to fix the error unable to print 4f
4F indicates printhead problem - either to replace the print head or the print head PCB.
Feb 13, 2015 | Brother DCP-J125
Mfc 7360 unable to print 7a
Error code 7A
A synchronized signal of the main motor cannot be detected.
Turn the power off and then back on again.
1 Flat cable connection failure of main motor
Check the flat cable connection of the main
motor and reconnect them.
2 Main motor failure Replace the main motor.
3 Low voltage power supply PCB failure
Replace the low voltage power supply PCB ASSY.
4 Main PCB failure Replace the main PCB ASSY.
Jan 14, 2015 | Brother MFC 7360N - Multifunction fax /...
My printer show error init unable 4f
Probably print head or the print head PCB is faulty.
Dec 09, 2014 | Brother DCP-J140w Wireless Compact Inkjet...
How can I fix DCP-195C unable to Init 4F?
Could be print head or print head PCB problem .
Sep 06, 2014 | Brother DCP-195C A4 Colour Inkjet...
Unable to print 36
Possible Reason:
1. High voltage power supply PCB
failure
---Replace the high voltage power supply
PCB ASSY.
2. Harness connection failure of high
---Check the harness connection of the high
voltage power supply PCB and reconnect
it.
3. Main PCB failure
---Replace the main PCB ASSY.
Aug 08, 2014 | Brother Dcp-7055 Laser Print Copy Scan...
Brother dcp7055 how to fix unable to print 36
Try these:
1. Replace the High Voltage Power Supply PCB ASSY.
2. Check the harness connection of the high voltage power supply PCB and re-connect it.
3. Replace the main PCB ASSY.
Jun 16, 2014 | Brother Dcp-7055 Laser Print Copy Scan...
Init unable 50
Set the maintenance unit into place, if the planetary arm does not
move smoothly, clean it. purge cam switch harness not connected correctly,correct the connection,purge cam switch broken replace the maintenance unit, gear(s) on the maintenance
unit broken paper feed motor defective replace the engine unit,
power supply PCB defective replace the power supply
PCB. Main PCB defective replace the main PCB.
Dec 02, 2013 | Brother DCP-195C Inkjet Multifunction...
Brother MFC-9440CN error 5A print unable
Error 5A unable to print is a problem with the high voltage power supply PCB, or with the engine PCB. A shop could tell you which one after some testing. Expensive repairs...
Jun 29, 2009 | Office Equipment & Supplies
Brother mfc465-cn unable to init 49
Error 49 relates to the print head drive voltage. It may just need the flat ribbon cables that connect the head to the main pcb reseating, but equally it may need the print head replacing (most likely).
An outside chance that the main pcb will need replacing.
In theory, all of these jobs are a task for an engineer. Brother UK (0870 830 400) can pass you on to a repair agent.
Jun 12, 2009 | Brother MFC-465CN InkJet Printer
Brother International - MFC-9970CDW - MFC-9970CDW Wireless Laser Logo
181 people viewed this question
Top Brother International Office Equipment & Supplies Experts
Gil Shultz
Ron Baird
 Andrew Henderson
Andrew Henderson
Are you a Brother International Office Equipment and Supply Expert? Answer questions, earn points and help others
