Question about Ovens
How to bake a cake in videocon eg2253p microwave oven
Baking a cake
hotuna
  • 288 Answers
SOURCE: GE Wall Oven - No heat (broil or bake)
On appliances like this only the heating elements use 220 volts. things like the clock, fan, etc use 110 volts. That is why some things work and other do not. Start at the breaker, sometimes a double pole breaker will have 1 side tripped, but will look perfectly fine. switch the breaker all the way to off then re-set. If nothing changes follow the power to the appliance remove the panel and look for some fuses, check to see if any are blown. Also sometimes the microwave will have a separate power source even though its built in to the same appliance. So that's not always a good symptom to follow.
Posted on Nov 11, 2007
SOURCE: mabe oven
Hi, well i have researched the mabe oven problem and it turns out that mabe used to make a 110V oven bake element for the ovens made in Mexico. However it appears that they no longer make that model oven and it's parts. Isn't that just golly gee terriffic!I am still searching for an element for it as GE who is also a share holder about 42% worth also has parts that sometimes will fit the Mabe made in Mexico, and not to be left out of the programe Camco is also part of the GE Mabe family so they are also a source to check with, and yes even whirlpool who is nothing to do with any of those other than a competitor sometimes has parts that will fit the Mabe made in Mexico. I'm not saying it will be a perfect fit but if it works, it works, but i'm not recomending you do it to a customers appliance at least not without asking if it's ok.
Posted on Feb 20, 2008
  • 42 Answers
SOURCE: Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Posted on Jan 26, 2009
SOURCE: Oven will not heat up on bake broil or convection cook.
I justn encountered the same problem (Model KERS507Y). Haven't checked yet...but am suspecting the Thermal fuse. Have you solved the problem?
Posted on Apr 09, 2009
  • 12 Answers
SOURCE: How to set the temperature on the KitchenAid Superba oven/convect
A separate oven thermometer is absolutely necessary in baking. Something similar to this would be cheap and easy. http://www.bedbathandbeyond.com/product.asp?order_num=-1&SKU=10161738
Or you could go for a digital one with a probe.
Posted on May 21, 2009
Which option will set for making cakes in danika oven?
Standard procedure with ANY oven to bake a cake: Start with Bake, end with Brol
Sep 11, 2015 | Ovens
Why do cakes sometimes collapse while baking?
helllo dis.... There are many things that can cause cakes to fall in the middle.... Jumping, etc., around the baking area is unlikely to be a problem except with very delicate sponge or angel food cakes. More likely, cakes fall when the crust appears to be done, but the batter is not baked through the middle. An uneven baking temperature is a frequent culprit; check the temperature of your oven with a separate baking thermometer, and be certain that your oven holds a steady heat through the entire baking period. Some older ovens preheat properly, then cycle off and drop the temperature after 15 or 20 minutes, which causes the uncooked portion of the cake to fall.
Less likely but possible problems could be inaccurate proportions of baking powder or baking soda if the cake is made from scratch. This could occur with cake mixes if sour milk or buttermilk is used instead of regular milk; the additional acid in sour milk requires additional baking soda to rise properly. Eggs that are not beaten properly, or perhaps beaten too much for the type of cake being made, might also cause problems. Joe
Mar 12, 2011 | Tecnik Ovens
I have an bajaj oven and im trying to bake a cake and everthg i bake it the sides of the cake get baked and the middle portion remains raw..ive tried all the up flame,down flame and also both the up and...
if your oven is gas its is very difficult to make perfect baking of of the uneven heating,if your oven is elecric is with convection that one good compare to gas oven on an electric oven without convection, the advantage of oven the with convection is even heating.
Dec 24, 2010 | Ovens
Best setting for baking cakes
good day,
hope this link below will solve your problem.
baking.
The best bread machine we've found for gluten-free bread baking. Programmable feature puts you in charge. Bakes a delicious 1.5 to 2 pound loaf every time. It has a viewing window, automatic settings for breads, cakes and jam, sourdough starter and programmable cycle that makes gluten-free bread in under two hours!
Aug 01, 2009 | Smeg SE250XUK Stainless Steel Electric...
KitchenAid Oven Temp.- Bottomside of Pizza or Cake stays uncooked
I have a 2yo Kitchenaid oven, and my advice is first, don't use convection for cakes or pizza. Use the thermal oven. For pizza preheat to 500 degrees, then put the pizza on the lowest rack, and bake for 7-8 minutes.This way the bottom browns, and the top doesn't get broiled from the top element coming on during the bake cycle.
As for cakes, again place them on the low rack so that they get bottom heat. I keep my eye on the oven and when the broil element comes on I stick a piece of foil over the cake until it goes off. Otherwise it will set the top and the cake won't rise as much. Even doing that cakes don't rise as much as they did in my old oven, and they brown too much on top.
The convection oven does a good job of cookies, and the broil mode is okay.
I wish I hadn't bought this oven, but I didn't know about the upper (broil) element coming on during the bake cycle until I'd had it for awhile, and it was too late to return it.
If anyone's shopping for an oven, ask questions, and don't get one that maintains the oven temperature by activating the broil element when baking.
Jun 24, 2009 | KitchenAid Architect ® II KEBS208S...
OVEN NOT BROWNING CAKES
put dynamite in container. if it blows up, too bad
Apr 12, 2009 | Jenn-Air JGW8130A Electric Single Oven
Apr 08, 2009 | KitchenAid Architect Series KEBC107KSS...
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
46 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
