Question about Jensen Vm9214 Car Video Player
Aftermarket harness have a harness not sure if wirexs match up so i need a pinout diagram
NEED WIRING DIAGRAM
If you are referring to installation and have the aftermarket wiring harness, The wires should be color coded. RED, YELLOW, & BLACK are power, ignition and ground. These should correspond to matching wires on the back of the head unit (CD player). Match the colored wires from the back of the unit to the same colored wires on the aftermarket harness and then connect them using wire connectors/wire nuts. Once you have them into the correct order the aftermarket harness should connect into the harness in your vehicle. I hope this answers your question =)
Nov 05, 2013 | JVC AM FM CD DET FACE CAR STEREO
I need to change the head unit in my 1990 Buick Century, but the wire harness the mechanics gave me doesn't fit?
The connectors for all GM oem radios for this car/year are the same. The place that sold you the new radio should be able to provide a patch cable with a connector at one end that fits the aftermarket radio, and one or more connectors at the other end that fit into the connectors in your car. If you can't get that patch cable from them, try sonicelectronix.com. These cables are usually unique to the brand of your aftermarket radio. Although it's a bit late, It's a good idea to check that these patch cables are available from the seller before buying the radio.
If you can't find a patch cable and the cable that came with the new radio has no connector(s) on one end, you will need to splice those wires to the correct wires going to the old radio connector, and for that you will need the wiring diagram for both your car and the new radio. You should be able to get the wiring schematics for your car from Alldatadiy.com, and your new radio should have come with a connector pinout description.
Mar 08, 2017 | 1990 Buick Century
Need wiring harness color coded diagram for pioneer dehp3900mp
Hi, the wiring diagram is at the back of the manual. This unit has the standard wire colors for all aftermarket head units. Please get back to me with the car model and year if you need to know the car wire colors to match up.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/130/130DEHP390.PDF
Nov 20, 2011 | Car Audio & Video
I need the wiring diagram for a dual stereo model xd1225 to hook it up to a 1986 ford f150
OK, for starters, get a wiring harness made for your vehicle. All aftermarket radios have standardized wiring colors. You wiring harness will have matching colors, so it will be easy to hook up. The harness will also have the diagram of colors on the package. However, you vehicle wire colors will not match this. That's why you have the harness. You will just plug into the stock vehcile harness. You will not have to match any wires because the harness is specifically made to match your vehicle. Trust me, it's easier this way. You can find them all over, try www.crutchfiedl.com to get one if you need. Hopd this helps.
Aug 23, 2011 | Car Audio & Video
I need Only color coding for wiring diagram for cdx-gt550
If you are planning to install your radio, I recommend you purchase a wiring harness specific for your vehicle. All aftermarket radios are standardized in wiring colors. The harness will have the diagram to hook your radio to the harness. The problem with hardwiring a radio is the wiring colors don't match, and hooking it up wrong could fry your entire electrical system. You can find a harness at www.crutchfield.com Hope this helps.
How to connect a Hyundai car radio to my Toyota ute
This is most likely impossible if either is a late model vehicle. As far as wiring you will need to cut the factory Radio harness out of the Hyundai, you will also need a wire diagram for the Hyundai. You will need to buy a harness designed to install an aftermarket head unit into the Toyota, the new harness will come with a description of which wires perform what function. You will then need to match these to the wires on the harness cut from the Hyundai using the diagram. Even if you do all this other hyundai radio will not bolt in where the factory Toyota radio was, and there is no adapter made for something like this. I would suggest just buying an aftermarket stereo. It will be MUCH easier and will almost definitely sound better than a stock Hyundai unit.
Mar 11, 2011 | 2002 Hyundai Accent
Wiring diagram
My fault meant this as a solution post....
What do you need the diagram for? If your installing the radio, you do not need a diagram you need to go purchase the wiring harness for your make and model and year car. Match the colored wires together to the ones on the back of the head unit then connect them, then that harness plugs into your stock car harness that your stock radio unplugged from. You also probly need an antenna adapter cable that just connects to your stock antenna cable to add length and then plugs into your aftermarket radio. If you need a wiring diagram because you are trying to open you radio and fix it because it is broke or something...good luck to ya. Hope I helped... :)
Dec 15, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
Stereo diagram for 1990 geo prizm
Hello stoogieprezi,
You should have gotten a plug-in harness with your new Alpine. To avoid cutting or tapping the wires on your vehicle, you need to purchase an aftermarket wiring harness. It appears that the Metra 70-1782 is the correct one for the 1990 Prizm.
Then you simply match up the wires on your Alpine harness with the Metra harness. The wiring color code for the harness is shown on the bottom left of the "description" tab and matches up with the Alpine color code on page 18 of your owners manual.
Hope this helps.
Jun 10, 2009 | Alpine CDM-9821 CD Player
Need a wiring diagram for my 92 volvo 940 gl
Go to the following site and enter the make and model of your vehicle and it will give you a free diogram of the wiring to your stereo. The colors do not have to match up.
Apr 04, 2009 | Dual XDMR-7700 CD Player
Jensen Vm9214 Car Video Player Logo
37 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
