Question about Riso RZ220 Duplicator
Error A34-218 Even if I reset the Master error A34-218 still remain
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Dec 14, 2014 | Minolta Office Equipment & Supplies
Service code interrupt
Error type T11 [Pressure-control motor lock]
T11-***
!!System Error!!
Press Reset Key
If Recovery has Failed, Call Service
Reset method Jam reset or switch on power again
Error point Error conditions
600
Timeout error for reducing pressure (OFF -> ON) during print-pressure home
positioning.
601
Timeout error for increasing pressure (ON -> OFF) during print-pressure home
positioning.
602 The print-pressure limit sensor does not change during print-pressure operation.
620 Print-pressure operation was called with the print-pressure motor locked.
621
Incorrect print-pressure operation timing (print-pressure operation command was
received when the print-pressure should not change).
622 Sensor A is ON and sensor B is OFF during movement from area A to area D.
623 Either sensor A or sensor B is ON during movement from area D to area A.
624 The current area data is undefined.
625 The target area data is undefined.
626 Timeout during relative print-pressure movement.
Error type T12 [Master-disposal-section motor lock]
T12-***
!!System Error!!
Press Reset Key
305
The master compression sensor does not go ON within 6.5 s after the master
compression motor operates in the return direction.
306
Master compression sensor does not go OFF within 2 s after the master
compression motor operates in the compress direction.
307
compression motor operates in the compress direction, and the mastercompression-
motor limit sensor cannot count up until the compression-limit
position.
309
The master-compression-motor limit sensor does not change within 200 ms
during compression operation.
hope to be of help
Sep 27, 2013 | Riso RP 3700
System error T01-521
Error type T01 [Main-motor lock]
T01-***
!!System Error!!
Press Reset Key
520
The main motor limit sensor does not go ON/OFF for more than 16 pulses while
the main motor is operating, even after the elapse of 100 ms.
521
The position-A sensor does not go ON/OFF, between two detections of position-B,
while the main motor is operating.
522
The position-B sensor does not go ON/OFF while the motor is operating, even
when 3033 pulses are received at the Main FG.
524
The clamp unit is not at the home position while the print drum is operating
(Clamp sensor C: OFF, except during master disposal).
536 The drum failed to stop at position A. (over-run)
537 The drum failed to stop at position B. (over-run)
538
The print
Sep 24, 2013 | Riso RP 3700
I forget my security code of nokia 7610 in m,y cell " lock phone if sim is chenge is activated so icant use any other sim i format my set by press * 3 on switch but phone code remain same. wat can ido...
If you forgot the security password, then you need to master reset the phone. You can get free master reset online. I recommend you to visit the site Unlock-Free.com where they are providing master reset code for certain Nokia DCT phones
Jul 11, 2011 | Nokia 7610
My nokia 5130 giving code error message when i enter the right code.i tried master code even but doesnt work.plz help me i cant go to nokia customer center
My suggestion to try this website http://www.unlocking4free.com/nokia-5130 and get the master reset code for your mobile at free of cost.......
Because i got many master reset and unlock code at free of cost.... And that codes are working well without any problem... So that i suggest this website to you and get the master reset code for your mobile.......
May 13, 2011 | Nokia 5130 Cellular Phone
My N73's phone memory is apparently full with nothing in the phone memory. ... i erase the NEF folder in the phone memory, but this time problem is still remained. How should I recover it ? pls.
You can Unlock the Mobile from the Security or Password Lock Using the Master Reset Code.You can get the Master reset Code at here
http://www.superunlockcodes.com/unlocking-services/rs12wp6/ I Unlocked my mobile From Security Lock using the Master Reset Code,You can Check Code for Your Brand Mobile and Model there.....
Dec 04, 2010 | Nokia N73 Cellular Phone
Reset master cylinder with ABS system
Disconnect the battery negative with the ignition key on and the engine not ON, only instruments on dash and radio on, connect it back on after two or four minutes, do not panic if You see sparks coming when you connect Battery back is normal, *** it well turn key OFF and start the car back an see, if problem remains, with key on press accelerator pedal 10 times fast and check if problem remains, contact dealer
Jan 22, 2009 | 1994 Pontiac Grand Am
I get a camera error start on my lg shine
dear,
switch off ur mobile and restart it . if nothing happens then do a master reset and then check it again.
beware of stored data loss
if the condition remains the same and open your mobile and check the plug of camera inside the mobile.
maybe due to some shock or hit , connector become loose ..
regards,
Aug 14, 2008 | LG Cell Phones
Riso Rz 220
Remove the master that is on the drum. Then check the master roll remove it cut about 18 inches off then re install master roll. hit the reset, then print bottons.
Jun 11, 2008 | Riso RZ220 Duplicator
Problem in games & applications
unable to open games and applications folder.- error is showing = "operation failed " kindly help
May 07, 2008 | Sony Ericsson K550i Cellular Phone
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Igor Studennikoff
Igor Studennikoff
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
