Question about Huawei Pinnacle Metropcs Phone
Arrow and center button wont work
My buttons randomly stopped working how do I fix it?
Monitor wont stop cycling through menu, its as if one of the monitor buttons were held down. as best as i can tell none are stuck. even after unplugging the monitor, as soon as it is plugged back in, it...
Sounds like a Philips. Had same problem. I used the actual arrow buttons on the monitor itself and while it was scrolling I kept hitting the arrow the opposite direction of the "scrolling" it locked on my PC signal. I can't use the remote or see my surveillance DVR at least I can use my PC. Oh I smacked it real hard the angrier I got! Funny thing it's worked fine for 5 days now. Just Sayin'
Jun 27, 2017 | Neovo F 415 (Black) 15" LCD Monitor
My M1210 stopped working. Wont boot up I get no
Try these steps
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
Jan 26, 2010 | Dell XPS M1210 Notebook
Problem for Sony SDM-HS75/B (Black) 17" LCD Monitor Menu buttons don't work but menu randomly appears
Try this:
Under the menu options, there's Menu Lock. Switch it to "On". It worked for me.
My menu button wasn't working, so to access the menu, I had to hold down the arrow up button and push the arrow down button till I got to the Menu Lock Option.
Dec 30, 2009 | Sony SDM-HS75/B 17" LCD Monitor
Volume Menu appears randomly; buttons 2-4 don't work reliably
Once you can try providing "reset" option from the menu .... This will solve most of your problems ..
Jul 25, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Vcr stopped working. Time blinks whenever I press any buttons.
I took the cover off the vcr pushed on some random parts, blew some dust of it, and put it back together. It worked.
Mar 20, 2009 | RCA VR555 VCR
My buttons wont work
i think the moisture has entered into the keypad sensor where it must have shorted the leads on the keypad board...
you should remove the keypad layer and make it dry thoroughly..
i would advise to take it to the service center for curing the keypad asap....if the phone is under warranty you can take it to the customer care
Jul 13, 2008 | Lands Phones
Printer busy message
See if this works:
Turn computer off
  1. Power off the printer.
  2. Close all printer covers and doors.
  3. Hold down the uparrow.jpg and downarrow.jpg (up arrow and down arrow) buttons on the printer and power the printer on.
  4. Release your fingers from the buttons when the message Diagnosing... appears.
  5. When Customer Mode and ESS Diag display, press the downarrow.jpg (down arrow) button until Test Print appears, and then press the select (center) button.
  6. Press the downarrow.jpg (down arrow) button until ContaminationChk appears, and then press the select (center) button twice.
  7. After the LCD displays Busy and the printer prints the ContaminationChk pages, power off the printer and power it back on.
Jan 20, 2008 | Dell 924 All-in-One InkJet Printer
Samsung- SGH-D820 key problem
Contact problem more common with any phone. Simply problem, somtimes you have to take a part the phone clean it, dry it to fix that.
You can buy a special cleanig solution for wather dammage from ebay if you realy want to fix this alone.
But if you hawe waranty, use ti!!!
Nov 11, 2007 | Samsung SGH-D820 Cellular Phone
Ink cartrige wont work
press menu then start mono then arrow up button 4 times.
machine will be in mainténance mode. press the arrow up button until 7 is displayed. press menu. press arrow up til 6 then press menu. press arrow up til 3 Dispaly shows powerp_all press start mono. machine runs a power purge. after that press arrorw up til 0 press menu press arrow up til 9 machine will print test sheet. In case you dont have a good result do the power purge again. If you dont get a good result after 3 times purging, the printhead is clogged and cant be fixed anymore!
to leave the maintenance mode press arrow up til 9 then menu then arrow up til 9.
Nov 05, 2007 | Brother DCP-110C All-In-One InkJet Printer
Huawei Pinnacle Metropcs Phone Logo
15 people viewed this question
Top Huawei Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Danny Kuhlmann
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
