Question about Philips Televison & Video
Bulb replacement need the part number for bulb on 51f710g
I have a vintage 1950-1960 Mansfield industries slide projector model A-35. I need a replacement bulb. Any idea what bulb this would take?
The number you need is either on the glass bulb or on the metal base of the bulb Look on the access cover to see if the replacement number is there, too.
May 15, 2017 | Office Equipment & Supplies
Hitachi 51f510 relay clicks once and back off no power
Needs new power supply http://www.ebay.com/itm/Hitachi-Power-Supply-51F710G-51F710A-UE25782-JT25022-DP5X-/271493729980?pt=US_TV_Boards_Parts_Components&hash=item3f36498ebc $39.95
Or fix the existing one. Take it out, look for blown or misshaped (puffed-up) capacitors. Unsolder and replace the obviously blown one(s) - $2 or so at Radio Shack for the parts.
Jul 26, 2014 | Televison & Video
Replaced bulb works most of the time, I'm thinking some sort of thermostat that tells the bulb to turn on. I just need a part numbers or other ideas
Hello
Are you need its service manual? Only service manual will have all part numbers and schematic diagrams. If you are in need of it, inform me please.
Dec 10, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
Hi I need a replacement bulb for my WS-55411 Mitsubishi. Can you help me find the right bulb and it's part number? The screen blacked out and sound still works so I assume I need a new bulb. When I shop...
Your model doesnt have a bulb since its a rear projection TV . It has three picture tubes, However loss of video with audio still working is usually caused by a vertical output failure.
Jul 28, 2010 | Mitsubishi WS-55411 55" Rear Projection...
What type of brake light bulb do I need for a 95 geo prizm?
Take the old bulb out, there will be a number on the bulb, you can take that number or whole bulb to any parts store to have it replaced. '
If there is no bulb, again a parts store can look up the vehicle and get the correct bulb replacement
May 25, 2010 | 1995 Geo Prizm
How do I replace the lamp? Do I need just the bulb, or also the housing?
just the bulb.. write down the model number of the unit and they will give you the same bulb that you need, just give them the model number.
If you are going to install the bulb just remember DO NOT HOLD directly the bulb, use any clothe or gloves, because even a fingerprint can busted the bulb even thou it's not yet use
Nov 08, 2009 | Sony XL-2100U Projector Lamp for...
Replacement bulb
There are numerous sources on line which will find the right replacement bulb based on your model number.
Jun 14, 2009 | Toshiba 52WM48 52 in. HDTV-Ready...
Need to fix lights on number plate on 1.3 3dr gl
hi from uk the number plate lights x2 are on same fuse as side+tail lights so if n/plate is not lit ?more likely bulbs have blown ? to access remove the panel from boot lid (clips+screws) then you will see rear of n/plate lights the bulb holders twist anti clock slightly and pull out replace bulbs with same type 5watt check all work b4 refitting panel
Feb 05, 2009 | 1999 Hyundai Accent
Need part number for oven bulb
looked up the bulb part is no longer available, but it looked like a regular appliance light bulb, remove the old one no diffrent then any appliance bulb you can buy in the supermarket if need be
Feb 19, 2008 | Ovens
Televison & Video Logo
15 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
