Question about Westinghouse Microwave Ovens
Westinghouse dsk965sng The 2 left side top ignition wont ignite.
I think this is a problem that I can handle, but would like to know the specifics on how to install the oven igniter (part #816625) onto a Whirlpool oven (model #sf385peyw3).
Igniters are pretty easy to change out. Just make sure the power is off and that you do NOT bend the igniter bracket. Also clean the connection with either a green scouring pad or a #2 eraser before connecting.
Just take your time and don't get distracted and you will be fine.
Jul 20, 2011 | Microwave Ovens
I got the automatic ignition on the stove top wet last night and it will not ignite the gas
I always wipe the area with a paper towel. The I turn on the gas and ignite it with a match or lighter. Let it run for a little while and it should dry out the ignition so that it will light automatically the next time, I hope this helps. You may have to do it two or three times to assure it's completely dry and capable of lighting.
If this helps, please come back to Fixya and rate my solution!
Jul 14, 2011 | GE Microwave Ovens
The igniter will come on but no gas, the broiler and stove top both work. I'm and hvac service tech and need some help.
you will either have a weak ignitor or you have a bad safety valve, but before you go buy any thing take the igniter from the broiler and install on the bake and see if works, if works you know it is the igniter, if not it will be the safety valve (fyi you can also turn on oven, then when igniter gets really orange you can tap the safety valve and if it ignites it will be safety valve)
Feb 24, 2011 | Microwave Ovens
I have a jenn-air stove The igniter went out on all 4 eyes on the cook-top
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Dec 25, 2010 | Microwave Ovens
When trying to light oven or grill the clicking of the ignition does not stop! Any ideas? Parkinson cowen chichester thanks
your oven switch is sticking, causing the clicking, if you can open the range top to see that switch, i would pull off the wire to that, until you can have it replaced
Dec 19, 2010 | Microwave Ovens
Top left burner (propane) does not seem to be receiving gas when trying to ignite it with electrical igniter (control knob). However the burner can be lit with a match when the control knob is turned past...
The igniter usually sparks for all burners on the stove at the same time. Usually a little water or gravy, or such has gotten on the little spike that stick up and throws the spark to the burner. If you will take a small brush, like a tooth brush and carefully clean around the little spike it normally starts sparking again. As it is right now, you should be able to see the spark on all the burners whenever you start any of the burners. Check to see on the one that is not lighting, I think you will find that it is not sparking at all right now.
Sep 21, 2010 | Microwave Ovens
Westinghouse oven we have and the fire doesnt light up when you turn it on the grill we have works on it but the oven doesnt
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Jun 16, 2010 | Microwave Ovens
GE Profile microwave remove top grill
1. Unplug power.
2. Remove two screws holding grille, either on top of the front edge of the outer case or in the grille itself.
3. The grille should lift right out. In not, you may need to pull it to the left about 1/4".
You can download GE owner's manuals and installation instructions here.
Some models have them on top.
Feb 04, 2009 | GE JVM1750SMSS Microwave Oven
Light bulb
If you are comfortable with taking the cover off, Unplug the microwave, usually there are 2 philips screws on the top back, 2 on the right back and 2 on the left back edge cover. Sometimes, their might be a screw on the bottom but you will notice this right away if there are or not if the cover doesnt come off.
Then located the light bulb. You should be able to see the opening from inside the microwave where the light bulb is located.
Once you locate the bulb, then there are usually 2 types, type 1 screws in and the other type is a bayonet type, which you push down, and then twist. You should be able to figure this out.
Sometimes there is a plastic cover that is placed around the bulb to kinda help focus the light towards the inside of the microwave.
Once the bulb is out, then take it to your local hardware store and see if they can match it up. You might want to call first to see if they carry them before driving all over the place.
Hope this helps.
Good luck.
If i have helped you with you question, then please remember to post a feedback and a rating.
Thanks.
Mac
Feb 19, 2008 | Westinghouse WST3504 Microwave Oven
Microwave Ovens Logo
16 people viewed this question
Top Westinghouse Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Westinghouse Microwave Oven Expert? Answer questions, earn points and help others
