Question about OfficeMax Heavy Duty Staples
Heavy duty stapler jam
Staple stuck
How do I prevent Rapid 5080e stapler from jamming
Make sure that the tray for the staples is clean and LIGHTLY oiled, Staples are held together with glue. IT could also be an issue with the wear on the staple head driver. If you use it a lot, the unit might be worn to the point that it is out of spec.
Aug 28, 2015 | Rapid 5080E HEAVY-DUTY FLAT CLINCH...
How do you fix staple jam?
You may have to open up the stapler to expose the loading area then look for staples (or staple fragments) jamming the nose. It may be necessary to resort to pliers to remove the bits.
Aug 09, 2014 | Bates Power Arm Extra Heavy Duty Stapler...
Stapler malfunction
I don't know, but check how frequently the stapler jams.
Dec 10, 2013 | Panasonic AS-302NN Electric Stapler Heavy...
900XDN-C SWINGLINE HIGH CAPACITY HEAVY DUTY STAPLER OPERATIONS MANUAL
auto parts store sells a pick with straight on one end and 90 degree on other end.
This should be slender enough to pull staples out.
Mar 27, 2013 | Tools & Hardware - Others
Handle stuck in locked position
One of the screws - furthest away from where the staples exit - has a nut on it... Remove the nut, then - using pliers - back out the screw. When I did this, the spring returned, a bent staple fell out and once re-assembled I could use the stapler again (for a few turns). It seems like the stapler is VERY sensitive to bounce during the stapling, you must hold it very tight (and flat) to the material so that the staple doesn't jam inside the stapler. Lousy product.
Mar 16, 2013 | Powershot Tool Company PowerShot 5700KB...
Heavy Duty Stapler will not stapler
are any staples jammed? try stapling something to see if it works, :)
Aug 01, 2012 | Tools & Hardware - Others
I bought a Powerfix Profi hand stapler from Aldi store but cannot get replacement staples. There is no support from their website
You can use about any replacement staples from a D.I.Y. store:
8mm staples or 12mm U-type staples or 10mm T-type nails
Nov 03, 2011 | Tools & Hardware - Others
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
Instructions on unjamming swingline electric stapler model 270; jam is at the front of the stapler; staplers come out either broken, flaten or crooked and does not secure document.
First, are you using the recommended staples for this stapler? Many heavy duty electric staplers don't use "standard" desk staples. Second, try unplugging the stapler, unloading the staples, and if possible, reach a couple of fingers into the stapler and try manually pushing up on the staple head to see if you can get the driver blade to come down. Does it come down smoothly, or does it seem like there is something stuck in there? If you aren't sure about disassembling the unit (my usual method-but I'd recommend having the parts diagram handy), try using a flashlight to look at the underside of the staple head, where the staples come out - can you see anything stuck in there? If so, you might be able to use a small knife blade or small dental pick to get jammed staple pieces out.
Mar 03, 2009 | Staples Swingline® 36115 Staple Guns Tools...
OfficeMax Heavy Duty Staples Logo
27 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
ROCKIT957
Randy Schumann
Randy Schumann
Colin Stickland
Colin Stickland
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
