Question about Wacom Technology Wacom Stu-500 Lcd Signature Tablet - Signature Reader - Usb / Rs-232
No drivers on PC for stu500b. what drivers do i need to work the stu500b?
What windows 7 ultimate drivers do i need for it to work with pecision workstation 670
You will need audio driver, possibly Network adapter driver and in some cases you may need to find the manufacturer of your optical drive by pulling out of the case to get model type and then the the driver from the manufacturer's site. Finally a chipset driver. check this site for most of the drivers.
http://www.dell.com/support/drivers/us/en/19/product/precision-670
Apr 23, 2014 | Dell Precision Workstation 670 PC Desktop
I DONT HAVE INTERNET CONTROLLER
go to acer.com to get the driver for the device easy work ...to hard work is gettin the driver to the pc who need the driver ...and if you have problems reading the driver from the pc its cause the pc needs a new net framework....then it will be able to read the file....that happens to alot of dells ....
Apr 06, 2011 | Acer Broadcom BCM440x Ethernet Adapter...
Webcam not working after Os reinstall
You need to install suitable drivers for the webcam to work. Go to ASUS site and download drivers for your notebook. your webcam will work fine after the installation of the driver.
Dec 20, 2010 | ASUS Eee PC 900 PC Notebook
IBall Baton 150M Wireless-N Router driver
iBall Baton 150M Wireless-N Router or any routers do not need drivers to work on your PC. Just the configurations settings provided by your ISP account.
Only Wireless adapters ie PCI or USB interface needs drivers for the device to work on your PC.
Here is a link pdf help file to help you configure your router to work on your PC/Laptop.
Hope it helps.
Dec 05, 2010 | Computers & Internet
I need all the drivers of sharp mebius pc-x2001
donwload all the drivers from the link below:-
http://www.notebook-driver.com/sharp/sharp-mebius-pc-um32w-driver/
Let me know if it works.
Remember all the drivers available is in ZIP form you need to extract it First.
May 10, 2010 | Computers & Internet
LG KP220 PC SUITE?
Finally, after spending 2 days on this issue, I am now able to back up my phone book on LG KP220 to my PC!  Hurray!
I have now used the pc sync software on Windows Vista as well as Windows XP (SP3) without any issues.
For Windows XP (SP3): ----------------------------------
After installing the driver, all you need to do is make sure that USBSER.SYS file has the following specs:
Size: 22,768 bytes     Version: 5.0.2195.4858
The newer one (which has the following specs) does not work and needs to be replaced with the older one with above specs.
Size: 26,221 bytes      Version: 5.1.2600.5512
(yes, for some reason, the older version works and newer does not)
For windows vista: -------------------------- When you first connect the phone in COM mode, let vista download the driver from the internet.  Then run PC Sync and viola it'll work!
For both: ------------ For running as a USB flash drive (data mode), you don't need any driver in either o/s. For running as a COM port (phone mode), you need a driver and a software.  The driver I'm using is USBSER.SYS and the software is called "Phone Suite" by MediaTek.  I've also tried a slightly older version of the same software called "PC Sync Manager" and that also works.  Other software should also work, as long as the driver is working correctly!
If you still need any help, drop me a mail at amoizpatgmaildotcom (you know what to do with "at" and "dot")
Feb 02, 2009 | LG CU500 Cellular Phone
Cannot install Drivers for IBM computers
lets start with the ThinkCentre A50 8175. download and install the chipset drivers first.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-60642
after you reboot install the network driver.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-55649
If this works rate me and we will continue
Jun 03, 2008 | IBM NetVista PC Desktop
My usb won't work on my pc. What driver do I need to make it work? It is 2.0gb
if you are using windows 98 then you have to install the driver.in xp no need of drivers.try your usb in another pc if it is working then you should try in all the ports.please post your findings so that we can help you more
Apr 05, 2008 | Computers & Internet
Need a driver for PC-CAM 350
Comment by mimhb, posted on Feb 20, 2008 my PC-CAM 350 purchased on 2005 at the beging it was worked well and recently I upgraded my PC due to virus, after that I don't have that Orginal installation CD for PC-cam 350 because it was missedplaced, also there is more problem in that pc cam showing in error messege and some numbers are displaying in the screen, when connect to the PC it camara screen dispaying NO. 15, and I try to Make Photo or Video its not working, please help me what is the problem and how to solve this problem as soon as possible. thanks
Sep 12, 2005 | Creative Labs PC-Cam 350 Digital Camera
Wacom Technology Wacom Stu-500 Lcd Signature Tablet - Signature Reader - Usb / Rs-232 Logo
49 people viewed this question
Top Wacom Technology Computers & Internet Experts
David Payne
David Payne
Are you a Wacom Technology Computer and Internet Expert? Answer questions, earn points and help others
