Question about Tensor 2 x 3W LED Desk Lamp
Tensor lt638 cord missing plug
The plug on the end does not look like a regular plug is it missing something
Tensor Desk Lamp with magnetic off & on switch stopped working. How can I fix this
Do you have the model number? This is most likely not the switch. There is a problem with the power suppply. IT uses capacitors that have been substandard and may have failed.
Dec 04, 2013 | Tensor 2 x 3W LED Desk Lamp
Have acer one message says to plug into ac adapter
Check the AC adapter and power cord. It sounds as if either one end of the cord near the transformer box is loose, or the end that plugs into the computer is loose/not connecting properly.
Failing that, make sure the wall socket you have the cord plugged into has power (try plugging something else into it). If everything I mentioned checks out, there could be something wrong with your battery.
Mar 23, 2012 | Acer Aspire One D255 Netbook
I need a replacement cord for my printer, I have the power cord I need the one with the phone jack end that plugs into the printer. Where can I get one?
That would be called an "ethernet" cord, especially if it looks just a little larger than a regular phone cord end and the cord itseld seems just a bit larger, too. It can be found at any major office retailer like Staples, Office Max....ad infinitum.
Regards,
Selk
Oct 19, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Need to replace the pull cord assembly, because something that tension the spring is missing. Tried substitute cord but found after reassembly there was no tention on the cord something is missing.
When the cord breaks, the internal spring will completely unwind. You have to re-tension the spring, then attach the cord and wind it onto the spool while holding the spool against tension. Finally, feed the end of the cord out through the cord port and tie the handle while still holding tension. A small pair of Vise Grip pliers will hold the cord while dealing with the handle. It's about like setting a trap without getting your fingers caught. Hope this helps!
Jun 07, 2010 | Craftsman sears 18" Chain Saw Chain (...
I have brought the printer with me to use in our 5th wheel- I am trying to hook up- I have 2 cords- beige cord for printer to computer- power cord -3 round openings- where do I plug in??? There is an open...
I believe you're missing the power supply for the printer. The 3-prong power cord plugs in to the power supply. If you lost that part of the printer, I can only advise you to call Lexmark. They might be able to send you one.
Apr 05, 2010 | Lexmark X5470 All-In-One InkJet Printer
No dial tone on a nec dtu
The NEC phone is probably a business multi-line digital phone, requiring a phone 'back-end' system. Will not work on an analog 'home' phone line.
Feb 16, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Missing power cord Balance 2019 model F 192 input 15v 4a 3 prong
what type of plug is on the monitor???
if it is not a regular AC plug, then it need a tramsformer and a vendor plug.
Oct 05, 2008 | Televison & Video
Ethernet cords
The cord that plugs into the DSL filter is a phone line and the other end plugs into your DSL modem. Also, every other jack that has a phone or fax or answering machine or caller id box has a DSL filter as well, in between the jack and the device.
May 01, 2008 | Kensington Portable Ethernet Cord (33052)
KDS RAD-5 monitor set up
THE POWER SUPPLY PLUGS INTO A WIRE STICKING OUT OF THE END THAT PLUGS INTO THE COMPUTER
Apr 15, 2008 | KDS RAD-5GS 15" Flat Panel LCD Monitor
Tensor 2 x 3W LED Desk Lamp Logo
220 people viewed this question
Top Tensor Home Experts
Donni Steen
Tom Chichester
Are you a Tensor Home Expert? Answer questions, earn points and help others
