Question about Nikon COOLPIX L20 Digital Camera
LAPTOP WILL NOT COME OUT OF 'SLEEP' MODE
My laptop LENOVO T61 will not come out of 'sleep/hibernation' mode...
when I try to start it immeadiately goes back to 'sleep'...all I have is black screen
  • 1,170 Answers
Turn it on, then wait, u will hear the computer turning itself on and off, but nothing is showing on the screen. so make it turn on and off, 3 time.( such as hearing the computer turned off, so that one,THEN IT TURNS ITSELF ON AGAIN, next time it turns off, that count as 2, and so on). on the third shut off then u press and hold the off button, to force it to shut down, then wait. about 5-10min., or less then 5. after then u turn the computer on.it should be on by now. if not try it again. if it happens again try one more time, if it happens again. then there something really wrong with your computer.
Posted on Jun 15, 2009
How to open hp laptop in sleep mode
This is a common problem on HP computers but also has many causes. If your laptop is not coming back on after being put into sleep mode, it could be a software issue among a few other things. If your computer has a hibernation mode I would suggest using it to get around the sleep mode issue. This mode will save everything the way it is and shut down completely. When you restart the computer it will open up just as you left it. Just like sleep mode except with a restart. This does not solve the sleep mode problem but easily provides a power saving alternative to it.
Jun 25, 2013 | HEWLETT-PACKARD HP Mini 5101 Netbook
Cant get power saving mode off
Step 1:
Sleep Mode b> Sleep mode is primarily used with home computers (desktop computers). Sleep mode is designed to save the current work, programs, and settings of your computer using your computers memory, while using very little power. b> Hibernate Mode b> Hibernate mode is primarily used with laptop's. Hibernate mode is designed to save your computers current state on to the hard disk, then turn off your computer to stop using power completely. This mode is usually used when you do not plan on using your laptop for an extended amount of time. Benefits b> Using Hibernate mode is more power-efficient, but files may become fragmented over time by using this mode frequently. Sleep mode does consume more power, but the advantage that Sleep mode has over Hibernate is that it does not take as long to resume your computers former state when you are ready to continue using it.
Feb 23, 2013 | Lenovo 3000 Computers & Internet
Acer one with windows 7 ultimate fall into sleep mode
A laptop computer is typically set to conserve battery power. One of the common settings called standby, sleep mode or hibernation turns off power to the screen and the laptop itself after a preset time limit passes without any mouse or keyboard activity. It can be inconvenient for the computer to shut down while you're working on an open page or during a download. Change the setting if you don't want your laptop to going into automatic shutdowns
Turn the laptop computer on with the power button if it's not set to turn on upon opening. Allow the system to boot up. Open the panel for adjusting the sleep settings. This varies among the popular versions of Windows operating systems. To change the sleep mode setting on a laptop running Windows XP, click the "Start" button, and click the "Control Panel" selection. Choose the "Performance and Maintenance" selection, and click on "Power Options." Click the "Power Schemes" tab, and click the drop downs next to "Turn Off Monitor," "Turn Off Hard Disk," "System Standby" and "System Hibernates." Select "Never" for each drop down in both the "Plugged in" and "Running on Battery Power" columns. Click the "Hibernate" tab and click to remove the check mark in the box next to "Enable Hibernation." To change the sleep settings on a Windows Vista laptop, click "Start," "Control Panel," "Systems and Maintenance" and "Power Options." Then click "Change Plan Settings" under the currently established plan. Click on the "Advanced Settings" tab and select the "Never" option on the "Sleep," "Sleep After," "Hibernate After," "Display" and "Turn off Display After" drop downs. Click the "OK" and "Save Changes" buttons to confirm the settings. To change the sleep settings on a laptop running Windows 7, click the "Start" button, choose "All Control Panel Items," select "Power Options" and click "Edit Plan Settings." Click the drop downs for "Turn off the Display" and "Put the Computer to Sleep." Choose "Never" for both and click the "Save Changes" button.
Feb 06, 2013 | Acer Aspire One PC Notebook
Disable sleep mode msi wind
Go into power options, select hibernate, uncheck box on left and click apply.
May 16, 2012 | MSI L1350430US Netbook
My dell Studio laptop takes too long to wake from sleep mode and the monitor just flickers when i try to switch on
If you use Windows 7, u might have hybrid sleep activated. This is similar to hibernate. When u choose SLEEP, your computer goes to hibernate. Sometimes this hibernate just hangs. You have to reboot computer.
Try pressing the power button for several seconds (10-15). It should power off the laptop.
If not, unplug the charger and remove the battery for a few minutes. Then try to start it up again.
May 13, 2011 | Dell Studio 1537 Laptop
Laptop wont wake from sleep or hibernation
1. you will need to go into you BIOS settings for the mother board to disable the sleep mode.
2. You also have a " sleep mode" in your Windows environment.
Check how to in the "help and support" link at the start button or Windows Orb ( for Windows 7)
Apr 15, 2010 | HP Pavilion dv2000t Notebook
Screen goes blank every 30 second, have to hit the
go to control panel > power options. Turn off hibernate and sleep mode, change all settings to never sleep and change the setting for "when closing the lid" to "do nothing" sleep mode, hibernation can destroy the registry on these laptops, you are better off turning that garbage off and just letting it run.
Nov 15, 2009 | Computers & Internet
My cooling fan is not working
It really is like the sleep mode / Hibernate mode when it is it really his job, also for when people are sleeping out which job as sleep, the computer does so well the reason is also removing his job when sleeping in, would have understood and helped them. good luck
Jan 11, 2009 | Dell Inspiron 1525 Laptop Jet Black
Laptop won't power up
HAVE you tried to remove the battery and than PLUG the AC in ? SEE if this helps and if that doesn't put the battery back in and take the AC out and TRY it again.
IF that doesn't WORK you may have your computer set on Hibernate or Sleep mode? THIS is in your control panel in the start menu under the POWER SETTINGS...... You should see the problem if you do get the computer running again and it happens again.
Also try to hold down the power button for 5 seconds or until it beeps and than push it again to reboot...
Sep 02, 2008 | Lenovo ThinkPad T61 Notebook
Nikon COOLPIX L20 Digital Camera Logo
266 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
