Question about Braun IRT3020 Thermoscan Ear Thermometer
Change from celcius to ferenheit
How to switch from celcius to ferenheit
How do I switch my Panasonic NN-CD989S from Celcius to Fahrenheit?
talk with your local service agent and see if he can advise on what to do as he probably has met this problem in servicing units and has to change the setting
Jul 07, 2016 | Panasonic NN-CD989S 1.5 CU FT GENIUS...
How do I change from F to Celcius
Take the thermostat off the wall & there should be a dip switch on the back for C or F. If it is programmable, you will need to get into the installation mode & change it there.
Jun 01, 2016 | Heating & Cooling
How do I can from Celcius to ferenheit
What are you trying to do this with
Oct 12, 2014 | Cars & Trucks
How to switch from fahrenheit to celcius?
Best to just keep a conversion chart nearby...or label your gauge with Celcius...
Aug 23, 2014 | 1991 Buick Park Avenue
How do I change my luxpro psd111 thermostat to display temperature back to farenheit from Celsius?
On the Luxpro PSD111, Farenheit or Celcius are selected using the Jumper Switch J2 on the rear of the unit's circuit board:
Open = Celcius
Closed = Farenheit
Jan 20, 2014 | Cars & Trucks
I have MABIS healthcare ear thermometer model no. 131-107-000 and i switched it to celcius accidentally. how do i switch it back to ferenheit? I lost my instructions.
Hold the scan button and wait for the arrow on the screen. Keep holding the scan button and push the memory button. You have to do it before it beeps.
Mar 29, 2011 | Mabis Health & Beauty
How to you change ferenheit to celcius?
Tc = (5/9) x (Tf-32); Tc = temperature in degrees Celsius, Tf = temperature in degreesFahrenheit.
Example: 40 deg. F minus 32 = 8, 8 x 5 = 40, 40 divided by 9 = 4.44 deg. Centigrade.
To go the other way:
Tf = [(9/5) x Tc]+32; Tc = temperature in degrees Celsius, Tf = temperature in degrees Fahrenheit
Example: -10 deg. C x 9/5 = -18; -18 + 32 = 14 deg. F
See also: http://www.csgnetwork.com/tempconvjava.html
Jan 29, 2011 | White Rodgers White-Rodgers 1F85RF-275...
How do change the thermostat from celcius to
The switch to change it should be on the upper left corner on the back of the t-stat.
You can see where it is here on page 14-15..
http://www.hunterfan.com/uploadedFiles/Support/Downloads/44550.pdf?n=4754
Heatman101
Feb 28, 2010 | Hunter Fan Company 5/1/1 Programmable...
I have a hunter 44150B thermostat and when i replaced the batteries, the temp is in celcius instead of ferenheit...HELP!
Pull the whole thing off the wall there is a switch on the back marked F and C. Make sure the switch is set correctly.
Feb 02, 2009 | Hunter Fan Company 5/1/1 Programmable...
Changing the temp. from Celcius to Farenheit
The correct formula is to take the Celcius degrees and multiple by 1.8 and then add 32.
or
F = (C x 1.8) + 32
Regards, Wayne Parrish
Jan 09, 2008 | Sharper Image SI686 Clock Radio
Braun IRT3020 Thermoscan Ear Thermometer Logo
32 people viewed this question
Top Braun Home Experts
 Adam D
Adam D
Level 1 Expert
Are you a Braun Home Expert? Answer questions, earn points and help others
