Question about Toshiba e-Studio 350 Copier
350 hdd mount fail - Toshiba e-Studio 350 Copier
Hdd mount failed toshiba studio6530c
Make sure the HDD is inside the machine...
Feb 23, 2015 | Toshiba Office Equipment & Supplies
HDD mount failure on Toshiba 351c copier
"HDD mount" means it has an internal hard drive (HDD, or hard disk drive), and the copier has failed to "mount" (place in operation) that disk drive. That error means that the internal hard drive has failed and needs to be replaced. It will very likely need to be a special proprietary hard drive, preloaded with some sort of operating system for the copier, and you'll need to get it from a dealer.
Jul 30, 2014 | Toshiba E-studio 351c Color...
I can't access to toshiba e452, It wrote "fail to mount HDD" please advice what should I do?
Sounds to me like your HDD has gone Tango Uniform. On a 452 I would find a 40GB HDD somewhere for cheap, slap it in and then follow the directions in the Service Manual (probably can find it by googling) You'll also need a copy of the latest firmware (SYSTEM 356 on that model). Good luck!
Feb 12, 2013 | Toshiba e-studio 455 Copier
My toshiba e-350 displays F104
F104 indicates HDD CRC error.
What u can do:
Perform bad sector scan 08-694. If result fail, u might need to replace HDD.
Jun 07, 2012 | Toshiba e-Studio 350 Copier
452 HDD mount failed
If u install new HDD, u need to make partition (3+CLEAR), update firmware (4+9), initialize updating data (08-947), format HDD (08-690)
Jun 03, 2012 | Toshiba COPIERS E-STUDIO 520 Copier
Error code F105 studio 450
F105 indicates HDD other error
Perform the bad sector check (08-694). If the check result is OK, recover the data in the HDD. If the check result is failed, replace the HDD.
Sep 17, 2009 | Toshiba e-Studio 350 Copier
ToshibaStudio 350 , showing code F105
F105 indicates HDD problem.
U need to check followings:
(1) Check if the connectors of the HDD are disconnected.
(2) Check if the connector pins are disconnected or the wires of harnesses are broken.
(3) Perform the bad sector check (08-694). If the check result is OK, recover the data in the HDD. If the
(4) Replace the SYS board.
Jan 25, 2009 | Toshiba e-Studio 350 Copier
Toshiba e-Studio 350 Copier Logo
15 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
