Question about AcuRite Professional Weather Center
Acurite wireless professonal model 01035 month and the total next to it are the same even after a moth has passed
The total changes on each as we get more rain but they are always show the same total on both of the readings..
Model 1099rx not working,even after I replaced all batteries
sorry but we need make and model to begin the process .
Mar 31, 2015 | Computers & Internet
How do I change from Fahrenheit to celcius? Model # 00621cadia2
You can download the manual here http://www.acurite.com/kbase/00621_Weather_Station.html
Set the Time, Date & Units Press the "SET" button, located on the back of the display unit, to enter SET MODE. Once in set mode, the preference you are currently setting will blink on the display.
To adjust the currently selected (flashing) item, press and release the "up" or "down" buttons (press and HOLD to fast adjust).
To save your adjustments, press and release the "SET" button again to adjust the next preference. The preference set order is as follows:
TIME ZONE ( PST MST CST EST AST HAST AKST) DST (Daylight Saving Time ON or OFF)*
CLOCK HOUR
CLOCK MINUTE
CALENDAR MONTH
CALENDAR DATE
CALENDAR YEAR
TEMPERATURE SCALE ( ?F or ?C) BAROMETRIC PRESSURE SCALE (inHg or hPa)
*If you live in an area that observes DST, DST should be set to ON, even if it is not currently Daylight Saving Time.
You will automatically exit SET MODE if no buttons are pressed for 30 seconds. Enter setup mode at any time by pressing the "SET" button.
Jan 10, 2015 | Measuring Tools & Sensors
Manual for model 00592txr
sending unit is too close , it needs to be at least four feet away from unit
Nov 11, 2014 | Acu-Rite AcuRite IndoorOutdoor Wireless...
Need User manual
I cannot find your model L50668TX thermometer on Acurite's website. That said, you can search available product manuals here:
Alternatively, if you still need more assistance/User Manual information, you can contact them with these details:
Website: http://www.acurite.com/support
Customer SupportTel: (877) 221-1252
Mon - Fri:
7:00 a.m. - 7:00 p.m. CT
Sat - Sun:
8:00 a.m. - 4:00 p.m. CT (Oct - Feb)
spacer.gifWholesale(866) 249-1045
Mon - Fri: 8:00 a.m. - 5:00 p.m. CT
support-mail.jpgMailing Address
Chaney Instrument Co.
965 Wells St.
Lake Geneva, WI 53147
Email: info@chaney-inst.com
Apr 16, 2014 | Acu-Rite Acurite Wireless Indooroutdoor...
MONTH AND DAILY RAIN TOTAL ARE ALWAYS THE SAME EVEN AFTER A MONTH
Try going to the rain section, push the + BUTTON 5 times, and then on the 5th push, hold the button for 3-5 seconds and the guage will reset to 0.
Mar 28, 2014 | Acu-Rite Acurite Wireless Weather...
ACU RITE Wireless Thermometer Model L5C0668TX cant set the date
I have misplaced the user manual for the
Acurite L5C0668TXACU RITE Wireless Thermometer Model L5C0668TX. Where can I get another?
Jul 19, 2012 | Acu-Rite Acurite Wireless Indooroutdoor...
I have a acurite wireless thermmeter model 75107 after changing the baterry I am not capturing the outdoor temps
In essence, you need to re handshake the units. There is a seek button on one or both that institues the process.
Mar 16, 2011 | Vacuums
I have an Acurite 822-RX thermometer that shows HH as the outdoor temp, even after replacing the batteries in both the base and remote units. How can it be fixed or reset?
HH means it is showing the high temperature you (most likely accidentally) set with the MAX MIN / + button, which is easy to do when setting the clock. Just press that button again until the reading appears.
Jan 15, 2011 | Acu-Rite Acurite Wireless Weather...
My acu-rite keeps beeping even after a battery change. Why?
I cut the wire that leads to the annoying noisemaker. Carefully remove the rear cover to expose the circuit board (the rear cover is connected to the circuit board so pull them apart carefully). Locate the noisemaker, mine was round and connected to the back cover with black and red wires. Cut the black and red wires and replace the rear cover. NOTE: If you use the alarm feature, it won't work anymore. I read on the Acurite site that the reason it beeps is because of interference with the wireless signal. They suggest not using one of your wireless devices. If you are like me, that isn't a good option.
Nov 11, 2010 | Acu-Rite AcuRite IndoorOutdoor Wireless...
AcuRite Professional Weather Center Logo
Top AcuRite Measuring Tools & Sensors Experts
Tom Chichester
Are you an AcuRite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
