Question about Cell Phones
Hinomoto manuals How to remove starter on 3 cylinder diesel Hinomoto approx 23HP No visible bolt heads but appears 2 nuts Should remove but is starter attached to A plate ..? Nuts. And bolt both turn so logic Would call to look for bolt heads. Must be Covered up so. Thus remove a plate? Stuck. Need advise. tTtHANKS
barkencoa
  • 3463 Answers
SOURCE: Changing Smeg SA280X/1 fan motor, shaft nut stuck?
Most fan blades are held on by a single nut, which is usualy a left hand thread, so to unscrew it you turn it clockwise as though you are tightening it up.and to tighten it,anticlockwise..
If the spindle turns, then you will have to hold it with a pair of grips or similar.
Plz rate my solution.
Thabks.
Posted on Jan 10, 2009
  • 744 Answers
SOURCE: Removing rusted nuts from bolts to replace toilet seat
Try:
* Penetrating oil...let it soak at least 1/2 hour
* If the nut is stripped, try either grabbing it with vice grips
* If all else fails, either grind it off, or use a nut splitter. Nylon is pretty soft, so it should be relatively easy to break
Posted on Apr 28, 2009
joecoolvette
  • 5660 Answers
SOURCE: How to loosen screws to remove blades from Ozito OZPL400A planer
WD-40 is nice for some situations, but not this particular one. I suggest you use something like Liquid Wrench. Apply, tap the nuts on each side with a metal punch, and a very small hammer. Not hard! You're just trying to bust any rust loose, and give the liquid wrench a chance to ease down in there.
Just tap!
How are you holding the bolt head on the other side? If these nuts are so corroded that this method won't free them, you make want to see if a 1/4 inch air ratchet wrench is available. The wrench is shaped in a 90 degree angle, so it should fit down in there. Have any mechanic friends? The bolts may break. It may come to this. Be sure the bolt head is held secure, so that no damage will come to the planer. If they, or it, breaks, you can just replace them. Make sure they're Grade 5 or above, bolts and nuts.
I've had to use a small propane torch to heat the nuts. The rust breaks free. I hope it doesn't come to this.
Posted on May 10, 2009
  • 62 Answers
SOURCE: How to use the clip attachments for Frank drop in sink
Click this:
http://64.26.61.110/grfx/pdf_files/granite_AMERA_dropin&UM.pdf
Page 2, step six
Posted on Jun 05, 2009
  • 58 Answers
SOURCE: How to remove a power steering cylinder from Case 440 tractor?
There is special ps pulley puller. Should be the same as a car. Can either buy or rent one.
Here is an example:
http://www.etoolcart.com/browseproducts/Power-Steering-Pulley-Puller-OTC4530.HTML
Posted on Jun 19, 2009
Looking for free download oh manual for hinomoto e182.
Feb 15, 2016 | Sewing Machines
NEED DIAGRAM FOR LOCATIONS OF CRANKSHAFT PULLY,OIL SLINGER AND SPRING.FOR 1983 MAZDA 2.2L DIESEL
Here is the procedure:-
  1. Remove setscrew from side of cylinder block.
  2. Remove oil pipe attaching bolts.
  3. Remove oil pump and strainer.
TIMING GEAR COVER
  1. Remove timing gear cover to case attaching bolts.
  2. Remove timing gear cover and gasket.
CAMSHAFT, CRANKSHAFT, IDLER & INJECTION PUMP GEARS
  1. Remove oil slinger and washers from crankshaft snout.
Using puller set 49 0839 425C or equivalent, remove crankshaft timing gear, Fig. 3.
  1. Position a clean rag between camshaft and idler gears, then remove cam gear lock bolt and washers.
  2. Using puller set 49 0839 425C or equivalent, remove cam gear from camshaft, Fig. 3.
  3. Remove idler gear to spindle retaining nuts and washers, then remove idler gear and spindle assemblies.
  4. Remove injection pump drive gear.
  5. Remove timing gear case to cylinder block attaching bolts, then the timing case.
CAMSHAFT
  1. Remove tappets from cylinder block.
  2. Remove camshaft thrust plate to cylinder block retaining bolts and washers, then pull camshaft from block.
PISTON & CONNECTING ROD
  1. Remove connecting rod bearing cap retaining nuts and bolts, then separate bearing cap from connecting rod.
  2. Using the wooden handle end of a hammer, push the piston and connecting rod assembly outward until piston rings clear cylinder bore. Remove piston and connecting rod assembly through top of cylinder block.
  3. To separate piston from connecting rod, remove piston pin retaining clips, then press pin from piston using a suitable driver.
CRANKSHAFT
  1. Remove rear oil seal cap retaining bolts, then the cap and seal.
  2. Remove main bearing cap to cylinder block retaining bolts, then the main bearing caps and thrust washers.
  3. Lift crankshaft from cylinder block.
Mar 26, 2015 | Mazda Cars & Trucks
Where are the bolts located to remove starter from 2006 chevy colbalt
I had a suspicion, so I checked. Sure enough, this is one of those fantastically engineered engines with one bolt visible, and the other INSIDE THE FRIGGIN' BELL HOUSING.
Have fun getting to that one. :p
Mar 15, 2015 | 2006 Chevrolet Cobalt
Hinomoto n249
Check all the wiring for green wires, also check fuses that are inline on the wiring harness. Check switches for loose connections. Check at battery for loose connections or broken wires.Hope this helps, plese post solved on fixya.com.So I get credit for a solved problem if it does. If not, check back and give me more info.
Mar 29, 2014 | Garden
78 Yamaha XS 750 Special.. I need to replace the starter, i've loosened the two (Allen head) bolts on the back of the starter, the starter now moves back and forth abit, but won't come out.. Is...
Here are the steps from the manual:
Electric Starter Removal
1. Remove L.H. crankcase cover.
2. Remove idler gear 1 and shaft.
3. Place a folded rag between the kick idler gear two (2) and pump drive gear as shown. Remove pump drive gear nut and gear. Remove cam chain.
4. Remove starter clutch assembly.
5. Remove oil delivery pipe.
6. Remove cam chain dampers.
7. Remove two (2) starter motor securing bolts. Remove starter motor.
You can find PDF files of a service manual by googling:
"XS750 Service Manual"
Aug 04, 2013 | Motorcycles
I need head bolt torque specs for a 2000 cadillac deville dts..
DeVille, Eldorado, Seville 1999-2005
Cylinder Head
Print
Removal & Installation
Left Side
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Drain the cooling system.
  3. Properly relieve the fuel system pressure.
  4. Remove or disconnect the following:
    Negative battery cable Exhaust manifold Alternator Water crossover Intake manifold Valve cover Timing cover Secondary camshaft drive chain Power steering return hose retaining bolt from the cylinder head 3 M6 external drive bolts from the front portion of the cylinder head 10 M11 internal drive cylinder head bolts Cylinder head and gasket.
  5. Clean the head mating surfaces.
To install:
Fig. Left cylinder head bolt torque sequence-4.6L engine
  1. Install the cylinder head with a new gasket. Lubricate the bolts with engine oil prior to installation.
  2. Torque the M11 bolts in sequence as follows:
    1. Step 1: 30 ft. lbs. (40 Nm), plus an additional 70 degrees
    2. Step 2: Turn an additional 60 degrees
    3. Step 3: Turn an additional 60 degrees (total 190 degrees)
  3. Torque the M6 bolts to 106 inch lbs. (12 Nm)
  4. Install or connect the following:
    Power steering return hose retaining bolt to the cylinder head and tighten to 37 ft. lbs. (50 Nm) Secondary camshaft drive chain Timing cover Valve cover Intake manifold Water crossover Exhaust manifold Negative battery cable
  5. Change the oil and filter.
  6. Fill the cooling system.
Right Side
    Negative battery cable Exhaust manifold Water crossover Intake manifold Valve cover Timing cover Secondary camshaft drive chain Electrical connector from the Engine Coolant Temperature (ECT) sensor Nut attaching the coil cassette ground wire to the cylinder head Bolt attaching the exhaust crossover pipe to the cylinder head Bolt attaching the right transaxle mount bracket to the cylinder head Bolt attaching the rear transaxle brace to the transaxle Nuts attaching the rear transaxle brace to the cylinder head Rear transaxle brace 3 M6 external drive bolts from the front portion of the cylinder head 10 M11 internal drive cylinder head bolts Cylinder head and gasket
To install:
Fig. Right cylinder head bolt torque sequence- 4.6L engine
    1. Step 1: 30 ft. lbs. (40 Nm), plus an additional 70 degrees.
    2. Step 2: Turn an additional 60 degrees.
    3. Step 3: Turn an additional 60 degrees (total 190 degrees).
  3. Torque the M6 bolts to 106 inch lbs. (12 Nm).
    Rear transaxle brace over the studs located at the rear of the right cylinder head Nuts attaching the rear transaxle brace to the cylinder head, loosely Bolts attaching the rear transaxle braces to the transaxle and tighten to 37 ft. lbs. (50 Nm) Nuts attaching the rear transaxle brace to the cylinder head and tighten 37 ft. lbs. (50 Nm) Electrical connector to the ECT sensor Bolt attaching the exhaust crossover pipe to the cylinder head and tighten to 18 ft. lbs. (25 Nm) Nut attaching the coil cassette ground wire to the cylinder head and tighten to 13 ft. lbs. (17 Nm) Secondary camshaft drive chain Timing cover Valve cover Intake manifold Water crossover Exhaust manifold Negative battery cable
Apr 16, 2013 | 2000 Cadillac DeVille DTS
Could you advise what are the cylinder head bolt tension settings for hyundai lantra j5. Could you email me back on judy.ben@optusnet.com.au. Thanks
let me see if i can get some info 4 you.
edit
REMOVAL
1. Drain the coolant and disconnect the upper radiator hose.
2. Remove the breather hose (between the air cleaner and the head cover).
3. Remove the air-intake hose.
4. Remove the vacuum hose, fuel hose and coolant hose.
5. Remove the cables from the spark plugs. The cables should be removed by holding the boot portion.
6. Remove the ignition coil.
7. Remove the power steering oil pump and bracket.
8. Remove the intake manifold.
9. Remove the heat protector and exhaust manifold assembly.
10. Remove the coolant pump pulley and the crankshaft pulley.
11. Remove the timing belt cover.
12. Remove the timing belt tensioner pulley.
13. Remove the timing belt.
14. Remove the head cover.
15. Remove the cylinder head assembly. The cylinder head bolts should be removed by using Special Tool, Cylinder Head Bolt Wrench (09221-32001) or equivalent, in the sequence as shown in the illustration in two or three steps.
16. Remove the gasket pieces from the cylinder block top surface and cylinder head bottom surface. NOTE: Make sure that the gasket pieces do not fall in the engine.
INSTALLATION
1. Clean all gasket surfaces of the cylinder block and the cylinder head.
2. Install a new cylinder head gasket onto the cylinder head assembly. Apply sealant to the gasket and do not reuse the old cylinder head gasket.
3. Install the cylinder head bolts. Starting at top center, tighten all cylinder head bolts in sequence as shown in illustration, using the Cylinder Head Bolt Wrench (09221 - 32001) or equivalent. Repeat the procedure, re-tightening all cylinder head bolt to the specified torque. (torque spec is Cold Engine 105-115 Nm (76-83 ft lb) )
4. Install the timing belt tensioner pulley.
5. Install the timing belt on the camshaft sprocket, making sure that the tension side is tightened by turning the camshaft sprocket in reverse, all timing marks are in alignment.
6. Adjust the timing according to "Timing Belt"
7. Install the rocker cover and tighten the bolts to the specified torque. Tightening torque: Rocker cover belt:
2.5-3.5 Nm (25-35 kg.cm, 2-3 ft. lbs.)
8. Install the timing belt cover.
9. Install the new intake manifold gasket and the intake manifold. Tighten the nuts and bolts to the specified torque.
10. Install the new exhaust manifold gasket and the exhaust manifold. Tighten the exhaust manifold attaching nuts to the specified torque.
11. Install the surge tank and tighten the nuts bolts to the specified torque.
12. Install the power steering oil pump and bracket.
13. Install the ignition coil.
14. Install the air intake hose.
15. Connect the vacuum hose, fuel hose and water hose.
16. Install breather hose.
Jun 08, 2011 | Hyundai Elantra Cars & Trucks
How do you remove toyota timeing chain
Timing Chain and Gears Removal & Installation To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Drain cooling system.
  3. Remove the upper front fender apron insulator.
  4. Remove the upper radiator support insulator.
  5. Remove the right front wheel and tire assembly.
  6. Remove the right lower splash shield.
  7. Remove the drive belt and alternator.
  8. Remove the air switching valve (XRS)
  9. Remove the power steering oil pressure switch connector.
  10. Remove the 2 power steering mounting nuts and through bolts. Remove the steering pump from the engine. Secure the steering pump to the cowl toy_car_15_wood_block_on_jack.gif
  11. Raise and support the engine with floor a jack. toy_car_18_eng_rh_mntng_inslt_blts.gif
  13. Remove the 2 nuts, 2 clips and the cylinder head shield (except XRS).
  14. Remove the 4 ignition coils.
  15. Remove the 2 ventilation hoses from the cylinder head valve cover.
  16. Remove the 9 bolts, 2 seal washers, 2 nuts, cylinder head cover and gasket (except XRS). XRS toy_car_18_eng_cylndr_hd_cvr_blts_2zz-g.gif
  17. Remove the 4 bolts and the cylinder head shield (XRS).
  18. Remove the 2 nuts, bolt and remove the ventilation hose from the ventilation pipe (XRS). XRS toy_car_18_eng_cylndr_hd_cvr_ventl_hs-pp.gif
  19. Remove the Ventilation pipe and gasket (XRS).
  20. Remove the 9 bolts, wire harness protector. Remove the cylinder head cover and gasket (XRS).
  21. Remove the O-ring from the cylinder head cover (XRS)
  22. Turn the crankshaft pulley and align its groove with timing mark "0" on the timing chain cover. toy_car_18_eng_tmng_mark.gif
  23. Ensure that the marks on the camshaft timing sprockets are in straight line on the timing chain cover surface as shown. toy_car_18_eng_tmng_point_marks.gif
  24. If not turn the crankshaft 1 revolution (360°) and align the marks as above.
  25. Remove the crankshaft pulley toy_car_18_eng_rmv_crnk_sft_pos_snsr_blts.gif
  26. Remove the 2 mounting bolts and remove the crankshaft position sensor.
  27. Remove the mounting bolt, nut and the drive belt tensioner.
  28. Remove the right engine mount bracket.
  29. Remove the front exhaust pipe (XRS).
  30. Remove the Exhaust manifold brace (XRS).
  31. Remove the Exhaust manifold (XRS) toy_car_18_eng_tmng_chn_tnsnr_blts.gif
  32. Remove the 2 mounting nuts and remove the chain tensioner.
  33. Remove the water pump. Except XRS toy_car_18_eng_tmng_chn_cvr_blts_1zz-fe.gif
  34. Remove the 11 mounting bolts and nut (except XRS).
  35. Remove the 12 bolts (XRS).
  36. Remove the stud bolt.
  37. Remove the timing chain cover and 2 gaskets.
  38. Remove the crank sensor plate.
  39. Remove the timing chain tensioner slipper mounting bolt. Remove the tensioner slipper. toy_car_18_eng_tmng_chn_sprkt.gif
    Note: If the crankshaft timing sprocket cannot be removed by hand, use 2 screwdrivers. Position shop rags as shown to prevent damage.
  40. Remove the timing chain and crankshaft timing sprocket.
  41. Remove the 2 chain vibration damper mounting bolts. Remove the vibration damper toy_car_18_eng_tmng_cntrl_assy.gif
  42. Hold the camshaft hexagonal section with a wrench. Remove the sprocket mounting bolt.
  43. Remove the valve timing controller assembly and timing sprocket.
Note: Be careful not to damage the cylinder head and valve lifter with the wrench.
Do not disassemble the valve timing controller assembly.
Oct 19, 2010 | 2005 Toyota Corolla
Starter diagram for a 1994 dodge intrepid
3.3L Engine
  1. Disconnect the negative (-) battery cable. Raise and safely support the front of the vehicle on jackstands. Fig. 1: Disconnect the negative battery cable 88172g31.gif
  2. Remove the three bolts attaching the starter to the engine/transaxle. Fig. 2: Remove the three starter mounting bolts 88172g32.gif
    CAUTION
    Be careful when removing the starter motor mounting bolts, the motor can be quite heavy. Personal injury could result if the starter motor falls from its mounting position.
  3. Remove the starter from the the transmission housing. Position the starter to gain access to the wiring connectors.
  4. Remove the battery positive cable nut from the starter and remove the cable. Fig. 3: Remove the battery positive cable nut from the starter and remove the cable 88172g33.gif
  5. Disconnect the push on solenoid connector.
  6. Remove the starter from the vehicle. To install:
  7. Clean all wire terminals of dirt, grease or corrosion.
  8. Attach the electrical wire connectors and secure with the mounting nuts. Tighten the starter solenoid B+ nut to 90 inch lbs. (10 Nm) and the solenoid wire-to-starter nut to 55 inch lbs. (6 Nm).
  9. Hold the starter motor in place, then secure in place with the 3 attaching bolts. Tighten the bolts to 40 ft. lbs. (54 Nm).
  10. Lower the vehicle.
  11. Connect the negative (-) battery cable.
3.5L Engine
  1. Disconnect the negative battery cable.
  2. Raise and support the vehicle.
  3. For easier servicing, do not remove the wiring from the starter motor at this time.
  4. Remove the three bolts attaching the starter to the engine. Fig. 4: Remove the three bolts attaching the starter to the engine 88172g34.gif
  5. Remove the starter solenoid assembly from the transfer housing. Position the starter to gain access to the wiring connectors.
  6. Remove the battery positive cable nut from starter and remove the cable.
  7. Disconnect the push on solenoid connector.
  8. Remove the starter from the vehicle. To install:
  9. Clean all wire terminals of dirt, grease or corrosion.
  10. Attach the electrical wire connectors and secure with the mounting nuts. Tighten the starter solenoid B+ nut to 90 inch lbs. (10 Nm) and the solenoid wire-to-starter nut to 55 inch lbs. (6 Nm).
  11. Hold the starter motor in place, then secure in place with the 3 attaching bolts. Tighten the bolts to 40 ft. lbs. (54 Nm).
  12. Lower the vehicle.
  13. Connect the negative battery cable.
Oct 15, 2010 | Dodge Intrepid Cars & Trucks
Tools needed to remove starter on 94 dodge spirit 3.0 liter V6
Regular socket wrench set, wrench set, screwdriver, etc.: REMOVAL & INSTALLATION Fig. 1: These three attaching bolts hold the starter motor to the engine/transaxle assembly - all models 86722051.gif
  1. Disconnect the negative (-) battery cable. Raise and safely support the front of the vehicle on jackstands. Remove the engine undercovers, if so equipped.
  2. Remove the 3 bolts attaching the starter to the engine/transaxle. CAUTION
  3. Remove the heat shield and its clamp, if so equipped.
  4. Remove the two electrical wire connector terminal nuts and remove the wiring connector from the starter.
  5. Remove the starter from the vehicle. To install:
  6. Clean all wire terminals of dirt, grease or corrosion.
  7. Attach the electrical wire connectors and secure with the mounting nuts. Tighten the starter solenoid B+ nut to 80 inch lbs. (9 Nm) and the solenoid wire-to-starter nut to 55 inch lbs. (6 Nm).
  8. Install the heat shield if one was removed.
  9. Hold the starter motor in place, then secure in place with the 3 attaching bolts. Tighten the bolts to 40 ft. lbs. (54 Nm) for all vehicles except Premier and Monaco. Tighten the attaching bolts to 20 ft. lbs. (27 Nm) for Premier and Monaco.
  10. Install any undercovers which were removed from the vehicle.
  11. Lower the vehicle.
  12. Connect the negative (-) battery cable. Fig. 2: After disconnecting the starter's electrical wiring, remove the 3 mounting bolts . . . 86722p15.jpg
    Fig. 3: . . . then the starter motor can be lowered from the underside of the vehicle 86722p16.jpg
Sep 24, 2010 | 1991 Dodge Spirit
Cell Phones Logo
15 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
