Question about RELIANCE ELECTRIC WATER HEATER
Thermostat and reset button (GIANT 152ETE) - no hot water
I have a GIANT 152ETE 40 gallons. I have been reseting it for a few days now as the water is getting very hot and it shuts down. I have replaced the top thermostat and the control advice at the bottom but it is still giving very very hot water and keep shutting down when the water has reached the high temp limit I guess.
I replaced the thermostat as the water was very hot in the tank, is it a problem? Should I have waited the water to cool down before?
What would be the next step?
Could it be one of the element?
Any help would be appreciated.
Thank you.
  • email662 Jun 15, 2009
    Yes I tried to lower the temperature and it is now at 52°C but nothing has changed the water is still extremely hot.
    I did replace both the top and bottom thermostats with 2 brand new ones so I do not get it and that is why I wonder if it could be a defective element.
    Thank you for your time
  • email662 Jun 25, 2009
    It turned out that the low element was defective. I replaced it and now it is back to normal.
I have the smae problem but my element on top works fine it is the element on the bottem that does not go on so what is it that i have to change the element or the thermostat. on the bottom or the one on top. I have voltage on the top but none on the bottom element and are they suppose to go on the same time.
Posted on Apr 16, 2010
I do have the same problem with mywater tank. I have the same model. Could you tell me how can I test if the element is defective?
What kind of tool should i get?
Thanks
Sam
Posted on Jul 24, 2009
    President:
  • 3,433 Answers
Have you tried seting the temp lower and going by the water temp itself? and compare it to the thermostat? The limit swith is to prevent a runaway, The thermostat is what is supposed to control the on/of temps. The element can only work one way failure would be no heat. So it is a controller or the controller that is not signalling properly.
Posted on Jun 15, 2009
Water temp to hot,,turned all way down,changed thermistates still the same,and pops the reset button
short in the wiring bypassing the thermostats
get an electrician in as the fault is serious enough to need it resetting
May 07, 2016 | Reliance 606 Series 40 Gallon Electric...
Thero. knocks off
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Replace both thermostats. One or the other is sticking, and there is no way to test which one is bad... since test unsticks a stuck thermostat
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 01, 2014 | Reliance 606 Series 40 Gallon Electric...
Reliant 40 gallon tall electric water heater replaced both thermostats upper and lower elements flushed tank hot water very hot temp turned down lowest possible keeps tripping reset button what else could...
Problem has to be bad element or bad thermostat.
Test elements for short to ground through metal tank wall:
http://waterheatertimer.org/How-to-test-water-heater-element.html
Make sure factory-installed insulation and cover are re-installed over new thermostats so they do not misread tank temperature.
If problem does not show with elements, then replace thermostats again.
Oct 06, 2012 | Reliance & 40 Gal Electric Mobile Home...
Reliance 606 electric 40 gallon hot water heater will get extremely hot and then shut off. I have to push the reset button after showers. I have turned the heat down but it still gets to hot. Thermostat...
ECO reset button trips for several reasons.
1) Easiest thing without testing, is replace both thermostats.
2) If problem persists, then test elements.
3) If problem continues, do full troubleshoot
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 08, 2011 | RELIANCE ELECTRIC WATER HEATER
Elctrical wiring of the thermostat Rheem hot water system
Yes, the reset probably is tripped...push in the red button hard
Then turn it on and try it...
Check out this tip..
How to replace the Thermostat and Element for
Electric Hot Water Heater
heatman101
Feb 20, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water
You posted under Rheem 40 gallon electric water heater, which is two-element 240Volt heater.
If this is not your heater, add a comment.
If you suddenly have no hot water, that narrows the suspect list.
Step1:
Check for tripped circuit breaker.
Open top cover on water heater and push in reset button on upper thermostat.
If reset button is tripped out, and will not push back in, then replace upper thermostat.
Put ear against tank and listen for bubbly-fizzing sound that says heater is ON.
If reset is not tripped, then move to step 2
Step 2: use tester or multi-meter and test across top two screws on upper thermostat for 240Volt.
If heater is not getting 240V, then test circuit breaker.
Move water heater wires from 240V breaker to another same-amp 240V breaker and see if that restores power.
You may need to replace breaker:
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
If problem persists, then you might have a line problem between breaker and water heater.
Open cover on top of heater, and check connections on top of heater.
Step 3:
If heater is getting 240V, then upper thermostat or upper element is bad.
I suggest 30 minute troubleshooting which could save you a service call, and will be valuable information in the future:
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 08, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My water is not heating in my Rheem 40 gallon electric. I pushed the reset button, but when I turn off the breaker and then on again, I do not hear the elements heating up.
Electric water heater can be repaired by homeowner
If I understand correctly, water heater is producing no hot water.
Reset button clicks in, but still no heat.
Three initial things can be causing this:
1) No power to water heater. Test across top two screws on upper thermostat for 240V. Red and black wire are attached to these screws. Screws are marked 1 and 3. Upper thermostat is same that has reset button. If power tests 120 across screws, then breaker may be off on one leg. If no power, then start testing at breaker.
2) Upper thermostat is bad. Replace thermostat with generic upper thermostat available at hardware store.
3) Upper element is bad. Test and replace element using Rheem 4500 watt element available at hardware store. Image shown below. Look at label on side of tank for element wattage. Rheem puts 4500 watt elements into all their 240V electric water heaters.
If upper element is burned out the tank will not heat any water.
http://waterheatertimer.org/How-it-works.html
Rheem 4500Watt element
Upper thermostats are generic and interchangeable:
Nov 23, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
RELIANCE ELECTRIC WATER HEATER Logo
5,126 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
Paul Nielson
Paul Nielson
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
